As a few of us have been discussing, I'm installing a 8" sub in the 6x9 location. You can click on each picture to see a larger version.
Since I have an Forester X, the location started off with a pocket:
Behind the pocket was foam that I had to cut out. It could possibly be used as a fiberglass mold in the future...
The empty location with measurements-
First I cut out MDF to help fill the spaces.
Next I sealed the entire location using adhesive metal silicone, spray foam and RAAMmat.
Now create a speaker baffle- (Pic from Tre36's Forester)
mounted the baffle with sheetmetal screws and I sealed it up with RAAMmat.
Then I covered the area with Ensolite-
Next I mounted a JL Audio 8w6-
My wife even helped out a bit with a grill. Since the F-X does not have a speaker grill like the FXT we had to make one.
Tan grill cloth and a $2 vent from Home Depot. The grill is much bigger than the opening, but it will mount to the trim piece from behind the upholstery.
All finished!!!
From Tre36s Forester
All finished!!!
