Fill or flush - Subaru Forester Owners Forum
post #1 of 16 (permalink) Old 06-03-2010, 09:57 AM Thread Starter
Fast & Dirty
SubieOutlaw's Avatar
Transmission: 4 speed auto
Fill or flush
Hi
I am in the process of getting ready for the 48k service. The stealership says I should FLUSH the trans with new fluid.
The service manual I own for my 09 says nothing regarding flushing. It simply says drain and fill with the volume drained.
A local Subie service expert says he just drains and refills and doubts stealership flushes.
Thoughts and recommendations.
SubieOutlaw is offline
post #2 of 16 (permalink) Old 06-03-2010, 10:37 AM
Just recently I replaced all 10 qts in my 99 Forester by removing supply line to trans cooler(pax side connection to lower radiator). I filled trans pan w/ 3 qts, started engine, and pumped out 1-1.5 qts (only 10-15 secs), stopped, refilled trans pan, and dumped caught fluid. I repeated this until clear new fluid emerged from supply line at about 10 qts. Adjust fluid level by removing or adding to get to full cold position.
Above procedure leaves a small amount of old fluid from trans cooler and trans return line in the system. I thought of this after completing my work. Not sure how to recover this last bit of fluid, but it might be possible to suction out w/ vacuum hand pump or air gun vaccum.
If fluid is in good shape, say changed w/i last 30-50k miles and does not smell burnt or foul, drain and refill pan should be fine IMO.
good luck
See you down the ROW!
1999 Subaru Forester
TexasForester is offline
post #3 of 16 (permalink) Old 06-03-2010, 10:44 AM
Feedback Score: 41 reviews
Last summer I had my trusted Subaru delership do a flush & fill on my '03 X & '07 FSXT. I opted to go with Redline synthetic ATF.
IMO, if you're going to do a "flush", do it before you have too many miles on your Forester. Both my Foresters are under 30K miles. If you have high miles & have never had a flush, I'd recommend just doing a drain & fill.
2.5x_sleeper is online now
post #4 of 16 (permalink) Old 06-03-2010, 10:52 AM
Doc Samson's Avatar
Transmission: 5 spd
Sounds like they are just trying to flush some $$$ out of your pocket, though it may be recommended for an AT. Peaty has this great write-up that also addresses the front diff for an AT - http://www.scoobymods.com/manual-tra...nge-t3091.html
Seems pretty straightforward to me, i.e. drain it and fill it. I'll be doing mine this weekend...
05 FXT w/ just a hint of mod
Doc Samson is offline
post #5 of 16 (permalink) Old 06-03-2010, 10:56 AM
Papa_D's Avatar
This is often a hotly debated topic on many forums and usually comes down to the argument about not flushing with pressure due to the danger of dislodging dirt that may eventually interrupt the proper flow of fluid and ultimately destroy the transmission.
To me, it is OK to do a flush whereby only the normal pressure of fluid flow is used to evacuate the system such as the bucket method where new fluid is poured in as the old fluid is discharged into a separate bucket.
They supposedly have machines that only use the naturally occurring pressures although I don't know what they are called and from my understanding, many of the machines force feed fluid through the system which may dislodge contaminants which could be bad indeed.
In the end I have personally chosen to do fluid drain and fill but will do it far more often and if I do flush the tranny, I will definitely utilize a non pressurized method similar to what is shown in the video I posted or at least make sure that if a machine is used that it is not pressurized and doesn't cross contaminate my fluid with another type which can also cause serious issues but either way, the idea is to maintain a reasonably new mix of transmission fluid at all times.
Maybe someone who is more familiar with the fluid filtering or lack of it in this particular vehicle can chime in and give some more advice based upon dirt in the system and the harm it may cause without a full blown fluid flush, good luck with it.
09 FXT LTD, 4 SPD AT, NAV and AutoStart
Papa_D is offline
post #6 of 16 (permalink) Old 06-03-2010, 10:56 AM
A flush is a risky thing. It runs the risk of picking up gunk that has settled in some nice out of the way nook or cranny in the tranny and dumping it somewhere you don't want it.
Same argument applies to engines.
Drain and refill ...
One of the other problems with the flush is that they can empty places like the valve body, which may cause airlocks or bubbles, and then they don't like to work. After rebuilding a valve body on a Renault I found out the hard way that an airlock in a valve body can produce some interesting results. Trying to go into two gears at once is cute.
sbrook is offline
post #7 of 16 (permalink) Old 06-03-2010, 10:57 AM
I love DIY stuff, but this isn't one of those things I want to mess with. The cost of having my dealership do the work really wasn't that bad.
post #8 of 16 (permalink) Old 06-03-2010, 11:28 AM
I just do a drain and fill every 8K miles or so.
adc is offline
post #9 of 16 (permalink) Old 06-03-2010, 11:36 AM Thread Starter
Fast & Dirty
wow.
it seems rather split. I think I will go with drain and fill.
Love the video.
post #10 of 16 (permalink) Old 06-03-2010, 06:59 PM
Papa_D's Avatar
Originally Posted by SubieOutlaw View Post
wow.
Love the video.
I couldn't find the two bucket method video where you have fresh fluid being sucked in at the same time it is being expelled which is what some of the Titan guys do rather than a "pressure flush" which is where I believe a lot of flush problems originate, that and also cleaning fluid additives and or cross contamination.
The two bucket method is similar to what you see in the video only you would detach the inlet and rest that hose in a bucket filled with fresh fluid, that way you don't have to worry about adding fluid, just watching for a color change.
If I do drain and fills, I will likely do four or five in fairly quick succession in order to eliminate most of the old fluid but maybe someone good at higher math can tell us exactly how many quarts of fresh fluid we will have to add to get a nearly complete fluid exchange.
Papa_D is offline
post #11 of 16 (permalink) Old 06-04-2010, 07:59 AM
4str's Avatar
Car Model: Forester 2.5X Premiu
I spent several hours reading all those debates out there re pressurized flush vs drain + fill. Personally, I'm not going to ever do the pressurized flush.
2010 Forester 2.5x Prem, 4AT, Newport Blue Pearl
4str is offline
post #12 of 16 (permalink) Old 06-04-2010, 09:47 AM Thread Starter
Fast & Dirty
I think I will do drain and fill and few times within 500km.
I will then start to do drain and fill every 20k. The atf fluid from Subaru is $8 a litre. Pretty cheap insurance to spend $40 every 20k. Yes?
post #13 of 16 (permalink) Old 06-04-2010, 10:18 AM
funkymonkey1002's Avatar
Car Model: 2.5 XT
imo this is the best way to do it. A drain and fill every 7.5 to 15k (ever 2 to 4 oil changes depending on how hard you drive). This will keep good clean fluid in there all the time without wasting a bunch of good fluid by doing drain and fills in short succession (each time you do a drain and fill you're getting some of the new and some of the old and only about a third of the total fluid).
The "2 bucket" method of flushing would be the best, a lot of dealers have a machine that basically does that automatically. They call it a flush but its basically a fluid exchanger, which I wouldn't worry about using. I would however stay away from any pressurized flush or any that they use special fluids, cleaners, additives etc.
funkymonkey1002 is offline
post #14 of 16 (permalink) Old 06-04-2010, 04:40 PM Thread Starter
Fast & Dirty
Just bought 12 litre of Subaru ATF
post #15 of 16 (permalink) Old 06-04-2010, 06:35 PM
Papa_D's Avatar
I would like to think that a drain and fill every now and again is the way to go but I wonder how the old fluid effects the new fluid with regard to any degenerative effects on the new fluid, any chemical engineers out there care to chime in?
I had a fluid exchange done to my Titan at the dealer but it was the non pressurized type and I personally knew the guy doing it for me and everything was fine.
In the end I see no difference between doing a non pressurized flush and simply running the transmission normally as far as any dirt working it's way loose and if people are careful and don't introduce air into the system or cleaning fluids, I have a hard time believing that a simple, non pressurized fluid transfer is responsible for any harm or malfunctions but on the other hand, a pressurized flush with cleaning additives seems risky at best.
Papa_D is offline
