#16 (permalink) |
I think this problem comes from the moisture which accumulates on the cold evaporator coil during AC operation. Moisture supports growth of mold/mildew. So you want to get rid of the moisture by drying the evap coil before stopping the car after an air conditioned drive.
If you've used AC during a drive, switch the AC off a few minutes before you stop the car. Don't switch the fan off—just the AC compressor, and let the fan continue to blow air across the evaporator to dry it off. Thus when you park the car, the evap coil will be dry, or pretty dry, and there will be a lesser chance of growth on the coil. I did this with my 96 OB and never had funky smells. |
#18 (permalink) | |
Need more MODs!
2003 Pacifica Blue Pearl Metallic 2.5X 4EAT +AVO turbo kit! |
#20 (permalink) |
Musty smell can be caused by poorly draining evaporator (debris buildup) and spraying cleaner won't help. I had a blocked drain recenly on my 9$ Accord and was able to clear by elevating on jack stands and accessing the drain w/ a shop vac to pull all water (and hopefully debris) out. It's worked so far w/ good drainage. I did not have a noticeable smell thankfully.
good luck
See you down the ROW! 1999 Subaru Forester |
#21 (permalink) |
I bought a product from O'Reilly Auto Parts that is meant to deoderize the ventalation system. You spray it into the outside ventalation intake and in vents inside the vehicle. You run the blower while spraying it in and it deoderizes the vents. It has worked well for me. I get that same musty smell during the summer since my Forester sits outside and with the high humidity we have in Illinois in the summer.
PURE AIR A/C Duct Odor Purifier Last edited by IBHWRD2 : 11-16-2008 at 10:09 AM. Reason: Added link to product mentioned in post. |
