('03-'05) vag-com cable +rom raider - Subaru Forester Owners Forum
Old 12-05-2012, 01:30 PM   #1 (permalink)
Car Model: fxti
Transmission: 5 speed manual
Default vag-com cable +rom raider
the car have been tuned openecu... i've got my cable last week and havee tried to do some logging... can i import the tune with ecuflash and edit some parts of the tune? just want to be sure how to do it dont want to loose the tune ...
i've got some experience with megasquirt on my gc8 but ecuflash and romraider is new to me...
JDMath is offline   Reply With Quote
Old 12-05-2012, 02:05 PM   #2 (permalink)
hueyduey's Avatar
Feedback Score: 13 reviews
I can't give you too much guidance as I use the tactrix adapter. But where I would check first is in your Control Panel > System > Device Manager. Verify when the cable is connected that you see the drivers loaded for the vag-com device. Also the Openport drivers should appear (these might be tactrix specific) but I had a problem in windows where it recognized the tactrix, but didn't install the right openport driver.
If the drivers appear to be ok. The next thing to do is verify you have the newest version of 32-bit java installed. For me I had to uninstall the current Java on my computer and reinstall it. If that doesn't work then try the different final and beta versions of RomRaider. Properly uninstall the previous version before installing a different version on your computer.
hueyduey is offline   Reply With Quote
Old 12-05-2012, 02:11 PM   #3 (permalink)
Car Model: fxti
i've edited my post before i saw your answer... this issue is now okai ;) java was the problem now i can log ;)
now just want to know how to corretly import my current tune to be able to adjust some things...
Old 12-05-2012, 03:08 PM   #4 (permalink)
hueyduey's Avatar
Once you've imported your current ROM using ECUFlash, then open the file using RomRaider's ECU Editor.
If you're familiar to modifying ECU parameters, RomRaider should be straight forward.
The upload process is the same as how you imported. Use ECUFlash and upload it back. FYI is something wrong happens during the upload process. Don't turn your ignition key to the off position, this will brick your ECU.
