My wife and I were on our way home from thanksgiving weekend and we stopped to get gas, and now our 99 forester will not start. I think it is the coil but I am looking for some confirmation. It cranks fine and it is getting fuel and when I tested the coil I could not get a resistance reading on the input side of the coil, the out put was within parameters. I have ordered one from the local parts store and it will be here tomorrow. I was just wondering if there could be anything else that could cause this. Crank or cam sensor, ignitor, or ECM.
To me it I would expect more of a power supply issue as it drove into the station fine was shut off and now has no spark. Bad ignition switch, loose connection...., that type of thing. Not that a cam/crank position sensor can't fail but it just doesn't happen often with subarus.
Edit: and coils typically give signs of death, miss fires, arching.....
Cam or crank sensor will do that but I've had them fail gradually. They will be flaky; sometimes they will work after it sits for awhile. It also usually triggers a code.
I'd rule out a cam sensor issue, since there are two of them and it's unlikely that they will fail at the same time. I had one fail a couple of months ago and the car was still driveable. It just caused some bucking at freeway speeds and the car wanted to stall out at idle, but could be kept from doing so by keeping the revs up.
Not to sound dumb here, but did you check all of the ignition fuses?
I had a similar thing happen on my Nissan a few months back and one of the main ignition fuses had popped... thus preventing the car from starting despite cranking over just fine.
189K members
