I finally looked at it and yes it is the tranny dipstick on the driver side and it is labled atf. Is the fluid supposed to be clear or slightly yellow?:shrug:
Shifts fine and no weird smell.
I'm just used to red fluids.
Eta: I changed the front and rear diff fluid and it was the usual stinky gear oil smell.
I know I didn't do the wrong fluids. Oil is oil and gear lube is gear lube. Didn't touch the tranny drain plug.
No red fluids when I did my work.
Also to add the transmission fluid was pretty clean like fresh oil.
