Replacement Instructions for front axles?
7K views 7 replies 5 participants last post by  dasboot
Today while I was out playing in the snow, I ripped open one of my cv boots. I would like to replace the front axle. Is there a DIY video, or pictures somewhere?
Thanks!!!!
#4 ·
Anyone know if the outer joint separates from the shaft? Or is the outer joint permanently attached to the shaft? I'd rather not have to to remove the inner DOJ and boots and everything in order to slide the outer boot through that side. It would be ideal to remove the outer joint and just slide the boot through that side, and not touch the DOJ at all. Any ideas?
#7 ·
You need to take your axle(s) to:
Axle Rebuilders
5517 Hollywood Blvd'
Los Angeles, CA 90028
323-856-0761
ask for Mateo
$60.00 each for a complete rebuild with new boots, new bearings and races, new grease, and they clean, wire wheel and repaint all of the parts so when you get them back, they look brand new.
Takes them one day.
By the way, what the heck is that picture in your avatar?
