Old 11-16-2008, 06:50 PM   #1 (permalink)
Man U fan!!!
subieoutlaw's Avatar
subieoutlaw is on a distinguished road
Default Oil change part numbers
Hi.
Does someone have the part numbers for:
Crush washer (to be replaced when oil drain plug is removed)
Fumoto valve (a very very good one)
2009 Forester Turbo
Canadian Model
Many thanks
Hey Numbnut, the left lane is for passing!
09 Silver FXT: Primitive Armor & my own kickass mudflaps
subieoutlaw is online now   Reply With Quote
Old 11-16-2008, 06:59 PM   #2 (permalink)
Real Lyte's Avatar
Real Lyte is on a distinguished road
For the oil valve, f-105 and f-105N (one with nipple).
SF '99L A/T (Mine) &
'95LS Legacy A/T (hers)
Real Lyte is offline   Reply With Quote
Old 11-16-2008, 07:15 PM   #3 (permalink)
Man U fan!!!
Super. That answers both.
Now, how many litres of oil does it take? Does this number include pre-filling the filter?
An service sheet on this would answer my prayers.
Old 11-16-2008, 07:54 PM   #4 (permalink)
scubadoober's Avatar
scubadoober is on a distinguished road
It's an 09 so you have your owners manual right? 4.2 qt.
scubadoober is offline   Reply With Quote
Old 11-23-2008, 06:57 PM   #5 (permalink)
Grump is on a distinguished road
If you don't do the Fumoto valve, the factory crush washer is
11126AA000.
2006 2.5X Premium w/AT
Grump is offline   Reply With Quote
Old 11-24-2008, 06:50 AM   #6 (permalink)
Man U fan!!!
Default ehow, is this video correct?
what do you think?
How to Change Your Motor Oil | eHow.com
Old 11-24-2008, 07:25 AM   #7 (permalink)
Real Lyte's Avatar
Only problem with warming engine up especially the first time you do it is that when you pull the plug you get really hot oil all over your hands. Also remember is shoots out sideways and doesn't go directly down.
Old 11-24-2008, 07:32 AM   #8 (permalink)
Hahaha, "Be careful when removing the old oil filter, it is full of oil" classic. Yep that's pretty much how to change your oil, and whatever you do don't drain the trans and double fill the engine oil.
Old 11-24-2008, 07:44 AM   #9 (permalink)
Man U fan!!!
If I do it while the engine is cold will I get all the old stuff out? Or should I just run the car for a minute and pray?
Old 11-24-2008, 07:50 AM   #10 (permalink)
Gallery: 8
Everything you need to know: Oil Change - ScoobyMods
-Silke
04 FXT PP PSM ~ "Subed"
98 Forester S ~ "Slynki"
92 SVX LS-L ~ x2
Old 11-24-2008, 08:26 AM   #11 (permalink)
Man U fan!!!
All peaty's info is for an older Foz. Does anyone know if there would be changes for a 2009 FXT?
Old 11-24-2008, 08:31 AM   #12 (permalink)
Gallery: 8
Check your owners manual for the fluid capacity. I don't think it has changed, it should still be 4.8 quarts with filter replacement. The 09 still uses the same block as previous years and the oil change procedure pretty much applies to all Subies of all years. Same crush washer, same Fumoto valve.
-Silke
92 SVX LS-L ~ x2
Old 11-24-2008, 08:33 AM   #13 (permalink)
Man U fan!!!
Any fears with fumoto valve? I do off road in my Subie.
Old 11-24-2008, 08:36 AM   #14 (permalink)
Gallery: 8
If you have a skidplate you should be fine.
-Silke
92 SVX LS-L ~ x2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
