#511 (permalink) |
Car Model: turbotek tuned fxt
Any one know why my graphs are backward? These are two different runs with two different maps one daily driver map and one aggresive track map. Both are 2nd gear pulls to redline as it is the shortest gear. The numbers are good a little high but it a vitual dyno jet but the graph is going the wrong way is it a auto thing? Car is a 2011 xt 4eat major mods are
Vf52 ipr tmic dw65c pump id1000cc injectors aem cai 3'' catless tbe acessport pro tune on e85 Last edited by nate_fisher; 10-07-2012 at 02:52 PM. |
#512 (permalink) | |
I stapled my
Car Model: FSXT
Transmission: 4EATme
Feedback Score: 9 reviews
#514 (permalink) |
Car Year: 08
Car Model: FSXT
VF48
TXS TMIC Tial 38mm MVS EWG on Grimmspeed coated uppipe Grimmspeed EBCS TiC Motive composite tumbler TGV deletes DW 650cc injectors Perrin turbo inlet, afta maf, and panel filter Xcceleration UEL Headers (wrapped), and 2-catted downpipe Milltek 3" Exhaust Cobb AP Tuned 274whp and 325wtq at a max of 19psi tapering down to 10 psi. AFR is at 11.0 at WOT ![]() Uploaded with ImageShack.us |
#515 (permalink) |
1
18G
08 STi TMIC Perrin EBCS welded TGV deletes KS phenolic spacers hacked stock airbox Ebay silicone inlet Cobb afta maf STi headers cleaned up, coated & wrapped GS cross pipe coated & wrapped GS up pipe coated & wrapped Invidia D/WG catless DP, wrapped custom 3" CBE (w/Hi-flow cat) Lightweight chromoly flywheel perrin lightweight crank pulley Five-O 850cc injectors Walbro 255lph pump Stock range plugs Cobb AP Harvey "the boost creep" tuned at 5800FT asl with a 1.15 Correction factor. Using this factor an 07 STi puts down 225. 91 octane, conservative tune for winter & road trips down to sea level ![]() E85 tune
04 FXT 18G E85 00 Outback 5MT 8th & 9th Subarus Last edited by Shef; 12-13-2012 at 07:27 PM. |
#517 (permalink) | |
Car Model: FORESTER
Transmission: AUTO
#518 (permalink) | |
Car Model: FORESTER
Transmission: AUTO
#519 (permalink) |
Yes they are inflated numbers for sure as its a virtual dyno so you cant really take them to serious. But people are putting down the bottom numbers all day on a vf52 so its probly not to far off. There is a guy on nasioc tuned buy junior2jz that put down 315whp and 400wtq on 93oct on the vf52 and much more on e85. There are dozens of people in the 330 range on that turbo all day long. But i just sold it so stay tuned for my td06 20g 8cm numbers on e85 im hoping to come near 400whp around 22psi.
#520 (permalink) |
1
Looking forward to seeing this!-^
I should probably just subscribe to your journal
04 FXT 18G E85 00 Outback 5MT 8th & 9th Subarus |
#521 (permalink) |
Car Year: 08
Car Model: FSXT
It's actually 12psi not 10, my mistake. I wonder the same thing too, and when I asked the tuner why he choose to install the 12psi WG spring instead, he said he feels more comfortable going with that for a DD. Would rather him use the 14psi spring but I'm fine with it as it pulls nicely upto redline with the added benefit of being somehat conservative..
#523 (permalink) |
2006 XTI LTD
Car Model: Forester XTI LTD SG9
Transmission: 2007 STI 6 speed, HP Techs-MPS LR 2.5, Junior Tuned, 560 WHP/ 490 WTQ
2006 FXT-XTI full STI mechanical conversion 07 STI 6 speed/ R180
4th gear Cobb AP v2 Stock EJ255 VF48 w/ WG welded shut, H/S PnP'd Cobb SF intake GMS inlet & AFTA MAF ETS TMIC GS EBCS Killer B Holy Header w/ custom up pipe & Tial MVR EWG Cobb full 3" custom catted exhaust w/ +12" resonator in mid pipe Full 1.75" EWG exhaust Walbro 400 E85 FP Aeromotive FPR Perrin Fuel rails DW 850cc injectors dyno. stock STI: 230 WHP Junior tuned Stock STI clutch let go at 440 WTQ, probably would have made more TQ and HP Both E85 & 93 graphs
2006 XTI LTD, HP Techs/ MPS SS LR 2.5, '07 DCCD Pro 6 speed/ R180 drive line Last edited by manitou; 01-05-2013 at 11:17 PM. |
#524 (permalink) |
2006 XTI LTD
2006 Forester XTI, stock ECU, Cobb Access Port v2
2007 long ratio 6 speed 245/45-18 Conti EXT DWS tires MPS 2.5 SS long rod short block with custom LR JE 925SD pistons and custom Saenz Super H beam +2mm rods, dynamically balanced to within .10 gram. MPS 10mm PnP'd oil pump My D25 heads, HP Techs CnC'd PnP'd, bowl blend, dog leg blend, Supertech +1mm valves, dual spring valve train. Kelford R199B cams Net calculated CR yeild 9.6/1 STI intake manifold Grimm PnP'd, coated TGV Deletes, Grimm PnP'd, coated Air pump delete Killer B Holy Headers w/ Tial MVR EWG/ 1 bar spring installed, ceramic coated. EWG 1.75" exhaust with Super Trapp SC Elite tunable muffler and 18 discs. Blouch Dom 3.5 XTR, 8cm coated hotside, welded IWG flapper. Cobb hi flow catted TBE, full 3", v- banded, + 12" vibrant resonator in mid pipe Grimm Speed EBCS Cobb SF intake/ fully closed Cobb air box and ram air into box Perrin 3" TIH & Afta MAF ETS TMIC Forge bypass valve w/ blue spring & 2 shims STI Grimm PnP throttle body AEM 3.5 bar MAP sensor w/ Cobb MAP adapter AEM IAT sensor on TMIC in front of throttle body Grimm Speed MAF block off plate Walbro 400 E85 fuel pump w / DW 12 gauge direct hi amperage re- wire kit Aero motive FPR set at 50 psi Perrin TF fuel rails Deatchwerks 1100 TF disc valve injectors Fluid dampner crank pulley ACT Streetlite flywheel, XT SS clutch, dynamically balance on top of complete rotating assemble at .10 gram Crawford AOS w/ PCV delete Mishimoto FXT radiator & stock fans/ shroud Grimm 160 deg. thermostat AEM Wideband failsafe gauge AEM oil pressure gauge AEM coolant temp gauge Dyno stock STI: 230 WHP Junior tuned, Speed Density, 21 psi/ 93 pump gas and 26 psi E85 graphs
2006 XTI LTD, HP Techs/ MPS SS LR 2.5, '07 DCCD Pro 6 speed/ R180 drive line Last edited by manitou; 01-08-2013 at 04:32 AM. |
#525 (permalink) |
Car Model: 2.5xt on E85
Thats huge power manitou! Very nice.
