('03-'05) P0301 - Cylinder 1 Misfire - Subaru Forester Owners Forum
 1Likes
post #1 of 16 (permalink) Old 05-26-2011, 05:35 AM Thread Starter
dantheman's Avatar
Car Model: 2.5 XT
Unhappy P0301 - Cylinder 1 Misfire
Hi everyone,
Turned on my car the other day and threw a CEL and a flashing cruise. When I pulled the code it read P0301 - Cylinder 1 Misfire. I've tried trouble shooting it by switching out Cylinder 1's spark plugs with Cylinder 3's and also the coil-packs and then clearing the code. However, I am still getting the same P0301 code for cylinder 1. Hoping that my engine isn't toast I'm going to continue to trouble shoot the problem. I'm just trying to find out if there is anything I'm missing.
Tomorrow:
I will be conducting a compression test on the Cylinder.
Also if my shop can do a flow test on my fuel injectors I'll be doing that.
Please let me know if there is anything else I should check, possibly the intake manifold could be leaking in that area? I don't really know and would be most grateful for any input.
thanks
dantheman is offline
post #2 of 16 (permalink) Old 05-26-2011, 07:46 AM
Since the code has returned, take a look at the freeze frame data, specifically, the short term/long term fuel trim numbers (Both banks) as well as the rpm & load numbers.
If the STFT and LTFT numbers are OK (for both cylinder banks, but especially bank 1), then the problem is less likely to be ignition related and probably air/fuel or compression. LTFT numbers should be within +/- 10 to 15%.
If outside of this range, then the PCM is correcting for an overly rich/lean condition -- what you're looking for here is an indication if the misfire is being caused by a rich or lean problem which have different troubleshooting approaches. E.g., excessively rich could be a bad fuel pressure regulator, leaky fuel injector, etc. Excessively lean could be an intake leak, etc.
A mechanical condition may exist (e.g., burnt exhaust valve), so in addition to the compression test, do a leak down test on the cylinder. If your shop has an oscilloscope, they can do a relative compression test. Good luck.
Regards,
paul...
10 Forester X Prem AT, 07 Boxster S, 03 MB E320
paulv is offline
post #3 of 16 (permalink) Old 05-27-2011, 05:48 AM Thread Starter
dantheman's Avatar
Car Model: 2.5 XT
So today I continued my trouble shooting. Only having a short amount of time I was just going to do the fuel injectors. I switched out cylinder 1s injector with cylinder 2s and no change at. I also listened to all cylinders with a oscilloscope and heard nothing out of the ordinary. Then I decided to go to the exhaust and listen to it, I could heard the misfire every few seconds. I put a dollar up to the exhaust and watched it flutter then the oh no face happened. The dollars bill pulled back inside the exhaust and held there for almost a full second. Tomorrow I will be doing the compression test on cylinder 1 and we'll see what happens from there. God I hope I don't have to pull this block apart.
post #4 of 16 (permalink) Old 05-27-2011, 07:26 AM Thread Starter
dantheman's Avatar
Car Model: 2.5 XT
Regards,
paul...
Thanks for all the info, I'll post up how everything turns out.
post #5 of 16 (permalink) Old 07-01-2011, 12:04 PM
Transmission: Hand
engine misfire
Looks like I have the same problem.
Did you find anything wrong and if so what?
pelgrim is offline
post #6 of 16 (permalink) Old 07-03-2011, 08:42 AM
Johndros's Avatar
i just had the same thing happen but it was cylinder 3... when your looking down at the block from the bumper which one is cylinder 3. thanks guys.
Johndros is offline
post #7 of 16 (permalink) Old 07-03-2011, 10:15 AM
Feedback Score: 41 reviews
Firing order: 1 - 3 - 2 - 4
--------#3----------------------#4---------
--------#1----------------------#2---------
---passenger side ----------driver's side-----
------------ front of vehicle ----------------
sls2121 likes this.
2.5x_sleeper is offline
post #8 of 16 (permalink) Old 07-03-2011, 10:32 AM
Johndros's Avatar
thanks so much. that was actually a perfect way to put it hah.
Johndros is offline
post #9 of 16 (permalink) Old 07-06-2011, 08:15 AM
INSubbie's Avatar
Transmission: 5 Speed Manual
My '06 XT started throwing the same code last week. I reset it once and it came back today. It seems to throw the code just after the vehicle is started. I have 115k miles, had the timing belt replaced 10k miles ago. I hope teres nothing seriously wrong. I'm very anxious what you find out.
'06 XT w/ 5MT
INSubbie is offline
post #10 of 16 (permalink) Old 07-06-2011, 08:55 AM
2point5awd's Avatar
Is there any other signs besides the CEL - like jittery idling or hiccups in acceleration under load?
2point5awd is offline
post #11 of 16 (permalink) Old 07-06-2011, 10:21 AM Thread Starter
dantheman's Avatar
Car Model: 2.5 XT
Wow forgot I had this thread going. With mine (Which is still misfiring) I have a rough idle and a little hiccup under hard acceleration. I'll finding what caused the problem after I pull the engine on 18 July. Anyone else find anything.
post #12 of 16 (permalink) Old 07-06-2011, 10:58 AM
Tussen's Avatar
Feedback Score: 19 reviews
Is the problem constant or only if certain conditions have been met?
I had a misfire and rough idle that would only occur after starting the car when the engine was warm from driving. Turned out to be the hot start fuel correction factor in my tune.
06 XTL 4EAT 2.5XT-R Yimi Sport Tuned...For Sale
Tussen is offline
post #13 of 16 (permalink) Old 07-06-2011, 11:14 AM
2point5awd's Avatar
My 08 XT had both rough idle and hiccups under load at 40k miles (car is stock). The hiccups under load turned out to be the spark plugs, which were replaced. The rough idle (with CELs) is still being worked on.
I am going to post a thread of what was done once I get it back and its all working (crossing fingers).
post #14 of 16 (permalink) Old 07-06-2011, 06:10 PM
INSubbie's Avatar
Mine hesitates ever so slightly, but nothing worse than normal. It seems to be occurring when it is at idle.
I had an issue after I had my timing belt replaced that the dealer found NON Subaru spark plugs (Std. Champions of all sorts) instead of the platinum tipped that are supposed to be in our turbo's that my previous dealer installed. This caused a Misfire on Cylinder 3, but the correct plugs fixed that. That was about 10K miles ago and now I have problems with Cylinder 1.
'06 XT w/ 5MT
INSubbie is offline
post #15 of 16 (permalink) Old 09-25-2012, 12:05 PM
Car Model: Forester 2.5 XT
Transmission: manuell
I have the same problem my self on my 2.5xt, but I have no CEL. I have a rough idle and a little "hiccup" under hard acceleration. I also logged miss fire, most(max 23) on cylinder one but a few on cylinder two and four(max 6-9)
anyone who has found any solution?
Petter is offline
