steering wheel vibration - Subaru Forester Owners Forum
post #1 of 20 (permalink) Old 02-07-2006, 09:58 PM Thread Starter
Official sf.org decal guy
toddlamp's Avatar
Feedback Score: 20 reviews
I just picked up my 06 FXT and it has about 600 miles on it. When on the highway I get a very noticable vibration in the steering wheel. It seems to only happen between 75 and 80mph. I thought that the front wheels may be out of balence but why is it that if I slow down or speed up past 75mph-80mph there is no vibration? I would think an out of balence front end would cause a vibration from 75mph (when it starts) on up and not go away past 80mph.
Get your SF.org decals at
toddlamp is offline
post #2 of 20 (permalink) Old 02-08-2006, 05:04 AM
Cubby's Avatar
Car Model: Forester S
Transmission: 5 MT
I had a similar problem with my 01. At at exactly 100kms I would get a bad shake in the steering. Anyways I had the tires rebalanced and its fine. I also get a shake when the rims plug up with snow.
Check the tire pressures in the tires. Make sure they are the same all around. That might also help.
2001 Forester S
5MT
Cubby is offline
post #3 of 20 (permalink) Old 02-08-2006, 05:04 AM
It'll probably be an out of balance or out of round tire, you can have a resonance develop at certain speeds that's damped otherwise.
brett s is offline
post #4 of 20 (permalink) Old 02-08-2006, 05:34 AM
Feedback Score: 53 reviews
Check the tire pressure. Our SVX has developed the same annoying problem lately, and it's always an indicator of unequal pressure in the tires.
~ Silke ~
'04 FXT 4EAT PSM - "Subed Up"
'98 S 4EAT DBP - "Slynki"
pleiad7 is offline
post #5 of 20 (permalink) Old 02-08-2006, 06:10 AM Thread Starter
toddlamp's Avatar
Thanks, I will check that today. What is a good tire pressure for front? and rear?
toddlamp is offline
post #6 of 20 (permalink) Old 02-08-2006, 06:45 AM
#8 Post ho
SenorSubie's Avatar
Car Model: Subaru Forester
32/31 26/24 depends on driving preferance for handeling/gas milage
99 AT-
wrx goodies
Subiegal Gauge Pod
SenorSubie is offline
post #7 of 20 (permalink) Old 02-13-2006, 09:01 PM Thread Starter
toddlamp's Avatar
Wow. What a difference. I was skeptical at first until I checked the pressure. 24 psi all around. Seriously low. And I was wondering why I was getting 17.5mpg. Anyway, thanks for the advice and it seems all better now, no vibration.
toddlamp is offline
post #8 of 20 (permalink) Old 02-17-2006, 05:44 PM
it might still be out of balance but the increased pressure has moved the resonance to a higher frequency.
probably doesnt matter but its something to be picky about if you want
lizardspeed is offline
post #9 of 20 (permalink) Old 02-17-2006, 05:55 PM Thread Starter
toddlamp's Avatar
Actually, it's back again, and it seems like it's worse. I am going to check my tire pressure again, but I am definitely going to bring it up with the serice center.
toddlamp is offline
post #10 of 20 (permalink) Old 03-28-2006, 07:29 AM
Jsalinger
Guest
Posts: n/a
Same problem
I had the same problem on a my new 2006 X this weekend. At about 74-75, terrible vibration in the steering wheel.
I will check the tire pressure, and if not it's going back to the dealer.
I have several other problems they also need to fix... my bad Subaru luck continues.
post #11 of 20 (permalink) Old 03-28-2006, 08:28 AM Thread Starter
toddlamp's Avatar
When I took my XT in for its first oil change I brought it up. They said that they balenced the tires and the vibration is much much less, although it does give me some trouble now closer to 95 mph. But since I don't go over 80mph all that much I have let it slide. Let me know what they say about it. It almost feels like it's not at the tires anymore but something closer to the transmission.
toddlamp is offline
post #12 of 20 (permalink) Old 03-28-2006, 09:06 AM
scarred from battle
blitzoid's Avatar
It's probably still a balance issue. Vehicle harmonics are really tricky that way.
Bear in mind, most tire balacning machines balance at speeds around 40mph. The fancy ones (Hunter GSP series) balance using a "road force" system, and at higher speeds, but balancing a tire at 95mph requires a degree of sensitivity that's rare. Since you're not supposed to be driving that fast at all anyways, you're going to have a hard time convincing the dealer to re-do everything.
If the problem comes back at more reasonable speeds, then i'd be concerned.
Fmr 98L auto. I ride the subway now.
blitzoid is offline
post #13 of 20 (permalink) Old 03-28-2006, 10:58 AM Thread Starter
toddlamp's Avatar
That's exactly what I was going to do.
Originally I had a very bad vibration between 70mph and 75mph. It turned out that the tire pressure was in consistant between wheels and at a low 24psi (straight from dealer). After adjusting pressure it went away for a while but then came back. Took it in to the dealer who balenced the wheels. Seems to be ok other than the high speed vibration.
toddlamp is offline
post #14 of 20 (permalink) Old 03-28-2006, 11:12 AM
scarred from battle
blitzoid's Avatar
one other thing to consider - the air forces in play at 95mph are drastically different than those at 50, 60, 70, or even 80. Minor aerodynamic issues get magnified greatly, etc.
blitzoid is offline
post #15 of 20 (permalink) Old 03-28-2006, 12:32 PM
Ze flying Russian
Aleksey's Avatar
Car Model: STI
Most likely one or more tires is/are out of balance. I had this problem numerous times before and always that was the issue. Btw, I recently changed tires and made sure the tires are perfectly balanced and the car is dead solid even at triple digit speed. (knocking on wood :) ).
Just remembered, one time it was the brake rotors ... when they are getting older it seems that they are slighly deforming due to heat and cause vibration at higher speed, but this is not your case as the car is new.
And another possible candidate would be ... some chunk of dry mud stuck to the wheel .. this will vibrate your car very much! Make sure the wheels are clean and nothing stuck to them
16G powered 04 FXT 5MT-Sold
07 Impreza STI-Current
Aleksey is offline
