Status
Not open for further replies.
1 - 16 of 16 Posts
04 Forester XT manually powered assisted
Selling a few items, some I never got the chance install. Strictly for all lower 48 states.
2006 STI cluster under 100k miles on the odometer. In amazing condition with no broken tabs. Will come with separate wire harness (was going to use customize to make it plug and play without cutting into my oem one)
360 shipped and all.
Grimspeed ceramic coated up pipe
-SOLD
Deatchwerks 850cc sidefeed injectors, deleted TGVs and rails (packaged together) no flow charts. all rubber components are in really good condition
230 shipped and all fees included
Grimmspeed AOS (black)
-SOLD
2001 forester s
does the sti cluster fit in our cars no problem or do you have to trim things? I know they definitely need wiring work
There’s plenty of post regarding the install of a STI cluster in our foresters you can find with a bit of searching. But does require some modifications. But Im pretty much giving you the most important and costly components.
It’s so clean!!! Been wanting to start the project but I sat on it for too long and now have to part ways with my forester.
2004 FXTi Stock
I worked with Aaron @afbeefcake and we worked to get plug and play harnesses for this kind of install. Guy does a great job and want to give him a shout if anyone wants to do something like this with @the wookie gauge cluster.
Only thing when installing is the two lower screws need to be drilled into new spots as they are in different area, but thats really easy. And it fits nicely.
Discussion Starter · #14 ·
Dude that sounds amazing. Could you send me a DM on how much he would charge if I sent him my STI harness??
Debating if I should keep it since it’s not moving as fast as I thought it would.
2004 FXTi Stock
Just PM him. He’ll build you one - no need to send him your harness.
1 - 16 of 16 Posts
Status
