('06-'08) auto stuck in park - Subaru Forester Owners Forum
post #1 of 18 (permalink) Old 07-17-2011, 03:41 PM Thread Starter
yerrow's Avatar
Car Year: 4/07
Car Model: wrx wagon/fozzy xt
Transmission: manual/auto
auto stuck in park
2007 auto xt 66k miles, not the wrx but the forester
it just started recently, but many times throught out the day, when starting the car i can't seem to get from park to drive or reverse.
foot on the brake, parking brake down, and stuck in park. usually after a few gentle tries it'll release into reverse or drive but its becoming annoying.
thoughts? advice?
home of the turbo awd waguhns
yerrow is offline
post #2 of 18 (permalink) Old 07-17-2011, 03:55 PM
good dog's Avatar
Car Model: XS
Have you had the console trim off recently around the shifter to clean? That's a common issue that the trim is not fully into place causing the shifter to hang up. There is also a brake switch that is part of the shifter interlock that could need adjustment. I'll see what I can find with a search.
2008 Forester XS 4EAT
Next TBD?
good dog is offline
post #3 of 18 (permalink) Old 07-17-2011, 04:06 PM
good dog's Avatar
Car Model: XS
automatic transmission shifter issues posts 4-7
Next TBD?
good dog is offline
post #4 of 18 (permalink) Old 07-17-2011, 05:43 PM
flstffxe's Avatar
^^ Good Dog has got you pointed in the right direction or at least one of a few.
Other possible options:
Brake switch(brake lights work?)
Shifter mechanism/linkages
wiring fault
08 X Prem 5mt
flstffxe is offline
post #5 of 18 (permalink) Old 07-20-2011, 08:05 PM
good dog's Avatar
Car Model: XS
You've got two options but since you have now indicated the brake lights are intermitent the second will likely be the solution.
1) With the shifter console trim off, clean the shifter lock solenoid, #18 the button may be sticking
http://opposedforces.com/parts/fores...llustration_4/
2) Replace #9 part #83370AA001 MSRP $40 should be able to get it for about $30 online, should be stocked at most dealerships, I'd hope. I guess you could also see if you can lubricate the switch button with some dielectric grease/lubricant.
http://opposedforces.com/parts/fores...llustration_2/
Next TBD?
good dog is offline
post #6 of 18 (permalink) Old 07-20-2011, 09:12 PM
Car Model: XS Premium
Or a squirt of WD40 or PB Blaster, using the red tube for careful aim and trying to get it into the space between the button and the body of the switch, and then manipulating the button by hand a few times to spread it around.
A loose connector at the back of the switch could also be a culprit, but that's a less likely situation.
bbottomley is online now
post #7 of 18 (permalink) Old 01-29-2013, 05:45 AM
Car Model: Fozzy XT
Is this part# for all years? My 07XT is doing the same thing.... hard to get out of park and intermittent brake lights.
Worked like a champ, fixed 2 issues. Thanks guys
Paul - 2007 FXT
pzr2874 is offline
post #8 of 18 (permalink) Old 05-15-2013, 03:35 AM
Brake light switch worked for me
Hi all,
just to contribute to this thread -- I had the same problem with the auto shifter stuck in park (a 2006 Forester). After reading the suggestions above I took off the paneling of the transmission, cleaned everything up including that solenoid that unlocks the transmission when stepping on the brake, and used WD40 on the switch at the top of the brake pedal. Then I drove around for a while and waited for it to happen again. It took a few days, but eventually it did, and it was clearly the break pedal switch because my brake lights weren't going on. I even noticed that the switch was coming out as it should when I press on the pedal, but still no lights ... so definitely a defective switch.
I then searched online and found the part on ebay for US$6! However, I needed it done asap, and the only ebay parts at those prices were from the US. We're in Australia, and I couldn't wait that long (I think driving without brake lights is illegal after all), so I had to get the part at a dealership here -- cost me AU$54. Crazy what a difference that is.
Anyway, I replaced the switch, only took about half an hour, and haven't had the problem since -- all sorted! This is definitely an easy DIY job, it's a bit fiddly to get to, but not hard to do.
However, just in case anyone else has this issue -- since I drove to the dealership with the switch already out, the check engine light came on. This worried me (had I knocked any electric wires by accident?) but now a few days later that's turned itself off -- apparently the car computer detects when things that seemed wrong have righted themselves.
Happy tinkering and a massive thanks to all those giving advice on this -- you probably saved me $100 or more in repair costs, much appreciate it!
Jasdh
jasdh is offline
post #9 of 18 (permalink) Old 10-11-2013, 02:27 PM
Car Model: Subaru Forester XT
Need Some Help - Problem exists even after changing switch
Guys,
have a 2006 forester XT. Same problem just happened recently and after reading the posts on the forums, figured I order a new switch on ebay (83370AA001). I figured that had to be the problem since I was not seeing any brake lights come on at all when depressing the brake.
After changing the switch, it is still not working. No brake lights, shift inter-lock not working unless I manually depress it, checked all fuses. So what else can it be?
the only thing that I can think of is that I recently installed rally lights and havent had a chance to fix it yet but the inline fuse for the lights keep blowing. I think there is a short somewhere near the lights themselves but I decided to leave the fuse out and fix it later. Then this problem came up. Related?
Any help would be appreciated!
rlk204 is offline
post #10 of 18 (permalink) Old 10-11-2013, 02:34 PM
Superacerc's Avatar
Car Model: 2.5xt 6 Speed Swap
Definitely possible if that fuse powers your brake lights. I'm not sure exactly but that shift lock solenoid could very well be powered off the light circuit which now gets no power.
Off-road 6 speed swap with
Stage II AWDTUNING Block
Superacerc is offline
post #11 of 18 (permalink) Old 10-11-2013, 02:48 PM
Let me clarify. Sorry. These are external Hella lights. The inline fuse is to the relay that came with the hella lights and its hooked up to the battery directly so I dont think it could be related. I am going to disconnect it as a precaution anyway until i get the brake lights/shift lock problem figured out first.
Any other suggestions? Do you know if the solenoid has a fuse somewhere or could that affect the brake lights not coming on?
rlk204 is offline
post #12 of 18 (permalink) Old 10-11-2013, 02:50 PM
Superacerc's Avatar
It's definitely coverd by a fuse but probably lumped under the brake light fuse. Just check all your internal and external fuses. I'd get a multimeter and test to see if the selonoid gets 12v supply when you touch the brakes.
If your brake lights arent coming on theres a fuse blown or a wire broken somewhere.
You can always rig it if you have to temporarily by getting a 12v supply and switching it to activate the selonoid. Probably a fuse though.
The other thing that could be faulty is the brake light switch itself. If it's broke the lights won't come on and most likely the lock won't get activated either.
post #13 of 18 (permalink) Old 10-11-2013, 03:19 PM
Thanks again
When you say the switch, do you mean part #9 #83370AA001
Because that is what I did figuring that had to be the issue since there was no brake lights. Just want to make sure theres not another switch.
thank you for your suggestions. Im going to try tinkering a little more tomorrow. I've had a day and a half today. My other car was broken into last night and now I have 2 non working cars that I cant drive until I get the glass replaced in the morning. For the subie, if I can't figure it out I am going to have the guy who is going to install my downpipe fix it once I get it in this week.
rlk204 is offline
post #14 of 18 (permalink) Old 11-18-2013, 02:02 PM
Just an update - turns out it was a blown main fuse
I definitely shorted it when I was messing around with the hella lights. Dealer had to replace main switch fuse and my heated seats switch. $400 for my idiocy but lesson learned.
rlk204 is offline
post #15 of 18 (permalink) Old 07-19-2014, 03:31 PM
Car Model: Impreza Touring Hatc
I seem to be having the same problem today. Car starts fine but will not come out of park. The fuse looks fine but replaced it just to be sure but didn't fix the problem. I removed the rear tail lights and the bulbs and wires appear fine. I took the console around the shifter off and there doesn't seem to be anything blocking it. If I push down the shift override button it will come out of park.
I recorded a video to see if my brake lights were coming on and it would appear they come on about 50% of the time. When they do come on it will shift out of park.
Based on all that does it sound like the brake switch down by the pedal?
'14 Impreza Touring Hatchback - CVT
shane_c is offline
