Old 07-24-2008, 01:24 PM   #16 (permalink)
fdxforester's Avatar
fdxforester is on a distinguished road
Originally Posted by Tau137 View Post
Bad wet start is almost always an electrical issue. Anything ignition-related should be checked first - spark plug wires, coil, igniter and connections throughout. Check the sparkplugs, too - while not the problem, they may contribute due to incorrect gap or whatnot.
Then it might be some other electrical gremlin, having to do with failing sensors or not so good wiring from them (TPS, cam & crank position, knock, MAF). Check, clean (use dielectric grease on connectors where needed), reinstall.
Finally, weak alternator and/or battery may also be contributing to the problem.
Agreed, the engine shaking tells me at least one cylinder is not firing. When it happens again, pull the plug wires off one at a time. You'll know when you have the right cylinder because the rpms won't drop or the engine wont quit when you pull the wire off the plug that not's firing.
put on your seatbelt… I wanna try something.
fdxforester is offline   Reply With Quote
Old 07-24-2008, 01:43 PM   #17 (permalink)
Engineer
bbottomley will become famous soon enough
That can be a recipe for a nasty shock if indeed one of the wires is leaking. I'd tend to do the disconnecting with the engine off. I realize that you don't get the benefit of observing an immediate change in RPM that way, but you still ought to be able to see a difference.
Do the disconnect at the coil pack, not at the plug. Easier and faster there. Those plug connectors are in pretty darn tight.
2003 XS Premium MT - 2005 Impreza 2.5 RS MT
Old 07-24-2008, 02:12 PM   #18 (permalink)
2006F0717 is on a distinguished road
It's not easy to test. As I said - it should be a wet morning and cold engine.
Now everything looks dry.
Next morning should be wet again, will look then.
BTW
If a moisture is a problem then it should be a problem until engine got warm. Right?
Why the problem is only on low < 1.0 RPM?
On1.5 RPM no misfire!
2006F0717 is offline   Reply With Quote
Old 07-24-2008, 05:00 PM   #19 (permalink)
neolynne's Avatar
neolynne is on a distinguished road
Same thing happened to me. Took 3 dealers to figure out it was a cracked coil. $150 later and it ran fine.
neolynne is offline   Reply With Quote
Old 07-24-2008, 05:26 PM   #20 (permalink)
Engineer
On a dark and very dry night you might be able to see sparks somewhere. But it hasn't been like that in NH for a while!
If everything seems to be OK while you're doing this, then start wiggling things.
Old 07-28-2008, 02:52 PM   #21 (permalink)
Thanks neolynne.
So, is it possible they cracked it during the “60k miles” service?
Old 07-29-2008, 04:34 AM   #22 (permalink)
lfdal is on a distinguished road
If it is still mounted on top of the engine on the 06's, it was a real popular place to lean on, especially if you were messing around the air filter and PCV valve. I think there's a TSB or maybe just a caution notice about not placing any weight on the coil pack since you can crack it that way.
Larry D
08 OBW Ltd,
Missing my 04 FXT 4EAT
lfdal is offline   Reply With Quote
