Subaru shutting off while driving - Subaru Forester Owners Forum
post #1 of 12 (permalink) Old 07-22-2009, 01:35 PM Thread Starter
Pls. help. We have put new sparkplugs & wires on, coil, new fuel pump, filter & relay. The 1998 forester still shuts off while driving. It used to act like it was out ot gas, but now just shuts off. It is very hard to get it restarted. Any insight or advice is appreciated. Thanks. I am trying to stay out of the shop. Thanks.
I wanted to add, the only code it is showing is the knock sensor.Could that cause it? My 2 toyota friends(with 20+yrs. exp in the industry each) say no.
minniedisney1 is offline
post #2 of 12 (permalink) Old 07-22-2009, 01:38 PM
flstffxe's Avatar
my thoughts would be cam/crank position sensor after trying what you already listed.
08 X Prem 5mt
flstffxe is offline
post #3 of 12 (permalink) Old 07-22-2009, 02:58 PM
EvilDan's Avatar
Car Model: Subaru Forester XT
Transmission: 5 speed manual.
I had a car turn off on me on the highway.. I'd pull it over and try to restart it without luck for about 5 minutes.. then later on it would start right up every time... turned out to be the .. oh ****, either the crank or cam position sensor.. I'm pretty sure it was crank though, located near the bottom of the engine. Cleared the issue right up.
2004 Subaru Forester XT. 5MT Java Black Pearl.
EvilDan is offline
post #4 of 12 (permalink) Old 07-22-2009, 03:30 PM
flstffxe's Avatar
Ford power stroke diesel owners some times keep spares in the glove box because it is so common for them. On one buddies we have changed it out twice in an intersection when it has dies and would not start again, both times it was raining heavily.
08 X Prem 5mt
flstffxe is offline
post #5 of 12 (permalink) Old 07-22-2009, 08:37 PM
LostInPhilly89's Avatar
Car Model: Impreza WRX
I happened across this thread and I have a kinda similar problem. I have a 1998 Forester as well, 5-speed manual. Twice in the past week, I've turned the key and nothing happened. All the dashboard lights came on, but no starter. It was rainy both times. Is this a similar problem?
LostInPhilly89 is offline
post #6 of 12 (permalink) Old 07-22-2009, 08:44 PM
Feedback Score: 53 reviews
Check the idle air control valve. Our SVX is having the same issue right now. We're currently in the process of replacing the fuel pump, but if that doesn't fix it, the IACV is the next thing we're going after.
~ Silke ~
'04 FXT 4EAT PSM - "Subed Up"
'98 S 4EAT DBP - "Slynki"
pleiad7 is offline
post #7 of 12 (permalink) Old 07-23-2009, 02:39 AM
BAC5.2's Avatar
Car Model: Outback XT-B
According to SOA, the car turning off while driving is "normal".
BAC5.2 is offline
post #8 of 12 (permalink) Old 07-23-2009, 02:57 AM Thread Starter
It may be "normal" to turn off, but why is it doing it & why won't it start back up right away?
Thanks for all the replies. I will let my dh know what you have said.
post #9 of 12 (permalink) Old 07-23-2009, 04:42 AM
BAC5.2's Avatar
When I brought this up about my 09 outback (why it stalls itself out when coming up to stop lights), I was told that the vehicle was operating as designed. No explanation given.
BAC5.2 is offline
post #10 of 12 (permalink) Old 07-23-2009, 05:05 AM
Car Model: Forester XS
If it's throwing a code for the knock sensor then i would start by replacing that. IIRC the orientation of the sensor is important too. Had a buddy with a WRX that ran into similar problems after an engine swap and it turned out to be the knock sensor.
TheJackman is offline
post #11 of 12 (permalink) Old 07-23-2009, 05:23 AM
Dan
Dan's Avatar
Car Year: 12
Car Model: Premium
Transmission: 5-speed
Minnie, what are the symptoms when it won't restart? Does it crank? Do you know if you're getting spark at the plugs? Do you know if you're getting fuel flow to the injectors?
FWIW similar symptoms on my brother's Probe, won't start for a long time (cranks really well) and finally catches and runs just fine. His problem is also the crank position sensor. But before attacking that item check on those three questions I asked above, and also get the CEL code looked at.
SHIFT_to_Subaru
'12 Forester, 5spd - hers
'08 Legacy SE, 5spd - hers
'09 OB SE, 5spd - mine
Dan is offline
post #12 of 12 (permalink) Old 08-03-2016, 07:25 PM
Car Model: forester xt
Transmission: CVT/XT
I have a '15 Forester XT with 13,500 miles on it and the engine shut off on I-70 in KS while I was going 70 mph. I was 300+ miles into my trip. I gassed up at a QT in Tulsa that morning with 91 premium octane. Pulled off on shoulder but couldn't get the car re-started. Had it towed to nearest Subaru dealer 60 miles back in Salina. The car sat at the dealership overnight and in the morning the mechanic said it started right up for him. I traveled on to Oregon w/o any more problems. At the time of the engine shutting down the driving conditions were: 100 degree temps outside, A/C on, cruise control on, and about 3 gallons of gas in tank.
tpd1494 is offline
