Old 10-08-2008, 05:53 AM   #1 (permalink)
BLUE WASABI
(#2 Info Provider)
sirwilliam's Avatar
Default Mystery muffled clanging noise
Well, this noise made its first guest appearance this past weekend.
It seemed to originate from the rear passenger side in the cargo area but hard to pinpoint its location due to acoustics in the rear and it only materializes when I am driving at moderate speed. I then began my tedious-super-awesome brainstorming to try to deductively weed out the culprit...and I am also pretty sensitive to different acoustic sounds so I narrowed it down to somehow emanating from the retractable rear cargo cover. I was thinking maybe my overstuffed suitcase which, even on its side, at times would push up the cover from its forward mounts was responsible for possibly bending the clips so that it wasn't a tight enough fit causing rattle. I finally took the time to go outside this morning at work and try to see if I could fix it. After moving some misc. crap around in the back, I found something that resembled the noise.
^^^Culprit (I believe) was my son's Stuff n' Scuff rear seat protector w/ pocket laying sideways and banging the cargo cover beam. The protector attached perfectly with my stock seats but after installing the STi front seats, it needs to be modified to be attached...so I got lazy and threw it in the back. Hopefully, that is the problem and it is now fixed. I will verify later today. I just can't stand abnormal noises with my car. Drives me up the wall
Anyways, just thought I would share.
BLUE WASABI
Old 10-08-2008, 07:10 AM   #2 (permalink)
The Sub kit guy
sea-scooby's Avatar
Glad to see your problem was solved!
I hate it when you get an annoying noise and can not figure out where it is coming from. I thought for the longest time my clutch was squeeking real loud and the dealer replaced the spring 3 times, but it turned out to be a spring in the seat. A quick spray with lubricant and all was quiet again.
05 Forester X A/T (hers)
My Journal page
Old 10-08-2008, 07:15 AM   #3 (permalink)
BLUE WASABI
(#2 Info Provider)
sirwilliam's Avatar
Yeah, I had that same squeek on my '04 but couldn't fix it...will have to take a mental note to remember to check seat this time. I loathe squeeks and rattles.
BLUE WASABI
Old 10-08-2008, 10:04 AM   #4 (permalink)
Enjoyn the ride
stan_t's Avatar
stan_t is on a distinguished road
Around the time of strut/springs swap my car developed a clacking sound coming from the back. I suspected the struts, but refused to believe it. Funky thing was it would go away completely sometimes.. then, come back.
Ended up being the left rear seat latch. I drive around with the rear seats down alot because the dog rides back there -- so, of course, no clacking. When I'd put the seats back up -- clacking starts again. At least it's not my suspension
Stan
'07 XT 5MT, VF43 tuned by FLI
handling > power > looks
stan_t is online now   Reply With Quote
Old 10-08-2008, 10:56 AM   #5 (permalink)
BLUE WASABI
(#2 Info Provider)
sirwilliam's Avatar
Well, tested out during lunch...not the cargo cover...I don't think. I put my backup fleece blanket under my cleaning supplies that are wrapped up in a plastic grocery bag and hanging from my driver-side retractable grocery hook and also reposition the jumper cables that are sitting inside my spare's rim. After a drive everything was fine...then I removed the blanket and the noise was back Have to double check the bag again...but if that is it, the supply bag will be removed.
Bright side looker, you! Yeah, suspension is not cheap...did you fix/resolve the problem?
BLUE WASABI
Old 10-08-2008, 12:52 PM   #6 (permalink)
Enjoyn the ride
stan_t's Avatar
The problem is definitely in the left rear seat backrest release/latch mechanism. It will clunk when the backrest is up and latched in. I just unlatch the left back seat backrest and leave it in the upright position, then there's no clunk. I am not sure if I want to take the car to the dealership with this problem since my car is modified.
Drive around with the back seats folded down, see if the noise goes away -- mine does.
Stan
Old 10-08-2008, 01:45 PM   #7 (permalink)
Supporting Vendor
SubaruPartsGirl's Avatar
SubaruPartsGirl is on a distinguished road
Haha I know what you mean! If I hear a strange noise I am on a mission to seek and destroy! I don't listen to the radio very much so any little noise will drive me crazy. Hopefully you got it sorted out.
Annapolis Subaru
Toll Free: 866-509-3019
SubaruPartsGirl is offline   Reply With Quote
Old 10-08-2008, 02:43 PM   #8 (permalink)
There's really no way to adjust the striker so I just put a few winds of tape around the striker and problem fixed.
'08 XT LTD/MT
Old 10-08-2008, 02:49 PM   #9 (permalink)
dbaldock9 is on a distinguished road
Or a stick-on rubber pad near the latch, to provide tension when the seat is in the latched position.
Take Care,
David Baldock
2007 Crystal Gray Forester 2.5X 4EAT
dbaldock9 is offline   Reply With Quote
Old 10-08-2008, 02:49 PM   #10 (permalink)
Enjoyn the ride
stan_t's Avatar
Sweet, that's exactly what I was going to do. Glad I'm not the only one with this problem.
[/thread hijack]
Stan
Old 10-09-2008, 10:16 AM   #11 (permalink)
2point5awd is on a distinguished road
hum... i may have to try that. I hear something similar as well as other sounds (that let me know its a Subaru :)
I found out that mine was making noises from the back hatch where the plastic piece hits the metal of the hatch (on the inside, below the wiper). I put some puffy tape and it helped.
2point5awd is offline   Reply With Quote
Old 10-09-2008, 10:47 AM   #12 (permalink)
BLUE WASABI
(#2 Info Provider)
sirwilliam's Avatar
Well, crappola! I think it really is the cargo cover beam/bar that is rattling. There is still some stuff I can still do to test some theories...will have to bust a sherlock holmes on my car. The noise is driving me batty!
I will have to check that.
BLUE WASABI
Old 10-09-2008, 10:58 AM   #13 (permalink)
On my previous 1998 Impreza Wagon, I put several rows of adhesive backed rubber weather stripping on the "bottom" of the lift-gate, to provide upward tension against the latching mechanism. That stopped it from making random rattles.
Take Care,
David Baldock
