anyone done it? I am thinking about it.
IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles the $575 option |
Advertisement |
#2 (permalink) | |
SUPERZILLA
the TCU is located under dash left of steering column ![]() put a (6 Ohm 10 W IIRC) resistor between (B55) No.3 and (B55) No.4 will improve the shift firmness..if it dosent try a 5 or 4 Ohm, don't bother with a VB mod on this vehical..sorry IPT
a6n6d6y Last edited by a6n6d6y; 08-17-2008 at 08:25 PM. |
#4 (permalink) | |
SUPERZILLA
simply put, it puts the TCU in direct control of the clutches and brakes..in the older system the TCU just controlled when and how firm, but valves and accumulators did the actuation of the clutches and brakes in the transmission
a6n6d6y Last edited by a6n6d6y; 08-16-2008 at 09:22 AM. |
#5 (permalink) | ||
Administrator |
#6 (permalink) | |
so, this will work on 2004 FXT 4Eat, Correct?
Thanks RYNO Quote:
#7 (permalink) | |
SUPERZILLA
my wife's 92 legacy does a better job of being in the right gear at the right time
a6n6d6y |
#8 (permalink) |
SUPERZILLA
you might want to be careful to make sure the wiring is the same...but yes this will work on all 'direct control' fozzys if the plugs on the TCU look exatly the same then it should work fine as is for $35 you can download the service manuals for your car from here..Subaru Technical Information System - Home you want the resister to jump across the two wires for the "Line pressure linear solenoid"
a6n6d6y Last edited by a6n6d6y; 08-16-2008 at 09:20 AM. |
#9 (permalink) | |
Administrator |
Even the failure-prone SVX transmission has a better feel to it and quicker response to throttle input, and we've been trying for a while now to kill the 4EAT in our 98 Forester to replace it with the JDM STI 4EAT we have in storage. It just won't die.
#10 (permalink) | |
Are you running this on your XT right now, in addition to the IPT valve body upgrade? Chance of any TCU Codes popping up with the resistor mod? Last edited by SkateandDestroy; 08-16-2008 at 01:32 PM. Reason: I'm stupid. |
#11 (permalink) | |
SUPERZILLA
I see no reason why putting the resister next to the TCU would work any differently than on the VB, but no I haven't tried this method if you get a code from this try a resister with a higher Ohm number
a6n6d6y Last edited by a6n6d6y; 08-16-2008 at 02:31 PM. |
#12 (permalink) |
Someone be the guinea pig for this and let me know how it works!!!!!!!!
I'm almost positive the wiring is different for early XT's though..Someone else did a CenterDiff Lock on an 04XT and the pin/plug were different than the 06 model. So I'd imagine the Line Presure would be different too. |
#14 (permalink) | |
Groovologist
| Thread Tools | |
