After reinstalling the engine, to do the head gaskets, I had the light and code mentioned above. After some research, I found that the pressure solenoid was broken from jacking the trans up to align the engine. It turns out the solenoid is very close to the bottom of the pan.
Does anyone make a t-pan skid plate for these things?
I had exactly the same problem. Change the engine gasket and also broke the line pressure solenoid.
Change the solenoid and now I have a problem in changing second gear to third, the change makes it a little slow.
Has anyone else had this problem? How I can fix it?
Did you replace the red solenoid yourself to resolve your problem?
