Old 10-08-2008, 05:46 AM   #1 (permalink)
Chris C is on a distinguished road
Default No "chirp" after maintenance
Hi--I have a 2004 Forester that has keyless remote entry. I've grown to like the fact that it chirps when I lock or unlock it remotely.
This week, I took it for its 60,000 tune-up. When I got home I realized the car no longer chirped when I used remote. So I looked up instructions and saw that I'm supposed to press 2 buttons (unlock & lock) simultaneously for 2 seconds after unlocking car using remote in order to activate the chirp.
The lights are supposed to flash when you do this, which they did. But it didn't chirp. The problem is definitely with the car, not the remote, because we have a second remote for the car and that didn't work either. We called the garage that did our maintenance, and of course, they say they didn't touch anything that should have affected it.
I am assuming they disconnected something accidentally. Does anyone know where--specifically-- the origin of the chirp is located internally/within the car and how I can diagnose or possibly fix it myself?
Chris C is offline   Reply With Quote
Old 10-08-2008, 07:21 AM   #2 (permalink)
The Sub kit guy
sea-scooby's Avatar
How many times did you do the code? The 03-05 keyless system has 3 modes, and each time you do it you get a different mode. On my 05 I can do flash/chirp, flash/no chirp, or no flash/no chirp.
05 Forester X A/T (hers)
My Journal page
Old 10-08-2008, 07:40 AM   #3 (permalink)
Thanks for your reply. I haven't tried doing this consecutively, but I have tried doing it at least 3 times. So I would think that each time I did the code, the mode would have changed (assuming I have 3 modes as your '05 does, but the manual only mentions 2). I can try doing doing the code consecutively a few times in a row on the off chance that will work, but I'm doubtful... I really think they disconnected the chirp mechanism (wherever it is) in my car.
Old 10-08-2008, 07:43 AM   #4 (permalink)
Dan
Dan's Avatar
Dan will become famous soon enough
I wonder if they accidentally unplugged the little piezo dealio that makes the chirp... I'll go outside to have a look for it.
SHIFT_to_Subaru
'04 XT, 5spd
Dan is offline   Reply With Quote
Old 10-08-2008, 08:02 AM   #5 (permalink)
ferret's Avatar
ferret has disabled reputation
It's Front and center behind the grill. Just look in the center, mounted to the front of the upright support. Look over on Scooby Mods, I'm pretty certain Peaty even has a picture of it.
04XSPP(7 Subaru's since 1978 All 5 sp)ILuvSubaru's
Old 10-08-2008, 08:07 AM   #6 (permalink)
Dan
Dan's Avatar
Yeah, that's what I found, too. The cable goes down in front of the grille and disappears rearward. I was too lazy to remove the plastic motor cover to follow it to the connector.
SHIFT_to_Subaru
'04 XT, 5spd
Old 10-08-2008, 09:58 AM   #7 (permalink)
Thanks to both of you! I'll let you know how I make out.
