The Duck of Doom
Location: ~ West Hollywood ~ The Only Hybrid Forester...
I've gotten this all resolved, but just wanted to put together a post to warn others of this possible failure. It's nothing severe, but warrants a good visual inspection so you don't end up stranded when your pulley decides to split in two....
![]() I had noticed the rubber looking slightly ragged on the pulley, but didn't think much of it and mentally noted that I should keep an eye on it. Well, within a week, the belts kept loosening up, and when I went to tighten them up, I noticed that the crank pulley had completely delaminated and was in two seperate pieces. I called around to various service/parts departments, and at first I got answers to the effect that this was unheard of and almost unbelievable, but the more I spoke with people the more it became apparent that this is in fact a common thing. The fact that it happened to my car at only 40k seems to be a bit unusual, but I was told that the pulleys are normally replaced when the timing belt is and it seems that they are considered a 'wear' item... Why the pulley is designed like this slightly baffles me. Anyway, heads up - take a look at your pulley MAESTRO |
19
Feedback Score: 13 reviews
Good reason to support aftermarket replacement despite the pseudo HP debate.
GATOR WAGON LINKY |
Car Year: 9999
Car Model: no car at the moment
Transmission: Legs for walking
Bummer. Sorry to hear this.
I hope you got it replaced under warranty or atleast they pony up some cash for you to get a one piece billet aluminum lightweight crank pulley of your choice.
Car Model: Forester "S" lifted.
Transmission: Bog-o-matic
Not common at all.
If I see two a year across all the models that would be pushing it. The last one we did was on a SVX with 220somethingk on it. 40k is VERY early.
It's real velour. Just let yourself go! |
#5 (permalink) | |
formerly known as Benrock05201
Car Model: FXTi
Feedback Score: 43 reviews
Ben |
#6 (permalink) | |
The Duck of Doom
Hopefully this one lasts more than just another 40k |
#7 (permalink) | |
The Duck of Doom
#8 (permalink) |
Registered User
Just a side question: Are the crank pulley's on the ej25 harmonically dampened like they are on DSM's? I know a lot of dsm guys have had problems with aftermarket crank pulleys because they are NOT harmonically dampened.
-Steve
'05 FXT 5MT |
#9 (permalink) | |
Depends on where you ask. NASIOC will insist it is solid metal, even though the above pic clearly shows otherwise
#10 (permalink) |
Car Model: xt
same thing just happened to me. '04 xt with 100,000 miles.
Could it be the result of an improperly fixed front end collision? thanks, r. |
#11 (permalink) |
If the pulley took a hit on the outer ring it may have been enough to start breaking the rubber bond with the two parts of the pulley.
It also just happens some times. Some auto parts stores(autozone) carry a after market replacement at a far lower price then the OEM. The Doorman part# 594-166 at Autozone is about $80. |
#12 (permalink) | |
Registered User
On a side note, we had problems with lightweight pulleys on the Titan even though they were manufactured well and I won't ever try them on a daily driver, I will stick with the factory versions and avoid any potential problems.
09 FXT LTD, 4 SPD AT, NAV and AutoStart |
#13 (permalink) |
Car Model: Forester XS PP 5sp
This is very common for the crank pulley on ALL EJ engines. ALL the way back to MY90 Legacy, I have seen this problem. In fact I just replaced MY04 a month ago buying one from a member of another board. I had 154K at the time I replaced it.
Subaru's price for a replacement is ridiculous .... somewhere around $140. But the damage this can do can go way beyond that. Usually 1st symptom is one of the belts comes off, frays and breaks or just becomes noisy. When you look at it running, you can see the outer grooved pulley wobbling and the belts tracking all over the place.
04XSPP, 98S (8 Subaru's since 1978, 7 were 5 sp) ILuvSubaru's |
#14 (permalink) |
Transmission: 5 Speed
Feedback Score: 55 reviews
A friend locally had his shread on his 06 lgt with 70k on it. It took out his timing belt cover as well.
2007 Forester XT - The Gray Goose 2006 Forester XT - Blu-Blur 2010 Forester X - SOLD-The Green Goblin |
#15 (permalink) |
Whats is even better is when the bolt loosens up and takes out the key way on the crank shaft.
