Old 11-27-2007, 08:08 AM   #1 (permalink)
Default Rattle noise in the rear
Hello everyone, I just bought my first Subaru on Halloween, a 08 Forester Sports XT, and since I first drove the car it has had a rattle in the back that I cannot figure out what it is. I know it is not the middle seat belt or the rear license plate, and I am wondering if anyone else has had this problem and knows what it was.
Thanks,
Brandon
08SportsXT is offline   Reply With Quote
Old 11-27-2007, 08:13 AM   #2 (permalink)
Smash81's Avatar
i know i've got a rattle in my '03, i think it's the antenna in the drivers side rear quarter window. atleast i think that's the antenna... if you have the same setup maybe take a look at that.
Smash81 is offline   Reply With Quote
Old 11-27-2007, 08:26 AM   #3 (permalink)
Smooth's Avatar
Feedback Score: 9 reviews
I've noticed that when I have the cargo cover (the pullout one) stowed under the floor that it rattles quite a bit.
'07 FSXT WRB ¤ protuned VF39
Smooth is offline   Reply With Quote
Old 11-27-2007, 08:38 AM   #4 (permalink)
The noise does sound like it's coming from the right rear panel, so you may be right about it being something with the antenna.
Old 11-27-2007, 08:48 AM   #5 (permalink)
FXTRunner1's Avatar
Gallery: 1
I had an annoying rattle like that and it took me awhile to figure it out. For me it was my striker plate that needed adjustment. The back door latches on to it. You can tell if its this by puting some electrical tape around the part the latch hits. If the tape fixes it then the fix is done by loosening the two bolts on the striker plate and move it in towards the interior.
05 FXT MT VF39'd
FXTRunner1 is offline   Reply With Quote
Old 11-27-2007, 10:00 AM   #6 (permalink)
sparrow75's Avatar
Default Rear Rattle
I have an 07XT and have been dealing with a rattle/vibration from the driver side rear cargo areas. I would hear it while driving over gravel roads. I also heard a similar rattle/vibration from base comming from my music. At first I didn't think the two sounds were related, but seems they are. Here is what i figured out:
1) the metal plate around the speaker in the cargo area is vibrating, causing the sound described above, both during music and driving on rough roads
2) So I lifted the cargo lid (to where the storage and spare tire are located) and tucked a towel up behind the carpted wall so the towel was tightly pushed between the metal speaker plate and wall. This held the speaker plate tightly so it does not vibrate.
All problems seem to be fixed, i haven't hear the noise since. Now, i just need to figure out a more perminent fix, maybe small piece of foam??
Hope this helps.
sparrow75 is offline   Reply With Quote
Old 11-27-2007, 10:58 AM   #7 (permalink)
Arthemys's Avatar
Gallery: 5
Originally Posted by FXTRunner1 View Post
I had an annoying rattle like that and it took me awhile to figure it out. For me it was my striker plate that needed adjustment. The back door latches on to it. You can tell if its this by putting some electrical tape around the part the latch hits. If the tape fixes it then the fix is done by loosening the two bolts on the striker plate and move it in towards the interior.
The rattle you're referring to, is that a squeak by chance? My 00 has this bizarre squeaking that seems to vanish temporarily when I put in foam weather stripping. The weather stripping got crimped and the squeaking has returned. By chance would moving the striker plate solve this? I do know that the little springy pad things on either side are no longer doing their job...
It's been cold as crap lately so I haven't had the time to fart around and figure out a decent solution by trial and error.
Arthemys is offline   Reply With Quote
Old 01-10-2008, 05:18 PM   #8 (permalink)
Boxer 4th's Avatar
Default Check this
I had a mysterious rattle in the back of my '07 that came up suddenly. After got over the initial annoyance, I realized that the cargo cover (the retractable "shade" thing) was retracted - but not quite all the way. The plastic handle was just dangling a bit too much and was rattling against the housing. I usually drive around in the covered up mode, otherwise it probably wouldn't have caught my attention.
Also Solved: ...a rattle I SWORE was in the front passenger door. My wife (a frequent passenger) insisted it was coming from inside the center console. She was right! It turned out to be the 2 loopy plastic retractable cupholder rings that live in the backside of the console. They occasionally jiggle around when they're folded up inside.
That's two mystery rattles down. Now there's a little one coming from the right side of the dash/windshield pillar area. I'm thinking maybe the pollen filter. Isn't that someplace in that vicinity?
Boxer 4th is offline   Reply With Quote
Old 01-13-2008, 01:20 PM   #9 (permalink)
FXTRunner1's Avatar
Gallery: 1
Yes, the two bolts on either side will allow it to slide a bit. Use a marker or pencil so you dont loose the original position. It make for a good reference point. Then loosen the bolts and move the catch inwards a small bit. Mine is a bit tight in that it takes a good slam for it to catch. But now it doesn't rattle...
05 FXT MT VF39'd
Old 01-14-2008, 10:08 AM   #10 (permalink)
JM1
JM1's Avatar
Wrap the post that the rear seats attach to when in the upright position. I put a little bit of black electrical tape on each side and it fixed the "pop" I would get each time I started driving the car after it had sat for a little while.
MY05 FXT MT Crystal Gray, Stage 1, ghetto wheels
JM1 is offline   Reply With Quote
Old 01-14-2008, 05:05 PM   #11 (permalink)
geargrinder's Avatar
I have this same noise sort of. Mine is kind of a buzzing sound from the left rear. I removed everything from the back, and it still persists. I am starting to think it has something to do with the speaker wiring witch is causing some kind of interference.
geargrinder is offline   Reply With Quote
Old 01-14-2008, 06:04 PM   #12 (permalink)
Default Rattle(s) in rear of '08 Sport XT
My '08 XT was purchased early in Sep '07 and it too came with a rattle in the right-rear of the interior (at no extra charge). I guessed that the rattle was coming from the passenger-side end of the privacy cover bar anchor point. To test my theory, I looped a bungie cord over the bar and secured both ends to the metal cargo loop directly under the bar. That seemed to cure that rattle. The other noise I get is from the cargo floor lid and/or parcel tray going "blam" whenever I go over anything larger than a small bump. I would have thought that Subaru would have worked out these details in a 10+ year old platform. This is the first new car I've purchased that I had to use a bungie cord to keep something from rattling.
SailorDon is offline   Reply With Quote
Old 01-15-2008, 11:47 AM   #13 (permalink)
Skotia's Avatar
I am having a similar rattle to what you described. Sounded like it was from the center console which prompted me to remove all the panels and re tighten them. Rattle still there. Now I am guessing that it is coming from the Passenger side front door panel. Any suggestions?
Skotia is offline   Reply With Quote
Old 09-05-2008, 07:00 AM   #14 (permalink)
PogiOne's Avatar
Gallery: 2
Had this annoying rattle too. Went crazy and replaced the rear upper strut mounts and sway bar end links too. But it turns out to be only the latch mechanism inside rear seat backs.
Try folding down the seat backs and go for a spin around the block.
04 Forester XT * 07 Impreza Sport Wagon
PogiOne is offline   Reply With Quote
Old 09-05-2008, 08:40 AM   #15 (permalink)
Groovologist
guroove's Avatar
There's an easy cure to all these problems. Aftermarket exhaust + open windows!
guroove is offline   Reply With Quote
