Front Differential Oil Change - Subaru Forester Owners Forum
post #1 of 11 (permalink) Old 09-21-2009, 02:13 AM Thread Starter
Car Model: Forester S
I have a 2001 Forester S. I apologize if this has already been covered but I couldn't find the answer after a lot of searching.
Does the front differential share oil with the transmission oil?
If not, does anyone have a writeup or pics of how to change the front differntial oil? I found good pics of the rear, but not front. Thanks!
Mike
emeraldspread is offline
post #2 of 11 (permalink) Old 09-21-2009, 04:00 AM
Car Model: Mitsubishi Pajero
Transmission: 5spd Automatic
I'm going to change the front diff oil too. I know it got it's own oil tho and the dipstick is on the other side as opposed to the transmission oil dipstick.
So the diff oil is on the passenger side if you exclude cars from UK, Japan and Australia I guess.
I'm guessing filling oil on the front diff is in the same way as the transmission. Through the dipstick hole.
07 Mitsubishi Pajero 3.2 5EAT
99 Forester: Sold
Elmy is offline
post #3 of 11 (permalink) Old 09-21-2009, 04:03 AM
vintage42's Avatar
Car Model: LL Bean (4EAT)
Originally Posted by emeraldspread View Post
I have a 2001 Forester S... Does the front differential share oil with the transmission oil?...
It does only if the transmission is manual. You don't say what transmission you have.
2008 LL Bean
vintage42 is offline
post #4 of 11 (permalink) Old 09-21-2009, 03:07 PM Thread Starter
It's an automatic.
Can't find the front level gauge dipstick to add gear oil! Anyone know where this is?
Mike
post #5 of 11 (permalink) Old 09-21-2009, 03:31 PM
On the 08 its back near the fire wall..close to the middle..but closer to the driver's side. Its down there pretty far.
adc is offline
post #6 of 11 (permalink) Old 09-21-2009, 05:11 PM Thread Starter
How bout on the 01?
post #7 of 11 (permalink) Old 09-21-2009, 05:17 PM
Car Model: Forester L
Your 2001 S model should be similar to my 1999 L model. The front differential dipstick should be located on the right hand side (passenger side on American models, driver side on Australian) near the firewall. If you stand by the right fender looking toward the back of the engine you should see a small yellow dipstick; its buried pretty far back there but you should be able to see it and reach it with your hand. You may need to snake your arm around a couple of hoses, but it is within arm's reach from the side of the car. Draining the oil is simple, there is a drain plug on the bottom of the differential. Replace the plug after draining, and fill to the full mark on the dipstick.
jared1970 is offline
post #8 of 11 (permalink) Old 09-21-2009, 06:17 PM
Veece07's Avatar
Agreed. I just did every thing a month ago, trans, rear and front diff's. I regretfully did not take any photos, but the front diff, on an auto, is buried fairly deep behind the air filter on my 2000 N/A.
Really, it was fairly easy to change all of this, but more difficult to check the levels as the gauge was hard to reach...
good luck!
'00 Silver SF N/A 4EAT
Veece07 is offline
post #9 of 11 (permalink) Old 09-21-2009, 09:20 PM
Tremo's Avatar
Yep, on automatic tranny USA cars the auto tranny dipstick is on the driver's side and is relatively easy to access. The front diff dipstick is buried on the passenger side down low and tight in behind the engine cylinders. You will probably have to remove some of the intake plumbing to get your arm down there so you can reach it.
Make sure when you drain the front diff oil you know which drain plug you are removing. There's 3 down there, engine, diff and tranny.
Use a good quality synthetic gear oil for that diff. 75W-90 GL5.
04 Outback 5MT
02 Forester S 4EAT
88 IROC-Z T5
Tremo is offline
post #10 of 11 (permalink) Old 09-22-2009, 04:17 AM
vintage42's Avatar
Originally Posted by Tremo View Post
Y... The front diff dipstick is buried on the passenger side down low and tight in behind the engine cylinders. You will probably have to remove some of the intake plumbing to get your arm down there so you can reach it....
I just changed my 2008 automatic's front differential oil. The dipstick was easy to see and reach, without removing anything. Use a funnel with a length of hose attached. They sell them in auto parts stores for a few dollars. The differential holds just over 1 quart. If changing both diffs on level ground, buy 2 quarts -- the rear takes just under a quart and the front takes the rest of the 2 quarts.
2008 LL Bean
post #11 of 11 (permalink) Old 11-22-2009, 01:41 PM
Car Model: Forrester
Pics?
I don't suppose you can tell me where the front differential plug is?
I've made a mess of trying to do a simple oil change and now I've added the Automatic Transmission Fluid to the Front Differential Gear Dipstick (on the passenger side) thinking it was the dipstick for the ATF (which appears to be on the driver side. So, I need to drain the FD gear oil and I want to make sure I get the right darn plug this time.
I should add I have the 2008 2.5X Sports.
Joe Stevens is offline
