Cruise Control Not Working - Subaru Forester Owners Forum
post #1 of 9 (permalink) Old 02-25-2011, 02:43 PM Thread Starter
Two days ago I purchased a 2002 Forester. However, the cruise does not work. When I push the button on the left the light goes on. However, when I pull the lever down nothing happens.
I looked under the dash and I see there is a switch button on both the clutch and the brake - both of these seem fine. However, a few extra plugs up under the dash, likely for options I done have! The suspicious thing is that there are 2 black wires right close to the brake pedal, and on the brake pedal there is a metal pin with a spring on it thats gets depressed when the brake is not pressed...but no switch! Should there be 2 switches on the brake (or clutch)?
Any help would be great.
Thanks.
Potter is offline
post #2 of 9 (permalink) Old 02-25-2011, 03:01 PM
good dog's Avatar
Car Model: XS
First welcome, hope others can contribute to what I have to offer.
I've not had any issues but these posts might help. It appears in the second thread that a neutral switch on the transmission is often the culprit on manual models and is accessible
Cruise control does not work
Does cruise control not work beyond a certain speed?
good dog is offline
post #3 of 9 (permalink) Old 02-25-2011, 06:58 PM Thread Starter
Wow, I really wonder if it isn't the Neutral Safety Switch. Reason being, on the highway in 5th gear it really lurches, or in any gear really when your holding a constant speed at anything less than 4000 rpm... it needs to be revved up to work well. And, the cruise isn't working. Sound right?
Potter is offline
post #4 of 9 (permalink) Old 02-25-2011, 07:22 PM
good dog's Avatar
Car Model: XS
Quick question, when you turn the car on does the CEL light, light up?
I'm pretty sure if the car has an O2 issue it disables the cruise. There is a mod for the O2 sensor to fool the ECU into not showing a CEL. The lurching/bucking could be indicative of a failing O2 sensor. I'll try searching for something tomorrow if no one posts over night.
good dog is offline
post #5 of 9 (permalink) Old 02-26-2011, 10:20 AM Thread Starter
Yes, the CEL is on, but wasn't always. Cruise wouldn't work and I noticed the lurching, and hour later the CEL came on. I just got the car at an auction so I know no history.
Potter is offline
post #6 of 9 (permalink) Old 01-13-2012, 04:11 PM
Car Model: SUB Forester
Transmission: 5-sp manual
Cruise control button
Hi,
I'm new to the forum and recently bought a 2002 Forester with cruise. The problem is that when I press the cruise control button on the dash, it doesn't light or seem to engage. It just pops up without staying down. Needless to say the cruise control doesn't work with it the way it is. Any ideas where to look first? Is it the button or something else causing the problem?
Thanks for your help. I've already learned some things about the Forester on this forum. I'm returning to Subaru after a 3-yr hiatus with a Nissan. I had an Impreza before the Nissan until someone ran a red light and totaled it.
lexforester5 is offline
post #7 of 9 (permalink) Old 04-11-2012, 08:05 AM
Car Model: Forester L
Transmission: Manual 5spd
I'm having the same issue. It was after I had transmission work done, the cruise control never worked again. I have a 2000 forester L 5spd. The CEL is on, but it's for the Catalytic converter. I already changed both O2 sensors as those went out right after I bought it (probably just a odb2 format the day I bought it).
I can press the Cruise button on the left, it lights up. The toggle doesn't engage anything though. How do I know if the Neutral Safety Switch is the issue? How do I test it?
Libertatus is offline
post #8 of 9 (permalink) Old 05-24-2014, 09:44 PM
Transmission: 5 speed
Unhappy Light on curise control does not come on=no cruise
Seems I'm having a common problem on my 02 Forester. The Cruise Control!
When I press the cruise control button no light comes on, thus the cruise is not working.
All the fuses seem to be good.
Vacuum line is good.
I checked the clutch switches, one has no wire attached, would that be normal? I'm not real sure what to look for here.
I also noticed there are two green connectors not attached underneath the dash, any thoughts on that?
From what I've read if the light is not coming on the switch is not working. Seems I need to start there. Does anyone know what exactly I need to look for to see why the switch is not working.
Krobert is offline
post #9 of 9 (permalink) Old 02-03-2016, 11:26 AM
My 2002 Forester cruise stopped working it is a manual transmission, on the clutch pedal is a safety switch and then like a bump stop with a spring and bushing well the spring was broken so after checking other things that could be a problem I decided for about five bucks to changed the spring I pulled the c clip off replaced the spring put the c clip back and my cruise control is now working perfect.
branonb is offline
