Timing Belt Replacement Cost - Subaru Forester Owners Forum
post #1 of 16 (permalink) Old 03-31-2008, 11:38 PM Thread Starter
For everyone that has had the 105k Timing belt service done by a dealer or repair shop what did they charge you total for the parts and labor?
Anyone know what the Book Hour is for the timing belt change?
Please only respond if you yourself has had to pay for it because knowing someone that knows someone usually is not accurate. I know how long it takes me to do it and I am putting together a video that shows the process and what tools are really needed and how to do it for a beginner. I will be editing the video and adding commentary. I hope to have this done in the next couple of weeks.
speedytang is offline
post #2 of 16 (permalink) Old 04-01-2008, 01:39 AM
Roo
Dr. Detour
Site Founder
Roo's Avatar
Car Year: 98
Car Model: Forester...what else
Feedback Score: 9 reviews
Let's see...
Personally, the parts I purchased for the upcoming 105k on Silke's car would retail at ~$850.
I don't raise the bar on maintenance, I simply shatter the sky with the amount of maintenance I'm doing to ensure the longevity of the motor.
In addition to timing belt:
ALL hoses carrying fluid of ANY sort underneath the hood. This includes everything from the main upper/lower hoses to the oil cooler hoses, to the water to turbo hose, to heater hoses, from front to rear of the engine bay. I also replace the water pump and thermostat (no to thermo, just changed out at 90k).
All tensioner pulleys, idlers, and anything that touches the timing belt.
All seals. Oil pump to the block o-ring, cam/crank seals, water pump gasket (obvious) and all the front end things that can wind up leaking and being expensive to fix if we have to go in later.
The part numbers? I have at least 30 parts total on order.
Please feel free to support our Subaru parts vendors here.
Roo is offline
post #3 of 16 (permalink) Old 04-01-2008, 07:46 AM
GIT-R-DONE's Avatar
Car Model: dodge caravan
Transmission: auto
^ +1 like Roo said is what I'm doing to my forester.
I spent over $1000 in parts for the engine thats including my new set of cams
GIT-R-DONE
2010 Dodge grand caravan SE
2002 S sport 5spd SOLD
1996 L Legacy AWD
GIT-R-DONE is offline
post #4 of 16 (permalink) Old 04-01-2008, 11:35 AM
Tyranny22's Avatar
Originally Posted by Roo View Post
Let's see...
In addition to timing belt: ALL hoses carrying fluid of ANY sort underneath the hood. This includes everything from the main upper/lower hoses to the oil cooler hoses, to the water to turbo hose, to heater hoses, from front to rear of the engine bay. I also replace the water pump and thermostat (no to thermo, just changed out at 90k). All tensioner pulleys, idlers, and anything that touches the timing belt. All seals. Oil pump to the block o-ring, cam/crank seals, water pump gasket (obvious) and all the front end things that can wind up leaking and being expensive to fix if we have to go in later. The part numbers? I have at least 30 parts total on order.
This looks like the check list when I replaced my head gaskets. Don't forget to go ahead and replace the knock sensor. I spent a total of $1,200 on my refurbish. Next up are the brakes. Thank God I'm done with the engine for quite some time.
Tyranny22 is offline
post #5 of 16 (permalink) Old 04-01-2008, 11:48 AM
Car Model: XS Premium
The last time this was discussed (a few days ago) the answer generally seemed to be a bit over $1000.
bbottomley is online now
post #6 of 16 (permalink) Old 02-06-2015, 03:24 PM
Sube777's Avatar
Car Model: Forester L
Just had my Timing Belt Replaced at the Subaru Dealership in Boone NC today February 6th 2015.
My Forester has 98151 miles on it.
I wanted Everything Replaced, All Idlers, Tensioner, Water Pump, Thermostat, All the Timing Belt parts..
I was told at the dealership that they "Check" the idlers and only replace them if they "need" to be replaced... The Dealership said this is what they normally do, to keep the cost down.. Hmm.. I didn't like the sound of that.. The Idlers are very important and with 98,000 miles on them already, they are going to fail before another 100,000 miles.. If one of them should fail, as they probably will, then the warranty would be voided because an OLD part was left in, to save a few $$$ and that one old part is what caused the timing belt to break.. My engine is totaled and the warranty on the new parts is worthless because the old part will be blamed for the failure... Interesting...
Since we already have the engine taken apart and I'm paying for the labor to have this done why not replace all the old Idlers along with everything else such as the Water Pump, Tensioner, etc. so I don't have one of these parts fail 20,000 miles down the road... Why would you Not Replace the Old Idlers with New Ones since they have 98,000 miles on them? Sounds fishy to me.. I insisted they replace All the Idlers with new ones...
My Total Cost was $1032.90!! This is the Subaru Dealership Price for Replacing Everything with Brand New OEM Subaru Parts.
I had a $110 Coupon that I received in the Mail from this Dealership so My True out of pocket Cost was $968.66.
See my Invoice Photos Below.
ID:	211794   Click image for larger version
ID:	211802   Click image for larger version
ID:	211866   Click image for larger version
Sube777 is offline
post #7 of 16 (permalink) Old 02-06-2015, 04:03 PM
Car Model: Subaru
Transmission: 5sp
I service a large chunk of the Subarus in my area. I charge $200-250 for labor for a timing belt job. I normally have them source a high perf Gates kit ~$300 (I like the Kevlar belts, personally, and it comes with all idlers, water pump, tensioner, etc).
Aside from the obvious thermostat replacement and accessory belts if they look bad while you're in there, I don't do much else. I don't see a need to replace seals that aren't leaking. Preventative maintenance is nice, but can very easily go overboard.
Edit: typed all this only to realize thread is from 2008.
Please disregard.
AWDBOB is offline
post #8 of 16 (permalink) Old 02-06-2015, 04:41 PM
No need to disregard. We like to keep related information together here. It makes it easier to find.
post #9 of 16 (permalink) Old 02-06-2015, 05:35 PM
Sube777's Avatar
Old Threads are Golden
Trust me, Before I had my Timing Belt Replaced, I came here and Researched all the old post.. Old Post are Still Relevant Information.
So interesting that the Dealership tries to leave OLD Idlers in there... Sounds like they are doing this on purpose so if the timing belt fails they can say.. Oh, we see you left on Old Idler in place.. That's what caused the timing belt to fail.. No Warranty for you..
If your going to replace the timing belt, have all the idlers replaced..
Sube777 is offline
post #10 of 16 (permalink) Old 02-06-2015, 05:53 PM
This is the reason why many of us aren't keen on dealing with technical questions on our Facebook page. Here today, gone tomorrow, no benefit to anybody in the future.
post #11 of 16 (permalink) Old 02-07-2015, 09:32 AM
NinoS's Avatar
Had mine done by an independent subaru specialist on my 03. Right at $400, included water pump and crank seal.
NinoS is offline
post #12 of 16 (permalink) Old 02-07-2015, 10:04 AM
Subguy58's Avatar
Transmission: manual
hey Nino, your car looks just like mine! Green(?) 2003 X. Cool!!
Subguy58 is offline
post #13 of 16 (permalink) Old 02-10-2015, 11:57 AM
Parky50's Avatar
Car Model: 2.5 XT Limited
*** Subscribing ***
Got this coming up pretty soon... just turned 90k on the way to work today.
Parky50 is offline
post #14 of 16 (permalink) Old 03-04-2015, 05:37 PM
Car Model: FXT Ltd
Originally Posted by Parky50 View Post
*** Subscribing ***
Keep in mind, the interval is 105k, OR 105 months. You may be under in miles, but you're wwaaayyy over in time. All rubber parts deteriorate over time, regardless of mileage.
My '05 has 80k, so it is way overdue also. Whirring noises, coolant odors, etc. So I'm here reading. Will likely get this done in the next week or two.
Subbing also.
Jason
ShopJerk is offline
post #15 of 16 (permalink) Old 05-26-2015, 12:17 PM
Good info here, thanks for keeping this thread around....
My '04 Forester (one owner) only has 75k on the meter/
but obviously has more than 105 months, so I guess I
should be thinking about the tb replacement. It runs great
and is easy to drive, I've religiously serviced it myself.
My '99 Forester is still being driven by the guy I sold
it to, don't know how many miles on it by now, or what
he's done to it service wise....
The Gates kit sounds about right, replace the other
parts at the same time. Great idea.
Thanks for having this forum available.
2Loose is offline
