('09-'13) 4EAT Trans Temp Gauge - Need Install Tips - Subaru Forester Owners Forum
 8Likes
  • 2 Post By FXTerrific
  • 1 Post By GTEASER
  • 1 Post By 2.5x_sleeper
  • 1 Post By fozroamer
  • 1 Post By FXTerrific
  • 1 Post By skirbykat
post #1 of 15 (permalink) Old 05-18-2017, 11:48 AM Thread Starter
fozroamer's Avatar
Car Model: Subaru XT
I plan on installing a trans temp gauge to monitor my trans temps on the little offroad trailer that I am pulling. I have a Hayden aftermarket trans cooler but need to monitor the temps. I plan on getting some kind of gauge and mounting the sensor in my trans oil pan. Any siggestions on installation or type of gauge to purchase would be greatly appreciated.
fozroamer is offline
post #2 of 15 (permalink) Old 05-18-2017, 11:53 AM
FXTerrific's Avatar
Car Model: XT Touring
does the trans pan have the same thread and all as the oil pan? i ask as theres a couple companies that make a replacement drain plug/bung (for the oil pan one)....that let you run a sensor through it.
305WHP/360WTQ
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
FXTerrific is offline
post #3 of 15 (permalink) Old 05-18-2017, 11:57 AM
FXTerrific's Avatar
compared to just drilling a hole in trans pan...and welding in a bung for the sensor.
305WHP/360WTQ
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
post #4 of 15 (permalink) Old 05-18-2017, 11:58 AM
FXTerrific's Avatar
wahooo! @GTEASER , always to the rescue
GTEASER's 2009 XTeaser
305WHP/360WTQ
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
post #5 of 15 (permalink) Old 05-18-2017, 12:01 PM
GTEASER's Avatar
Car Model: FXT Limited
@FXTerrific you got a busted link.
GTEASER is online now
post #6 of 15 (permalink) Old 05-18-2017, 12:02 PM
FXTerrific's Avatar
doesnt look like it. it takes me to the right post in your thread. but if so, sorry:
"Also installed the Killer B 20mm to 1/8"NPT sensor adapter drain plug and put my trans temp gauge sensor in. Ran the wire up to the top of the firewall and left it coiled up until I get to the rest of the install."
-GTEASER
[/QUOTE]
HeyChris and GTEASER like this.
305WHP/360WTQ
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
post #7 of 15 (permalink) Old 05-18-2017, 12:41 PM Thread Starter
fozroamer's Avatar
Sweet! Thanks for that. Now to decide on a proper gauge. Was going to go with a GlowShift 7 color Trans temp gauge. Do you have a link for that Killer B 20mm to 1/8" NPT adapter?
Edit: NM Found it! http://www.killerbmotorsport.net/oil...r-adapter.html
post #8 of 15 (permalink) Old 05-18-2017, 03:15 PM
GTEASER's Avatar
@fozroamer , I am using VEI dual function gauges. I paired the trans temp with water temp and will be getting another for oil pressure and oil temp, and another for boost and AFR. 6 monitors in 3 gauges. Win win. Elegantly simple and well built gauges. And lots of options as far as dimming both with and without the dash lights on.
Personally I would avoid the GlowShift products, kinda bottom of the barrel.
http://www.veisystems.com/ws/8-d1-se...unction-gauges
http://www.veisystems.com/old/docs/I...-TTC-WTC-M.pdf
https://www.amazon.com/s/ref=nb_sb_n...%3Avei+systems
fozroamer likes this.
post #9 of 15 (permalink) Old 05-18-2017, 04:39 PM
Feedback Score: 41 reviews
@fozroamer take a look at this thread Write-up for installing 4EAT cooler?, specifically this post in that thread.
That's the direction I plan on going. Take at this post in my Member Journal: Autometer ATF temperature manifold.
2.5x_sleeper is offline
post #10 of 15 (permalink) Old 05-19-2017, 11:59 AM Thread Starter
fozroamer's Avatar
D1-Series Gauges - VEI Systems
That is a sexy gauge. So I bought that Killer B Motorsport M20x1.5 to 1/8PT adapter I assume it will be compatible with the Veisystems gauges?
GTEASER likes this.
post #11 of 15 (permalink) Old 05-19-2017, 12:07 PM
FXTerrific's Avatar
ohhhhh. i should not have clicked on those links. me likey!
GTEASER likes this.
305WHP/360WTQ
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
post #12 of 15 (permalink) Old 05-19-2017, 03:19 PM
GTEASER's Avatar
Yessir!
post #13 of 15 (permalink) Old 05-19-2017, 03:34 PM
Location: THe unmentionable part of a female whale,California
Car Model: FOrester 2.5i
Transmission: cvt
It's also possible to install an inline T-adapter for temperature/pressure sender
VDO T - Adaptor / Fitting for Temp & Pressure Gauges | eBay
'17 Forester2.5i, CVT...6000 miles
hillbille is online now
post #14 of 15 (permalink) Old 05-19-2017, 06:12 PM
I believe I also recently shared that I switched my Fumoto from oil to trans....in other words, same pitch and thread.
Sent from my XT1585 using Tapatalk
FXTerrific likes this.
skirbykat is offline
post #15 of 15 (permalink) Old 05-22-2017, 02:25 PM Thread Starter
fozroamer's Avatar
Ok So I am going to go ahead and install an engine oil cooler as well but Im going to get one that comes with a Type A sandwhich adapter that would hopefully allow me to install a oil temp sensor into it. I will be installing a plate and fin style engine oil cooler similar to this: https://www.amazon.com/dp/B004XONT6G...I2H800BXBE7K3O
GTEASER likes this.
