Timing Belt Replacement? - Subaru Forester Owners Forum
 1Likes
  • 1 Post By DMZX
post #1 of 12 (permalink) Old 11-28-2012, 05:56 PM Thread Starter
Car Model: Subaru Forester L
Question Timing Belt Replacement?
I just recently got back from the mechanics after fixing my window motor, and they said that it was time to replace my timing belt since I passed 180,000 miles. Now I'm pretty sure that they didn't check it since they just noted at it, but he said that it would cost about 1000 dollars. It sounds ridicules since it is only a belt and online you can buy them for 50 dollars. Does this sound right to replace it now? Am i spending to much money on it? Can I do it my self?
I Have a 1998 Subaru Forester L
Any info would help.
Mrbenster is offline
post #2 of 12 (permalink) Old 11-28-2012, 06:47 PM
Woody '04's Avatar
Car Model: Forester X, MT
that seems high for just the belt, but then it is california too. do you know if they were only suggesting replacing the belt or also doing more work?
when you replace the timing belt, at that mileage you should also replace the tensioner, idler pulleys, water pump, and pull and re-seal the oil pump.
first, be sure the headgaskets aren't leaking or a lot of that expensive labor would have to be re-done.
'04 Forester X 5spd MT
Past Green, Red '00 L 5spd
Woody '04 is offline
post #3 of 12 (permalink) Old 11-28-2012, 11:24 PM
Transmission: Autotragic
$1000 is actually quite reasonable if they do the service properly... that means replacing the belt, idler pulleys, tensioner and water pump.
Most of that cost is labor... it's a very labor intensive job. Just to let you know, you NEED to get the idler pulleys and the tensioner replaced. The belt itself rarely fails, it's the seizure of the pulleys that cause the belt heat up and snap, so it's imperative that you replace those while you're there.
Also, since the timing belt service isn't due til 105,000 miles, I can't imagine it needing to be changed for another 105K meaning at 210,000 so 180K seems a bit too soon. That is unless it wasn't changed at 105K in which case you are on borrowed time.
kfergiez is offline
post #4 of 12 (permalink) Old 11-29-2012, 06:01 AM
Car Year: '03
Car Model: Fozzy
Transmission: Eat A Taco
Look up a full timing kit, with water pump and cam/crank seals... runs about 400$ +/-
I would hope they would be doing a full kit for that cost, but as stated, most of it is labor..
Aaron'z 2.5RS/WRX is offline
post #5 of 12 (permalink) Old 11-29-2012, 08:34 AM
Gates timing belt kit with all pulley's, tensioner and water pump
While you're in there:
1) replace the cam seals
2) replace the crank seal
3) replace the thermostat
4) accessory belts
other items: most shops will pull the radiator. If you haven't replaced the radiator hoses, now may be a good time. If you haven't replaced the radiator, now may be a good time.
peace of mind items
Joe
Smokin_Joe is offline
post #6 of 12 (permalink) Old 11-29-2012, 08:50 AM
nashcarr's Avatar
Mine was just done at 106K. The radiator started leaking a bit a few hundred miles before so I had all of the following completed:
Gates TB kit w pullies
OEM water pump
OEM thermostat
OEM radiator hoses
OEM accessory belts
Mishimoto radiator
B&M trans cooler
2005 FXT
2010 Sti
nashcarr is offline
post #7 of 12 (permalink) Old 11-29-2012, 10:07 AM
Feedback Score: 53 reviews
Forum price list for OEM kits: Forester Timing Belt Kits
~ Silke ~
'04 FXT 4EAT PSM - "Subed Up"
'98 S 4EAT DBP - "Slynki"
pleiad7 is offline
post #8 of 12 (permalink) Old 11-29-2012, 10:59 AM
Also if you don't get a Subaru Specialist or the Subaru Dealership to do this job you are begging for trouble.
adc is offline
post #9 of 12 (permalink) Old 01-14-2015, 01:58 PM
E_S_A_D's Avatar
So, I didn't want to start a new thread, but I want some thoughts here. I have a 2008 with 110,000 miles on it. It's obviously time to replace the timing belt soon.
Here's my quote:
$580 for timing belt and main tensioner
OR
$800 for timing belt, tensioner inspection replacement, waterpump, and replace coolant
Better deal and decent costs?
E_S_A_D is offline
post #10 of 12 (permalink) Old 01-14-2015, 03:09 PM
You should insist on the idlers being replaced as well - don't count on your original ones to last 200k+. They get gritty and eventually seize, taking the timing belt with it.
Case in point: $30 now to save $5000 later...
~ Silke ~
pleiad7 is offline
post #11 of 12 (permalink) Old 10-03-2016, 03:30 PM
BigAl's Avatar
Car Model: Forester L.L. Bean
Transmission: yes
What about time?
Subaru's website recommends timing belt replacement at 105,000 miles, or 105 months, whichever comes first. On the other hand, a handout I picked up at our Subaru dealership recommends replacement at 105,000 miles with no reference to time.
Our 2006 L.L. Bean went into service in July 2006, so celebrated its 10th birthday this summer. It's at about the 123 month mark now. But it's gone only 95,500 miles. Is it reasonable to wait for timing belt replacement until it gets closer to 105,000 miles, or should I bite the bullet now?
Thanks in advance for any assistance the group could provide.
2006 L.L. Bean Evergreen Metallic ("green Bean")
BigAl is offline
post #12 of 12 (permalink) Old 10-03-2016, 04:08 PM
DMZX's Avatar
Car Model: Forester Premium
If it were me and the budget could take the hit, I would get it done. Off my mind.
Change_agent likes this.
DMZX is offline
