#63 (permalink) | ||
'04 F-XT PSM MT '97 SVX LSi EPB '02 AW WRX Wagon |
#64 (permalink) | |
Frank |
#65 (permalink) |
Well here's my sheet w/ the pe1820, pe850cc injectors & Hyperflow tmic on 93 octane. Highest numbers are (in green) 312.66 whp/302.43 wtq in case its not visible. Tuned by Jorge
#66 (permalink) |
Here's Zippy's latest numbers. This was on a dynojet at 5280 feet. The Black lines are Cobb Stage 2 and the Blue are Cobb stage 1 both done on the same dyno. My guess is that I'm getting a little over 300 lb/ft of torque and 260-270 hp and at the crank. Let me know if you've got a beter estimate. I'm mostly happy about how flat and V8ish the torque curve is. Maybe next year a bigger IC and a protune.
COBB Stage 2 etc. |
#67 (permalink) | |
http://www.gruppe-s.com/geoff/MY06-STI.jpg
-Mike- | 2008 FSXT ( Aspen White) |
#69 (permalink) | |
BLUE WASABI
(#2 Info Provider) |
BLUE WASABI |
#70 (permalink) | |
What mods do you have? Nice numbers!
SUV - Sick Utility Vehicle 05 FXT 5MT |
#71 (permalink) | |
I'm enjoying it. There's quite a difference in torque between the 93 oct. and 100 oct. fuel. (304 ft.lbs/364 ft.lbs) Have to save up for a new clutch...
#72 (permalink) | |
Engine/Exhaust Mods: -pe1820 turbo (ported) -pe850cc inj. -Hyperflow TMIC -GM boost solenoid -Typhoon intake -Perrin inlet -TXS stealthback (w/hiflo cat) -Helix up-pipe -H&S backbox (Scoobysport) What is really nice is the smooth power delivery. I'm making power almost all the way up.
#74 (permalink) |
23 psi what my tuner told me, and that it's fine.
I don't completely understand the relationship between boost, horsepower & torque, and fuel & air delivery, but my tuner was happy with the map and so was I when I drove the car. Also no boost creep issue.....yet. That may change when it gets colder, but I'll have to see.
#75 (permalink) | |
Good to know you're making good numbers with the txs stealthback and highflow cat. I pulled mine thinking it was bound to be fouled from the high egts sometimes but I was wrong.. it looks perfect inside still. The TXS cat is ceramic though. I wish it was made from the new metal substrate stuff.
