('03-'05) P0301 05 Forester XT - Subaru Forester Owners Forum
post #1 of 17 (permalink) Old 01-22-2012, 10:31 AM Thread Starter
Went out to dinner last night, and went home with no issues. 1 hour after we got home I started the car to go out and I got a blinking cruise light and sold CEL, went to pepboys today to get it scanned but once i pulled into the service garage and let it idle for 1 minute the code disappeared, but they still scanned it and it stored a P0301 Misfire cyl. 1 code. Since the code went away by itself should I still check the plugs and the injectors or do a compression check on the engine? or should i wait for it to come by before I do anything?
ej205gdb is offline
post #2 of 17 (permalink) Old 01-22-2012, 01:47 PM Thread Starter
so i just tooked it back out for another drive and same error code p0301 came back, so i guess it's time to change out the spark plugs or coilpacks?
ej205gdb is offline
post #3 of 17 (permalink) Old 01-24-2012, 12:05 PM Thread Starter
just changed out the spark plugs, they had normal wear and tear but no fouling or anything crazy. no code is back yet and the car has been driven for ~20 miles. I am however having slightly rough idle so we did compression check on the cylinders and got a 145-148 on all cylinders. what should i check next to try to fix the rough idle? injectors? coilpack?
ej205gdb is offline
post #4 of 17 (permalink) Old 02-02-2012, 09:10 AM Thread Starter
well the light just came back on last night after driving for 500miles without coming on, same misfire cylinder 1 P0301 code again! going to swap the coilpack from 1 to 3 and see if the code goes to cylinder 3. will report back but is there anything else i should check as well while I'm in there?
ej205gdb is offline
post #5 of 17 (permalink) Old 02-02-2012, 12:32 PM Thread Starter
also, the AVCS and the Turbo Screen has been removed already.
ej205gdb is offline
post #6 of 17 (permalink) Old 02-05-2012, 08:23 AM
Transmission: 5-speed
Any update on this? I just got this code and wanted to know what you ran into before I start working on it.
diddlebop is offline
post #7 of 17 (permalink) Old 02-05-2012, 12:45 PM Thread Starter
i swapped the coil pack from cyl 1 to cyl 3, so far no cel yet but still slightly rough idle. my cel usually comes back in 600 miles so i'll see when it comes back, so far i only drove 200 miles on it.
ej205gdb is offline
post #8 of 17 (permalink) Old 02-05-2012, 07:16 PM
funkymonkey1002's Avatar
Car Model: 2.5 XT
Could be the injectors if it's not an issue with ignition. Otherwise it could potentially be something with the valvetrain.
funkymonkey1002 is offline
post #9 of 17 (permalink) Old 02-09-2012, 01:03 PM
turbolishous's Avatar
Car Model: Forester 2.5XT
I had the same problem, it was a coil. Since the coils are interchangeable swap them from side to side to confirm that the miss-fire moves also. The miss-fire monitors on these are sensitive. I replaced my coil and no problems since. The Subie techs confirmed this is a common issue. Good luck!
turbolishous is offline
post #10 of 17 (permalink) Old 02-10-2012, 02:21 PM
Car Year: 03
What about spark plug wires??
Sent from my DROID3 using Tapatalk
jsahara24 is offline
post #11 of 17 (permalink) Old 02-15-2012, 11:40 PM Thread Starter
800 miles later the code popped back up, still the P0301 cyl 1 misfire, going to swap injectors over to see if that fixes it or moves the code to a different cylinder.
ej205gdb is offline
post #12 of 17 (permalink) Old 03-02-2012, 10:14 AM Thread Starter
after swapping the injector over from cyl1 to cyl3 2 weeks ago no code yet, and much smoother idle. hopefully that did the trick but will keep everybody updated if the code does come back.
ej205gdb is offline
post #13 of 17 (permalink) Old 03-05-2012, 06:29 PM
Car Model: FXT Limited
Im in! My 04 fxt is doing the same thing except it is finding a misfire on cylinder 4. Tomorrow will be plugs and wires.. Then ill do coil packs, then injectors. Ill keep updates as well!
wrxtofxt is offline
post #14 of 17 (permalink) Old 03-06-2012, 05:53 AM
Car Model: forester xt
Transmission: manual
haha mine is a misfire on cyl 3. Must be the weather?
Everlastingboost is offline
post #15 of 17 (permalink) Old 03-06-2012, 05:06 PM
Yeah it sucks! I dont have the patience to deal with it. I just realized I said I was going to put plug wires in it (Good luck with that!). Anyways I didnt get a chance to do anything on it today but hopefully will get around to it soon! Ill update when I do!
wrxtofxt is offline
