Help, I can't get the hood to open! - Subaru Forester Owners Forum
post #1 of 6 (permalink) Old 02-27-2011, 06:12 PM Thread Starter
Car Model: Forester L
Ok, I pull the inside release like normal and then hop out and pull on the hood..and nothing! The hood doesn't pop up it's usual amount, it's like it's frozen in position. What I remember about the last time I had it open is that when I dropped the hood to close, it didn't close all the way and I had to push it closed. Which probably means that I forced/bent something that shouldn't have been forced or bent.
The interior release feels like it's still connected so I don't think that I snapped the cable.
So how do I go about opening the hood without being able to pull up the hood or release the "first catch" that pulling the cable normally releases?
Ron
99 Forester L 4EAT Aspen White
09 Impreza 5dr Premium 4EAT/SS Sun Gold Opal
awd4me is offline
post #2 of 6 (permalink) Old 02-27-2011, 06:14 PM
FPT_RAIDER's Avatar
have some one pull the release and you pull up on the hood at the same time
FPT_RAIDER is offline
post #3 of 6 (permalink) Old 02-27-2011, 06:19 PM
good dog's Avatar
Car Model: XS
That's a dilemma. You could try spraying some lubricant from below or through the grille in the general vicinity of the latch. Also having a helper pull the release while you put pressure and try moving it side to side after letting the lube work in. Hopefully you have a can of lubricant that comes with those small spray straws that might get between the hood weather stripping. If you don't have something like that a flat probe of something can be pressed between the hood and frame to move the seal out of the way and get some lube to the mechanism.
Good luck and keep us posted as to the result.
2008 Forester XS 4EAT
Next TBD?
good dog is offline
post #4 of 6 (permalink) Old 02-27-2011, 06:24 PM
Naomi's Pilot's Avatar
Car Model: 2.5X Premium (5sp)
Careful driving. I had that happen to a car (non-Subaru) once and the hood suddenly flew open at 65 mpg, spider-webbing my windshield and scaring me half to death. You DON'T want that to happen.
Best thing to do, as suggested above, is to have someone pull the latch while you jimmy the hood open.
If not, force it open (get out a drill/saw if you have to) and install pins to hold it closed until you get a new latch mechanism.
You're facing a possible safety issue here, the worst kind.
Best of luck!
2011 2.5X Premium, 5MT, Obsidian Black Pearl
Naomi's Pilot is offline
post #5 of 6 (permalink) Old 02-27-2011, 06:39 PM
Car Model: XS Premium
+1 for lube. A number of us have encountered the situation where the hood won't stay all the way down or can't even go all the way down. (But fortunately mine has never gone all the way up--just up to the initial release point) A shot of PB Blaster cured it on the spot, and it's now part of my spring cleanup procedure every year.
Not quite your problem, I realize, but it sounds like they might be related.
bbottomley is offline
post #6 of 6 (permalink) Old 03-01-2011, 06:21 PM Thread Starter
Ok, I finally got it to open tonight. It did take two people, one to pull the release lever and me to pull the hood up while the lever was being pulled. For some reason the hood still wasn't coming up that initial bit but at least there was a little "click" when the lever was pulled and I was able to get it lifted enough to move the catch and free the hood the rest of the way.
I will be lubing it the next time I see the car in the daylight(it's my wife's car-I get to drive the Impreza) and seeing if something appears to be out of alignment enough to account for the closing problem.
Thanks for all the responses!
To Naomi's Pilot: I had that happen to me with a "68 VW Beetle.....after I figured out what the heck had happened, I found out that I could look through between the end of the hood and the firewall to slow down and pull over. Let me tell you, that curved hood makes a great airbrake!
Ron
awd4me is offline
