Subaru Forester Thermostat - Subaru Forester Owners Forum
post #1 of 11 (permalink) Old 05-01-2006, 08:45 PM
joel
Guest
Posts: n/a
Question Subaru Forester Thermostat
Subaru overheating, changed broken hose and replaced with new radiator cap but it's still overheating. Can someone tell me where the thermostat on a 1998 Forestor.:-( :-(
post #2 of 11 (permalink) Old 05-01-2006, 09:10 PM
GIT-R-DONE's Avatar
Car Model: dodge caravan
Transmission: auto
were the bottom rad hose goes to the engine u will see two bolts take them out and the housing out the thermostat is there.
http://www.scoobymods.com/forums/att...achmentid=2052
http://www.scoobymods.com/forums/sho...=&threadid=170
GIT-R-DONE
2010 Dodge grand caravan SE
2002 S sport 5spd SOLD
1996 L Legacy AWD
GIT-R-DONE is offline
post #3 of 11 (permalink) Old 05-02-2006, 12:54 AM
joel
Guest
Posts: n/a
Thumbs up Thermostat located.
thanks buddy. nice lights and cool doggy.
post #4 of 11 (permalink) Old 05-02-2006, 04:19 AM
The Modfather
Peaty's Avatar
Transmission: 6 Speed Manual
Feedback Score: 10 reviews
Subarus also have a headgasket problem. If the thermostat does not help that could be the cause. I hope not though.
http://www.scoobymods.com/forums/showthread.php?t=4413
Peaty
Peaty is offline
post #5 of 11 (permalink) Old 02-26-2009, 12:21 AM
Thermostat is located on the engine end of the lower (yes, I said lower) radiator hose. The housing is plastic, so work carefully. It would be a good idea to use a genuine Subaru thermostat and rubber O-ring gasket, as this will give the correct temperature. I am surprised your thermostat went bad-- usually the factory Subie thermostats last 10-15 years. To replace thermostat, drain radiator, then remove lower hose at engine end (first green shower), remove the bolts securing the lower hose connector to the engine and remove the connector (second green shower), then pull the thermostat and rubber ring out with pliers (third green shower). Installation is reverse of removal, and there is no gasket on the thermostat cover to speak of-- the O- ring around the thermostat does all the sealing. Remember to refill radiator with care, and use the air "burp" screw mounted on the radiator top, opposite the fill pipe. i got this answer at wikianswer guys....
_________________
Thermostat
thermodix is offline
post #6 of 11 (permalink) Old 12-10-2009, 05:23 AM
Car Model: Forester L, AT
Forester overheated again last night - just had the dealer replace the radiator, thermostat, water pump, and associated gaskets 2 years ago (vehicle had had the very same parts replaced just 30K miles prior to that along with cylinder head gaskets, etc. for the earlier recall). Based upon behavior, fluctuation of engine temp, heater no longer working, then temp skyrocking to the "red" zone in single digit temps, evident that another coolant issue is at hand. Is this common for these vehicles or do I have a lemon on my hands - seems that I continue to have the same issues over and over again (just long enough that the Subaru parts/labor warranty is expired).....
99Forester is offline
post #7 of 11 (permalink) Old 12-12-2009, 08:54 AM
Wormguy's Avatar
Car Model: Forester S
It could just be that your rad is leaking out of the lower tank. Can you smell coolant while you are driving?
I had a similar thing happen with my '01 a few years ago. The car was overheating and loosing coolant. It turned out to be the lower rad tank gasket. I had the dealer figure this out, and it cost about $400. A year ago I had the head gaskets done. Last month I noticed I was losing coolant from the top tank gasket (so it never lost enough to lead to overheating). It is hard to see an external coolant leak from the bottom tank. It leaks only when the system is pressurized, and then it is usually a trickle. The coolant splashes out onto the street and dries up if it hits the engine.
Try pulling out the radiator. You can do this yourself fairly easily. For my car it is: Drain the coolant (bottom drain will get a lot of it, easier if you put a short hose onto it). Remove the coolant reservoir. Remove the drivebelt covers from the engine. Disconnect the lower rad hose and catch the remaining coolant. Disconnect the top hose. Disconnect the fan electrical connectors. Remove the mounting brackets. Lift the rad+fans out. Take off the fans/shrouds.
Take it to a rad shop (the kind that does work for other dealers/shops) and have them pressure-test it and repair if necessary (probably cost ~$100).
I just did this last month (Nov 09). The time to remove the rad was less than an hour. A local rad shop repaired my top tank in a day for $95 (with a replacement tank+gasket, the right way to do it). I replaced the rad in less than 15 minutes, filled it up with coolant, and it has been fine since. I also replaced the thermostat while I was at it (a $20 part). The coolant looked good when I removed it, so I kept it all and put it back in, then topped off what I had lost. (If you do this yourself you should put in the Subaru coolant conditioner.)
2001 Subaru Forester S, M/T, 2.5L N/A, 205K miles
Wormguy is offline
post #8 of 11 (permalink) Old 12-12-2009, 09:28 AM
99S
99S's Avatar
Any external coolant leaks? I believe you have the dreaded headgasket problem. Had to get mine replaced about 5000 miles ago. I had no external leaks. Was overheating when the car would get too low on radiator fluid. For almost 3 years I was able to get away with topping off the fluid every couple of weeks. Coolant loss was never consistant, so sometimes it would be good for a month, and sometimes started overheating after a couple of days. At least 20 times was stuck on the side of the road waiting for it to cool down . Refused to just admit it and get the headgasket replaced. Changed the radiator cap, hoses, overflow tank, thermostat, housing, water pump with varying degrees of success, but never completely solved the problem. Even when I popped the timing belt, I didn't have the money to get to the headgasket. When my heads were finally removed in October, I ended up needing to get them remolded at the machine shop. The headgasket wasn't actually worn too bad, but the heads themselves were warped!
$1200 later, my Fozzy now runs like new. Now, I'm looking to put another 200k miles on her
99S is offline
post #9 of 11 (permalink) Old 12-23-2012, 06:58 PM
New User
Car Model: subaru forester
Transmission: automatic
water is not circulating to the heater core on 99 forester
I have a 99 subaru forester auto. I just changed thermostat radiator and hoses. Yet it still overheated and it would not blow out hot air. The thermostat never turned on I believe. I was told the water wasnt circulating to the heater core. Is this true? What can it be. Im looking for other ideas. Please help!!!!
kmart815 is offline
post #10 of 11 (permalink) Old 12-24-2012, 03:21 AM
Need help! My FX is overheating
adc is offline
post #11 of 11 (permalink) Old 05-21-2013, 11:20 AM
kmart815, still having the overheating problem?
crf450r is offline
