('01-'02) How to replace rear axle shaft? - Subaru Forester Owners Forum
post #1 of 14 (permalink) Old 05-08-2011, 04:01 PM Thread Starter
Car Model: Forester S
Hi everyone,
3 out of 4 CV joints on the rear axle shaft are shot on my 2001 so I guess I'll replace the rear shaft ***'y.
Is it a big job to replace the rear axle? What problems I'm likely to run into? i dod not find anything on the forum yet?
Forester S 2001
Bezou is offline
post #2 of 14 (permalink) Old 05-08-2011, 07:41 PM
This is for the fronts, but may help: Replacing a CV Axle?
TD
'98 S
'04 FXT
'93 SS
'02 GG
'96 GD
wtdash is offline
post #3 of 14 (permalink) Old 05-09-2011, 04:09 PM Thread Starter
In fact the big question is should I take the diff out? If so, do I need to drain the oil first?
I found this How To: How To: Change rear axle - Subaru Impreza WRX STI Forums: IWSTI.com but it's seems to be specific to the STI not the Foz.
Forester S 2001
Bezou is offline
post #4 of 14 (permalink) Old 05-09-2011, 05:25 PM
No way do you need to remove the rear diff (or the gear oil in it if you do - but might be time to change the gear oil).
Edit: Yes, you can do it this way - mea culpa! (but only if you can't get the bolt out of the rear lateral links/control arms.)
When you undo the big axle nut, on the outer end of the axle, and remove the roll-pin on the diff side of the axle, it will be loose...I just can't remember what else, if anything, needs to be loose to get it out.
Td
'98 S
'04 FXT
'93 SS
'02 GG
'96 GD
wtdash is offline
post #5 of 14 (permalink) Old 05-09-2011, 05:56 PM Thread Starter
Just what I thought!
Chilton says you need to remove the diff to get the axle loose but it would not be the first time they are wrong!
Forester S 2001
Bezou is offline
post #6 of 14 (permalink) Old 05-09-2011, 07:55 PM
Well, I can't believe it but in this POST for a WRX they DO suggest dropping the rear diff...what a PITA!
Option #2 (this is how it's described in the FSM): Check THIS post on how to do an STI which should be similar. When removing that control arm bolt in #5, make sure it's been sprayed w/PB Blaster for as long in advance as you can.....If Quebec salt their roads yours is likely very rusty.
Option #3: Also, I 'think' that if you remove the 2 bottom bolts on the rear strut you can move it out of the way to get the axle out...but not sure...since I don't see it mentioned, probably not.
TD
'98 S
'04 FXT
'93 SS
'02 GG
'96 GD
wtdash is offline
post #7 of 14 (permalink) Old 05-10-2011, 02:40 PM Thread Starter
Quebec do salts their roads so no it is likely to be rusty. I'm not sure if the control arms as the same as an STI but I'll check.
Worst case I'll take the diff out. Sometime it's just faster to things properly than try to cheat!
Forester S 2001
Bezou is offline
post #8 of 14 (permalink) Old 05-10-2011, 02:46 PM
jgrote's Avatar
I found that pulling the link bolt is the easiest way. You may have to destroy the bolt to get it out, so buy a new one in advance.
jgrote is offline
post #9 of 14 (permalink) Old 05-10-2011, 03:26 PM Thread Starter
I'll start to shoot some rustcheck on it. Should be handy when I'll be ready.
Forester S 2001
Bezou is offline
post #10 of 14 (permalink) Old 05-15-2011, 09:44 AM Thread Starter
C-Clip dimension?
I had to take down the diff since the control arm bolt was impossible to remove. Everything was alright until I put everything together. The c-clip were not on the old axles. I put everythin back together ( hey it worked for the old ones) but the axle keeps popping out
The closet suby dealer is a 2 hr drive and before pulling everything apart again I would like to have those clips on hands.
Do you know which sizes are those clips? I could get them locally before doing the fix.
Forester S 2001
Bezou is offline
post #11 of 14 (permalink) Old 08-17-2011, 03:27 PM
CinderBlock's Avatar
Car Model: ES300
Originally Posted by Bezou View Post
Thanks!I found this How To: How To: Change rear axle - Subaru Impreza WRX STI Forums: IWSTI.com but it's seems to be specific to the STI not the Foz.
Anyone try this on their SF? And any extra parts I should get before hand?
Ford F150
CinderBlock is offline
post #12 of 14 (permalink) Old 08-18-2011, 08:46 AM
zzyzzx's Avatar
I have never done one in the back of the car, but I would have to think that it's easier than doing a front one. Probably much easier.
zzyzzx is offline
post #13 of 14 (permalink) Old 08-24-2011, 03:45 PM
Car Model: SF9BY7W
Transmission: TZ1A3ZC2AA
Rear Axle replacement
Piece of Gateau!
1. Remove Caliper and disc.
2. Remove Knuckle brace bolt (17mm).
3. Support Knuckle with Jack.
4. Remove Knuckle Strut frame bolt (19mm).
5. Remove Axle nut.
6. Tap axle nut to loosen from hub.
7. Pry axle from differential.
Notes:
1. When replacing bolts use MolyLube liberally.
2. MOST IMPORTANT: The after-market boot clamp on the outside CV joint will likely be ripped off due to minimal clearance exposing the CV joint to dirt (Subaru uses special clamps). I've successfully made clamps using heavy wire and a tool called Clamp Maker available from Gempler's. Pay attention to the direction you make the clamp and the forward rotation of the CV joint.
Bonne Chance!
AxleNut is offline
post #14 of 14 (permalink) Old 05-24-2015, 06:39 PM
SO the axle just came right out of the differential now I can NOT get it back in. IT seems like it is in all the way but I can just pull it out by hand. Is this normal? When I bolt the knuckle back up will it just hold the axle in the differential?
SwellSuba is offline
