Old 09-08-2008, 12:34 AM   #1 (permalink)
Allistair is on a distinguished road
Default Rear Hum
Hi all
I am interested in buying a forester but before I do I need help. The one i have seen and test driven has a serious hum from the back. Could this be a wheel bearing or something to do with the all wheel drive system? Help please
Allistair is offline   Reply With Quote
Old 09-08-2008, 01:48 PM   #2 (permalink)
Listen to hear if the humming changes in pitch when you shift the load from one side to the other when turning.
'08 XT LTD/MT
Old 09-08-2008, 01:56 PM   #3 (permalink)
mdg
mdg's Avatar
mdg is on a distinguished road
I'd say its the bearings.
Then again, some all season and off road tyres hum.
Red on black, black wheels and fat tyres.
mdg is offline   Reply With Quote
Old 09-08-2008, 03:43 PM   #4 (permalink)
flstffxe's Avatar
flstffxe is on a distinguished road
if it is some thing that you are concerned about agree to have a independent shop look at it.
His 08 Fozzy Prem 5mt
Hers 08 Fozzy base auto
Old 09-11-2008, 06:34 AM   #5 (permalink)
billshoff's Avatar
billshoff is on a distinguished road
Default bearings
I just had a rear bearing replaced 2 days ago on an '01 Forester.....$273 at an independent shop.
No Subi left behind. Adopt one today!
billshoff is offline   Reply With Quote
Old 09-12-2008, 04:52 PM   #6 (permalink)
motoretro is on a distinguished road
My 06 Forester w/ 49K also had a hum in the rear....It was diagnosed with a failing Pinion gear bearing yesterday. $800.00 to fix by Ind. shop
Motoretro
motoretro is offline   Reply With Quote
Old 09-12-2008, 05:57 PM   #7 (permalink)
Tau137's Avatar
Tau137 is on a distinguished road
Motoretro
Cheaper to get full diff from a junkyard.
Old 09-12-2008, 08:00 PM   #8 (permalink)
Motoretro
No warranty?
'08 XT LTD/MT
Old 09-12-2008, 09:47 PM   #9 (permalink)
Gallery: 8
That's a bargain!
-Silke
04 FXT PP PSM ~ "Subed"
98 Forester S ~ "Slynki"
92 SVX LS-L ~ x2
Old 09-13-2008, 05:47 AM   #10 (permalink)
Originally Posted by The Black Box View Post
No warranty?
We'll find out Thursday, I have an appointment then to inspect the damage...........I'm a bit miffed to see this happen at such low mileage. Never towed or off a dirt road. Something i've noticed.....The bottom of differential is very hot after 20 minutes of driving on cold fluid. Spoke to my son who has a 03 WRX and he has the same condition. Is this due to the proximty to exhaust or do these just run hot? This can't be good for the fluid, all .8 of a quart of it.
Motoretro
Old 09-28-2008, 07:14 PM   #11 (permalink)
Upon inspection, Subie dealer said right side rear wheel bearing was bad, Replaced this one and noise was reduced 70% although have another appointment for this Thursday.....Left side is whining now! At least it's getting quieter.
Motoretro
Old 10-04-2008, 03:42 PM   #12 (permalink)
Well the left side rear wheel bearing was bad too! that's (2) wheel bearings in less than 3 weeks. At least it was under waranty(50K) still. With new Michelin Primacys, all is good & quiet.
So much for the local wrench and his $800.00 Pinion bearing failing.
Motoretro
Old 10-05-2008, 03:04 PM   #13 (permalink)
FXTINTX is on a distinguished road
I just had both rear wheel bearings replaced at the same time after hearing them hum for over 10,000 miles....
Bought all brand new Subaru parts: Bearings, Seals, etc. and had them professionally installed
(because I didn't have time to do it myself honestly)
now, only a month later, one or both have FAILED !!!!!
DAMMMMMMITTTT!!!!!
It really pisses me off when brand new parts fail like this....
I am getting it warrantied and swapped out for the parts cost by my dealership where I bought the parts..
(SUBARU OF DALLAS- MIKE, KEITH, CAREY- THE BEST PARTS GUYS I HAVE EVER HAD BTW!!!!! - (214)526-5555 -TELL 'em RYNO Sent ya!!!)
My car has 125,000 miles on it....
GOOD LUCK!
RYNO
FXTINTX is offline   Reply With Quote
Old 10-06-2008, 11:46 AM   #14 (permalink)
PaulieD is on a distinguished road
Is this a common problem for Forester's? I have a '98 that also has a humming noise from the rear. I replaced the tires, but that didn't fix the noise. The noise doesn't seem to be any louder on one side or the other, so maybe both wheel bearings are bad? BTW, the car has about 145,000 miles.
PaulieD is offline   Reply With Quote
Old 10-08-2008, 10:13 AM   #15 (permalink)
Not sure if it's a problem or not, perhaps the higher mileage owners can answer this. I was very surprise to have 2 go out at 50K and considering the light use this vehicle gets, something appears amiss. Is it a design, installation, or lack of intial lubrication problem??
Motoretro
