hi all, i noticed recently that the front end of the forester was wheelspinning a lot when i hit the gas. strange i thought as its AWD?
read a few threads, and as its an auto it should be sending most of the power to the rear under high throttle conditions.
so i started thinking that i have diff issues and all sorts, but it then it hit me that this started after I fitted the electronic speedo converter...... with this in mind i removed the converter and took the car for a good thrashing.
all back to normal, no front wheels lighting up and power to the rear again.
when i bought the converter I was assured that it was programmed for the automatic version and would work fine? it does the job and the gear changes seem ok, its just the center diff that seems to be affected..........
has anyone else had issues like this??
