Fuel filter - Subaru Forester Owners Forum
post #1 of 27 (permalink) Old 02-15-2010, 01:50 PM Thread Starter
Car Model: Forester 2.5X AT
Fuel filter
I recently had a mechanic (non-Subaru specialist) change out my fuel filter for me. He said that it didn't really have a fuel filter that can be replaced, only a "sock" type of screen in the fuel tank. Searching around, I'm starting to suspect that this isn't the case and that there is actually a cartridge type filter that should have been replaced (and that the "sock" is a "pre-filter"). Can anyone comment on this? The vehicle is a 2007 N/A.
TH-07 is offline
post #2 of 27 (permalink) Old 02-15-2010, 01:55 PM
Feedback Score: 41 reviews
Your '07 has an in tank fuel filter. Due the hassle of getting into the tank to change this filter, most don't mess with it, unless they have problems.
The replacement fuel filter PN is 42072FE020 & it's on the spendy side. I'm going to replace mine, but only because I'm going in there to install a Walbro fuel pump upgrade.
2.5x_sleeper is online now
post #3 of 27 (permalink) Old 02-15-2010, 01:59 PM Thread Starter
...but the owner's manual says to replace it at 60K (which is where I'm at now). Don't I run the risk of ruining the fuel pump?
TH-07 is offline
post #4 of 27 (permalink) Old 02-15-2010, 02:05 PM
The fuel filter costs around $80 list, but you should be able to get it for $60. If you want to replace the prefilter sock, you have to buy a fuel pump installation kit & that'll run you another $20.
post #5 of 27 (permalink) Old 02-15-2010, 02:18 PM
My MODding Journal
Where is the fuel filter at on the 06 NA? I haven't been able to find it and the dealer says there's no external filter on the car.
erikwi is offline
post #6 of 27 (permalink) Old 02-15-2010, 03:03 PM
vintage42's Avatar
Car Model: LL Bean (4EAT)
According to this article, it's in the tank for 06:
http://www.subaruforester.org/vbulle...el-filters.jpg
2008 LL Bean
vintage42 is offline
post #7 of 27 (permalink) Old 02-15-2010, 03:16 PM
The Modfather
Peaty's Avatar
Transmission: 6 Speed Manual
Feedback Score: 10 reviews
if you look here:
http://www.scoobymods.com/fuel-filte...45.html?t=3645
You will see that subaru went from a fuel filter in the motor bay by the strut tower to in the tank which you are supposed to change. it's just a lot more expensive and harder to do. One of the worst things they have done in a while IMHO.
Peaty
Peaty is offline
post #8 of 27 (permalink) Old 02-15-2010, 04:52 PM
Originally Posted by Peaty View Post
if you look here:
Oh crap! Dealer said there was no inline filter to change and they don't even show a part number for a filter. Bet they want to sell the entire assembly for some serious $$.
erikwi is offline
post #9 of 27 (permalink) Old 02-15-2010, 05:26 PM
greentrees's Avatar
Car Model: Acura TSX
Feedback Score: 29 reviews
Hey, I have an 05 and I think it's the same as your MY as far as the fuel filter, I changed mine out a week ago, here's my thread:
DIY 60K service write-up and pics 05 XT
...and there's a pic below of the old filter disassembled. You definitely have a fuel filter that can be changed, $80 retail as others said below. There are some wonderful "how to" threads on this forum that give detailed pictures and make it pretty easy. Worst thing is the smell really. You just need an 8mm, 7mm and a phillips head, that's about it...and some pliers too.
I think you could probably stretch it a bit past the recommended 60k, mine wasn't real dirty at all, I saw zero particles etc. in there, it was just discolored.
Good luck!
PS FWIW I have also had mechanics look up my car on their computer and tell me that there is no filter to change.
Name:	Fuel filter element.jpg
greentrees is offline
post #10 of 27 (permalink) Old 02-15-2010, 05:56 PM
Car Model: Forester touring
Replacing the in tank fuel filter in your Forester is very do-able. If you do, you should also replace the fuel pump gasket.
I will tell you, after doing all the fuel pump housing recalls on the Baha's, I saw very little sediment or discoloration of the fuel filter element. So, is it worth it to replace it?..................its your call.
SubTech is offline
post #11 of 27 (permalink) Old 02-15-2010, 06:00 PM
FPT_RAIDER's Avatar
it can depend on the gas you use and just because you cant see it doesnt mean its not there, the sock is for the big stuff, the other filter is for the smaller stuff
FPT_RAIDER is offline
post #12 of 27 (permalink) Old 02-15-2010, 07:05 PM
I did a work order on a BMW many years ago for a no run condition. When I got it in the shop, the first thing I checked was fuel pressure and it had none. Long story short, owner hadn't maintained the car and a clogged fuel filter toasted both the in tank pump and the external pump. I had to replace both and install a new filter before the car would run. I took the old filter and reverse flushed it using the parts washer. You wouldn't believe the amount of silt that came out for a solid 2 minutes.
A clogged filter will burn up a fuel pump by making it work harder so about 100k, I'll dive in there and replace the filter. Gas smell doesn't bother me, as long as I have a fire extinguisher nearby.
erikwi is offline
post #13 of 27 (permalink) Old 02-16-2010, 10:37 AM
Car Model: FORESTER
2004 fORESTER
Is the fuel filter on the 2004 under the hood or in the fuel tank?
GRETSCH43 is offline
post #14 of 27 (permalink) Old 02-16-2010, 10:43 AM
The Modfather
Peaty's Avatar
Look at my link, it's under the hood in the Forester and easy to get to.
Peaty
Peaty is offline
post #15 of 27 (permalink) Old 02-16-2010, 10:48 AM
Car Model: Mitsubishi Pajero
Transmission: 5spd Automatic
For clearing up the confusion. It's supposed to be under the hood for all foresters up to 2004. From the 2005 models and up it's in the tank.
That's how I understood it from earlier readings
07 Mitsubishi Pajero 3.2 5EAT
99 Forester: Sold
Elmy is offline
