Following is elaborate bolt tightening sequence for Forester 2.5L SOHC cylinder head. Is this what all DIY'rs are using?
2) Tighten cylinder head bolts. (1) Apply a coat of engine oil to washers and bolt threads. NOTE: Bolts with pink marks on their bolts heads must be used for (c) through (f). (2) Tighten all bolts to 29 N·m (3.0 kg-m, 22 ft-lb) in alphabetical sequence. Then tighten all bolts to 69 N·m (7.0 kg-m, 51 ft-lb) in alphabetical sequence. (3) Back off all bolts by 180° first; back them off by 180° again. (4) Tighten bolts (a) and (b) to 34 N·m (3.5 kg-m, 25 ft-lb). (5) Tighten bolts (c), (d), (e) and (f) to 15 N·m (1.5 kg-m, 11 ft-lb). (6) Tighten all bolts by 80 to 90° in alphabetical (7) Further tighten all bolts by 80 to 90° in alphabetical sequence shown in figure below. CAUTION: Ensure that the total “re-tightening angle” [in the former two steps], do not exceed 180°. Thanks
See you down the ROW! 1999 Subaru Forester |
Car Model: Forester XS PP 5sp
That's what I just used on MY04. Granted, the 03/04 manual WAS different, but I have always used what the RS, Legacy, Outback and 99-02 SOHC's called for, which is exactly what you stated.
Step 3, back off 180 in BACKWARD sequence .... ie f back to a. Then 180 again. The 2 ODD colored bolts are in the center. I have seen some pink, red, black and green to date. Sometimes the 4 corners are colored, others only the center bolts are.
04XSPP, 98S (8 Subaru's since 1978, 7 were 5 sp) ILuvSubaru's |
