Center Bearing replacement - Subaru Forester Owners Forum
post #1 of 7 (permalink) Old 03-19-2010, 03:11 PM Thread Starter
shourican's Avatar
I had a noise under load on my 04 XT mt. It was a whirring sound.
Anywho, my mechanic friend and I put it up on the lift and he said it was the center bearing. Should have taken a picture, but its a big rubber bushing with a bearing inside it that the rear drive shaft passes through. Its attached to the body by two bolts. I tried searching the forums and the net, but it seems this piece is only sold with the driveshaft maybe?
Trying to find a solution, any help is appreciated
-Steve
04 Silver XT 5spd
06 LL Bean hers
shourican is offline
post #2 of 7 (permalink) Old 03-19-2010, 06:43 PM
flstffxe's Avatar
Only available from Subaru with the driveshaft.
Should be able to find a used one or if one can remove the bearing from the rubber damper, at that point a bearing is a bearing and you only need to match the bearing numbers and press it back into the dampener.
08 X Prem 5mt
flstffxe is offline
post #3 of 7 (permalink) Old 03-19-2010, 06:46 PM
funkymonkey1002's Avatar
Car Model: 2.5 XT
lol I have the same problem (along with eventually needing anew drive shaft). Everyone says to get an impreza DS but reuse the stock center bearing, but you can't get a forester center bearing by itself.
I'm getting tempted to just throw a 1 piece driveshaft on that has NO center bearing.
funkymonkey1002 is offline
post #4 of 7 (permalink) Old 03-19-2010, 08:42 PM
Woody '04's Avatar
Car Model: Forester X, MT
I did just that on a toyota corona wagon that was a little longer than the forester. it worked just fine, however it didn't have the exhaust run under the driveshaft so you may want to look closely at the clearances and keep in mind suspension travel. i was thinking about this myself. in a larger city there should be a shop that specialized in driveshaft repair that can do the welding and balancing.
anyone else go 1-piece driveshaft already?
'04 Forester X 5spd MT
Past Green, Red '00 L 5spd
Woody '04 is offline
post #5 of 7 (permalink) Old 03-20-2010, 05:55 AM
Car Model: 2.5 XT
Well thats actually my issue now. I replaced my catback with a newer one that has a slightly larger resonator. Theres enough play in the rubber damper in the center bearing that the DS sometimes rubs against the exhaust as it is, there are a couple rusty lines around the DS. I figure there will be less movement in a 1 piece driveshaft, and I'd probably get the resonator replaced with a straight pipe.
I can't find any bolton 1 piece driveshafts that definitely fit the forester however. I have a FXT 4eat, and I figure a 4eat WRX 1 piece driveshaft -should- work, but a bunch say that even on the impreza "modifications are necessary".
Also oddly enough a high end 1 piece aluminum driveshaft is -cheaper- than a replacement stock DS from a dealer (i guess they are simpler though).
post #6 of 7 (permalink) Old 03-20-2010, 07:03 AM
flstffxe's Avatar
Suspension travel is not an issue with the driveshaft as the rear diff is fixed and does not move with the suspension like a solid rear axle in a truck....
There are shops out there that offer one piece driveshafts(for the Imprezza), but for the price I would look into having my own made locally.
THE DRIVESHAFT SHOP
08 X Prem 5mt
flstffxe is offline
post #7 of 7 (permalink) Old 08-21-2015, 01:33 AM
Niko_Forester's Avatar
Here is a link to the recoded audio of my centre bearing noise which could only be heard between 50 to 60 kph (30 to 40mph). My 06 forester is currently getting repaired under the used car warranty as provided when I purchased my used forester. I had the car not even 1 day and noticed this horrible noise. The video contains good quality audio recordings from inside the vehicle.
https://youtu.be/dUyqHbMtPkU. - Auido only
Niko_Forester is offline
