Shake during cornering - Subaru Forester Owners Forum
post #1 of 5 (permalink) Old 12-15-2009, 10:17 PM Thread Starter
Smooshed FOTY 2011
Blue Fox's Avatar
Car Model: Lifted 2.5 XT
Transmission: 5-Speed MT
Alright, I know that I may need to replace stuff, which is fine......just sold stock so I'm going to invest a little into the Foz. The issue I'm having (and it's getting progressively worse as the weeks wear on) is shaking/rattling during cornering.
Off-road: The front end rattles a bit and sounds like something is in either the suspension or steering...and the rattle can be felt in the steering wheel. When on-road, turning through a corner with rough pavement also give a similar feedback through the steering wheel.
On-road: If I corner somewhat aggressively on-road, I get a very unsatisfactory "feel" in the steering wheel like a grinding or rattling feel. If I corner VERY hard (to the point where the tires squeal), the rattle becomes very audible and the steering wheel shakes a bit more.
Also, I've noticed that when driving straight in the city and going over little bumps here and there, I get an awkward feeling in the steering wheel like it slightly tugs and then lets go and it'll do this consistently and has been getting worse over the past couple of weeks as well.
And to add, while the feedback and rattling has been getting worse, so has a certain "noise" I get when going in reverse. If I place the car in reverse and let off the gas, I get a slight feedback in the steering wheel and an audible moaning/humming noise. This has been getting worse at the same rate.
I know this is a lot of different symptoms, but since they've all increased steadily together, I'm thinking it's all related to a single problem. The only thing I can think it could be would be either....
Motor Mounts, steering rack bushings (or both) and possibly the struts as they now creak when I go over bumps. I guess the smart thing to do (since I already have the steering rack bushings) is to do that and go from there. Just seeing if anyone else has had any similar experiences and what their fix was.
Thanks in advance.
2004 XT - RIP
2005 XT - 5MT - 2" LIFT
Blue Fox is offline
post #2 of 5 (permalink) Old 12-16-2009, 06:47 AM
funkymonkey1002's Avatar
Car Model: 2.5 XT
Wheelbearing. Jack the car up and see if theres any play in the wheels (might have to unbolt the calipers, as they sometimes keep the rotors from letting the hub move within the knuckles) This is exactly how my car felt when the front wheel bearing was completely shot. Do you get vibrations mostly when turning in one particular direction (possibly worst on long sweeping corners)?
It could also be balljoint, front tophats, steering rack bushings, tierod ends, front/rear bushings on the front control arms etc.
funkymonkey1002 is offline
post #3 of 5 (permalink) Old 12-16-2009, 08:35 PM Thread Starter
Smooshed FOTY 2011
Blue Fox's Avatar
Thanks. I replaced the tophats on the front right before my engine went back in May, and that didn't help when it was only a slight issue, but now it's becoming more pronounced.
I'll jack the car up later this week and pull the wheels and calipers to check the bearings. As for the rest of the stuff.....I'll just take it to a trusted suspension shop to take a look at and have them tell me what's wrong with it.
2004 XT - RIP
Blue Fox is offline
post #4 of 5 (permalink) Old 02-04-2011, 11:35 PM Thread Starter
Smooshed FOTY 2011
Blue Fox's Avatar
PROBLEM FOUND
Actually, it was long ago, but I decided to update this thread. The whole issue was the tie-rod ends. You had to really get under there and shake them hard, but it was indeed them. No more front end vibration during cornering.
2004 XT - RIP
Blue Fox is offline
post #5 of 5 (permalink) Old 01-05-2015, 10:20 AM
benjamino's Avatar
Car Model: 2.5 XTEn
Thanks for posting the cause. I have the exact same symptoms and have replaced drop links, sway bar bushes and now a lower ball joint in pursuit of it! I will try the tie rod ends next. Did you do both? I can easily rotate/twist mine but can't actually feel any real play.
benjamino is offline
