OBD Code p0483 - Subaru Forester Owners Forum
post #1 of 3 (permalink) Old 10-07-2006, 08:00 AM
hmeetis
Guest
Posts: n/a
OBD Code p0483
I have a 1998 subaru forrester and i happen to have a vag-com (for my VW) that reads all generic obd codes. I am getting code p0483 and i can not find info about said code on any sights. I have reset the code once allready to see if it would just disapear but apparently its a accual problem.
Please email me hmeetis@yahoo.com with any information. I will be surfing around to try finding more.
post #2 of 3 (permalink) Old 10-07-2006, 08:51 AM
ferret's Avatar
Car Model: Impreza Ltd
Cooling fan FUNCTIONALITY failure.
1st ensure the fans, both of them are coming on when the vehicle gets hot. This code is set after the ECU triggers the fans to come on, the temp as read by the engine temp sensor has NOT decreased in the 'specified' amount of time.
Fans not running, suspect fans, relays, fuses to the fans, ECU
Fans running, ensure there are no obstructions before or after the radiator. Also the radiator may be clogged. Or if vehicle is not overheating it can be a defective engine temp sensor.
Hope this information helps you find your problem.....remember the 98 has the N/A DOHC which is also prone to head gasket failure, so it you ever see coolant spewing out of your reservoir after a long run on the highway, this is one symptom of a failed head gasket.
ferret is offline
post #3 of 3 (permalink) Old 10-07-2006, 12:02 PM
The Modfather
Peaty's Avatar
Transmission: 6 Speed Manual
Feedback Score: 10 reviews
some more info
Peaty
Peaty is offline
