1 - 2 of 2 Posts
2001 Forester
I have a section of the black molding between the roof rack rails and the roof that is slipping out or missing.
To remove or loosen the roof rack rails do I need to remove the headliner and access bolts from below? Or is there a way to loosen /remove from the top side that I can not see.
Thanks
IFAIK the roof rack is bolted on thru the roof & you need to drop the headliner to get to the bolts. :frown:
1 - 2 of 2 Posts
