so i pulled my engine and replaced the old worn leaking head gaskets,no problem, it was pretty easy really. the problem was after i cleaned up to take it on a drive. it started right up no problem, sounded better no leaking fluid from anywhere ALL fluid is at the right level, the problem is when i pull it down in to gear ( it an auto) i have no transmission. there are no engine codes, no missing or extra bolts, no wires left undone, nothing that i can see as a problem besides that my car doesn't drive, i have no power to my wheels. of anyone can steer me in any direction i'd appreciate it. i have been told to pull the the transmission lines from the radiator and check to see if the transmission oil pump is working, any other suggestions.
thanks
Adam:huh:
its a 2001 forester 150,000 on it
auto trans
no problem besides leaky head gasket until now
thanks
Adam:huh:
auto trans
