Old 02-15-2006, 08:22 PM   #1 (permalink)
Scatter Brain
Northwest Tan's Avatar
Northwest Tan is on a distinguished road
Default The "What's on Moose" Thread
What's on Moose:
(recent updates in GREEN)
Engine Stuff
  • 3" Cobb TBE w/ Cat (painted the can black to reduce bling)
  • Prodrive CAI
  • STi TMIC
  • Process West Splitter
  • VF-41
  • GST Shortblock (JE 100mm forged, balanced, blueprinted)
  • Cosworth HP oil pump
  • ARP bolts
  • Titek UP
  • Walbro Fuel Pump
  • Group N Engine Mounts
  • Samco radiator hoses
  • GM 3-port BCS
Dyno Plots:
This is with the TD04 on a Protune.[/color]
18G-TD06 tuned at GST.
Coincidentally, the plot for the VF-41 looks just like this.
VF-41 Dyno
Driveline
  • ACT HD pressure plate, SM disc
  • ACT Streetlite flywheel
  • Red Line Lightweight Shockproof
Suspension
  • COBB front and rear sway bar
  • Swift springs on OEM struts
  • STi aluminum lateral links
  • Whiteline steering rack bushings
  • Cusco rear strut tower brace
  • Group N trailing arm bushings
  • Perrin spherical front end links
  • Whiteline polyurethane rear end links
Braking
  • Hawk HPS front/rear pads
  • Goodrich lines (PTFE w/ stainless steel overbraid)
  • ATE Super Blue Racing fluid
  • Powerslot slotted rotors
Wheels/Tires
  • 17x8" +48 5-Zigen FN01R-C
  • 235/45/17 Falken 912
  • 215/60/16 Michelin Pilot Exalto A/S
  • 16x6.5" +48 Stock FXT Wheels
Alignment Specs
Front:
  • Camber: -1.0
  • Caster: 3.5
  • Toe: 0.00
Rear:
  • Camber: -1.5
  • Toe: 0.00
Misc.
  • PLX DM-100 w/ AFR, Boost, Oil Temp, EGT
  • Pilot 3 lamp sequential shift light
  • iPod Mod
  • Hella Supertones (git out da way foo!) :D
  • Cobb double adjustable shifter
  • Kartboy exhaust hangers
  • Sea-Scooby's complete 8" sub woofer kit
what's on Moose
Northwest Tan is offline   Reply With Quote
Old 02-15-2006, 08:47 PM   #2 (permalink)
SKSTI's Avatar
SKSTI is on a distinguished road
How's Cobb's TBE noise level (from the cockpit)? And do you think you could have gain a bit more with Ecutek instead of the AP? I'm trying to decide between the two...
PS
How is your experience with Gruppe-S? Any complaints?
SKSTI is offline   Reply With Quote
Old 02-15-2006, 09:05 PM   #3 (permalink)
Scatter Brain
PS
Nice sounding exhaust. Slight freeway drone but not louder than the wind noise.
AP > ecutek. AP has maps, protune, street tuner, boost display and can read/reset error codes. Best bang for your dollar.
Gruppe-S is great. Mike knows how to do a good tune.
what's on Moose
Old 02-15-2006, 09:34 PM   #4 (permalink)
SKSTI's Avatar
Thanks for the input.
I'm going to drop by and pick up a couple of stuff from them this coming week. Good to hear they're solid folks to deal with.
Old 03-19-2006, 07:30 AM   #5 (permalink)
Scatter Brain
Default Updates
Thumbnailed a better dyno plot and added brake system components.
what's on Moose
Old 03-19-2006, 10:49 AM   #6 (permalink)
Champion's Club
GatorXTi's Avatar
Gallery: 9
GatorXTi is an unknown quantity at this point
What is your opinion on COBB OTS STG2 vs. STG2 Protune? Am I reading your Dyno graph wrong? Are those numbers a bit low? 214/223 whp/wtq? For STG2 Protune? Curious....:think:
TAILGATOR LINK
GatorXTi is offline   Reply With Quote
Old 03-19-2006, 11:17 AM   #7 (permalink)
Mr. April 2008
Image Master
The Wraith's Avatar
The Wraith has disabled reputation
I think you and I need to find a twisty road... :twisted:
"You don't need horse power if you don't slow down."
Suby81
The Wraith is online now   Reply With Quote
Old 03-19-2006, 12:22 PM   #8 (permalink)
keyser soze's Avatar
keyser soze is on a distinguished road
The numbers are meaningless for comparisons to other vehicles, they are best used as markers for the vehicle itself for monitoring how modifications are effecting the performance.
There are too many variables at play to compare one dyno plot to another, the only exclusion would be 2 cars dynoed back to back on the same dyno, with simular temp, humidity, etc.
I am curious as to an accurate drivetrain loss index for our Subarus. With 214 HP at the wheels, what is the HP at the crank?
07 UGM WRX Wagon
keyser soze is offline   Reply With Quote
Old 03-19-2006, 03:01 PM   #9 (permalink)
Eclipse's Avatar
Eclipse has disabled reputation
Gruppe S has a an extremely stingy dyno. Even for a Mustang it's very conservative.
Eclipse is offline   Reply With Quote
Old 03-19-2006, 04:31 PM   #10 (permalink)
Champion's Club
GatorXTi's Avatar
Gallery: 9
Point taken Mr. Soze and that would make more sense Eclipse.
TAILGATOR LINK
Old 03-19-2006, 07:35 PM   #11 (permalink)
Scatter Brain
Keyser Soze and GatorXT-
If you compare the numbers to COBB's liberal dyno, mine seem low.
A stock STi on the Gruppe-S dyno puts down around 225, so I'm happy with the peak numbers...But the real story is how much area I have under the curve. Power delivery is SO much smoother on the Protune map compared to the shelf stage-2 map. The power is more usable (for lack of a better way to word it).
Wraith-
Moose will kick a$$ in the twisties but I am not the best on the street. I have more confidence around cones...
Mike at Gruppe-S did a great job giving me a great tune that really shines at the auto-x.
what's on Moose
Old 03-26-2006, 01:46 PM   #12 (permalink)
Scatter Brain
Post Update March 26, 2006
Installed Whiteline ALK "sport"
Replaced COBB front sway bar with the stock bar and bushings for auto-x'ing to reduce push.
The ALK and softer front bar gives me so much more grip in front! Power can be applied much sooner and more aggressively in the turns. There is a bit more front body roll but that is to be expected from the stock front bar.
NVH is up but only noticeable when driving over small bumps or lane "dots." The front goes "bam" and rear does not.
The main reason why I chose to replace the control arm aft bushings with an ALK is because I felt that the this was cause of a left pull during hard acceleration; I had hoped the stiffer ALK bushing would correct it. So far, it seems to have worked, but won't be 100% sure until Moose gets another alignment.
On the drawing board:
Trailing Links and DBA front rotors...
what's on Moose
Old 10-26-2007, 04:40 PM   #13 (permalink)
Scatter Brain
Update the first post to reflect current parts/mods.
Installed a VF-39 and STi TMIC because I thought my TD04 was the reason the engine was drinking oil. Currently running the COBB OTS VF-39 map.
what's on Moose
Old 01-07-2008, 05:36 AM   #14 (permalink)
Scatter Brain
Updated the OP with new parts:
  • GST Shortblock (JE 100mm forged, Cosworth bearings, balanced, blueprinted)
  • ARP bolts
  • Titek UP
  • Walbro 255 liter/hour fuel pump
  • Group N engine mounts
I'll post the dyno plots after the tune; the short block is still going through the break-in.
what's on Moose
Old 09-20-2008, 08:44 AM   #15 (permalink)
Scatter Brain
The 18G died.
Installed the VF-41.
Very happy with it! Plot looks very similar to the 18G plot, but slightly higher. It is so much more fun to drive than 18G ever was.
Link to my thread about the VF-41 install and dead 18G
what's on Moose
