Got stuck and partially "flooded", seeking advice - Subaru Forester Owners Forum
Go Back   Subaru Forester Owners Forum > General Forums > Member Mishaps
Old 04-20-2012, 06:29 AM   #1 (permalink)
Car Model: 2.5 X
Default Got stuck and partially "flooded", seeking advice
Yesterday I went off work at 6pm, then drove my 11 2.5X into nearby national forest to explore a dried pond I found on google earth. Had some mud fun there, but the last try was not very careful and got stuck...Luckily there were some guys playing ATV nearby, they went home and drove a 4X4 truck back to the hole and towed me out. My Forrie was sitting in mud for about half an hour, there was maybe 3 inch muddy water at the passenger side, and I didnt know how bad it was in the engine bay...but the two exhaust were not merged. The car could not crank after that, although the lights and window still work, the battery is not wet at all.
I ended up calling AAA for a flatbed and got the car home almost midnight. My wife gives me a silence treatment, which worries me more...
Now my thought is just letting the car dry out for another day or two, then trying to start it. If not, which parts would be the on checking list?
Please guys, give me some advice, much appreciated
Got stuck and partially "flooded", seeking advice-neo_img_img_4996.jpg   Got stuck and partially "flooded", seeking advice-neo_img_img_4994.jpg   Got stuck and partially "flooded", seeking advice-neo_img_img_4995.jpg
PentaGang is offline   Reply With Quote
Old 04-20-2012, 06:57 AM   #2 (permalink)
bobbotron's Avatar
Car Model: Forester XS
Sorry to hear about your mishap! Could you provide more details as to what happened when it got stuck? Did the engine cut out, or did you shut it off when you got bogged down? There were some other threads about this kind of accident recently, it can be a problem if you've sucked water into your engine. I hope it hasn't happened with yours!
bobbotron is offline   Reply With Quote
Old 04-20-2012, 07:02 AM   #3 (permalink)
Car Model: 2.5 X
I tried to rock it out but failed, then I just turn down the engine and shift to neutral.
Old 04-20-2012, 09:15 AM   #4 (permalink)
TC2000's Avatar
Gallery: 39
If it was running before you shut it off your probably ok motor wise, but your going to have to pull the carpet and see what all has gotten wet under there.
2009 Forester X Premium 4EAT
Respect The Wagon!
TC2000 is offline   Reply With Quote
Old 04-20-2012, 11:43 AM   #5 (permalink)
Car Model: Outback Limited
Transmission: cvt
Do you mean the engine would not rotate when trying to start it?
That could mean hydraulic lock, water got into the cylinders.
upflying is offline   Reply With Quote
Old 04-20-2012, 11:50 AM   #6 (permalink)
toysbyus's Avatar
....possibly move yourself into the basement before you wife tells you to????
2003 X AT
toysbyus is offline   Reply With Quote
Old 04-20-2012, 12:00 PM   #7 (permalink)
Transmission: cvt
IIWY, call the insurance company and tell them what happened.
Take that decal off the left rear passenger door before the insurance adjuster looks at it.
Old 04-20-2012, 12:13 PM   #8 (permalink)
Car Model: 2.5 X
Really hope this is not the case...
Both exhaust were not merged, and the air intake was not dripping water(just feel wet)
My hope is that only the starting coil got wet...
Old 04-20-2012, 01:00 PM   #9 (permalink)
Smooshed FOTY 2011
Blue Fox's Avatar
Car Model: Forester 2.5 XT
Transmission: 5-Speed MT
Does the motor turn over at all? Does it just not start, or is it not even trying to turn over? If water got into the pistons, you would need to take out the spark plugs, and manually turn the motor over by hand (using the crank bolt and a breaker bar) and get the water out before trying to actually start the car, or you'll destroy the motor. In actuality, this should have been the first thing done even if you suspect water got into the motor.
2004 XT - RIP
2005 XT - 5MT - JOURNAL
Blue Fox is offline   Reply With Quote
Old 04-20-2012, 01:04 PM   #10 (permalink)
flstffxe's Avatar
ECU is in the passenger foot well, they don't like water.
His - 08 X Prem 5mt
Hers - 08 X 4EAT
Subaru oil filter comparison
flstffxe is online now   Reply With Quote
Old 04-20-2012, 01:10 PM   #11 (permalink)
Smooshed FOTY 2011
Blue Fox's Avatar
^^ To add to this. Once you do get your engine up and running again (and hopefully there is no damage done). I would change the oil immediately, then run some SeaFoam in it that will help to wick out any trapped water/moisture. I would also run SeaFoam in the gas, as well as run it through the vacuum lines a couple of times over the next month.
2004 XT - RIP
Old 04-20-2012, 02:26 PM   #12 (permalink)
BrbnCwby's Avatar
Car Model: 2.5x premium
Transmission: auto
Put it up for the FOTM.
BrbnCwby is offline   Reply With Quote
Old 04-20-2012, 05:14 PM   #13 (permalink)
Car Model: Outback
Gallery: 2
Also, you're gonna want to change out your front diff fluid now.
2003 Outback 2.5 AWP.
AWDFTW is offline   Reply With Quote
Old 04-20-2012, 06:11 PM   #14 (permalink)
Fast & Dirty
SubieOutlaw's Avatar
Transmission: 4 speed auto
WOW. Sorry about the mishap. This reminds me of an off road trip near Calgary. A puddle looked shallow until I started to throw some rocks into it. Then used a stick to measure it. 2 feet deep.
As mentioned, remove decal and call the insurance adjuster. Accidents happen while going to the campsite all the time.
My 09 FXT Journal
SubieOutlaw is offline   Reply With Quote
Old 04-20-2012, 10:45 PM   #15 (permalink)
yallahyimshi's Avatar
Car Model: Forester XT Rinspeed
Transmission: manual 5 speed
an offroad advice i was given in romania from an experienced driver was not to turn of the engine when getting stuck in the water, even if the exhausts are out of it an only the nose is under water... hopefully everything is ok with your ride
Forester XT 2.0L MY04
290HP/420NM (AFP4H) by JGM
yallahyimshi is offline   Reply With Quote
