Cracked Radiator - Subaru Forester Owners Forum
post #1 of 14 (permalink) Old 12-07-2008, 02:05 PM Thread Starter
Cracked Radiator
Was wondering if anyone else had a cracked radiator like mine, 2004 Forester XT 95,000 miles.
It appears as though the weight of the fan assembly /road vibration has caused a stress fracture on the top side of the screw boss.
[screw boss being pulled down]
It has been spraying out coolant through the crack.
I forgot to take a picture of the crack prior to putting a temporary patch over the crack [JB weld]. I don't expect the patch to hold long, just want to get a few more miles in while I await shipment of the replacement radiator.
Is this a common problem?
Chris
eyefly is offline
post #2 of 14 (permalink) Old 12-07-2008, 02:38 PM
admin
SuperRu's Avatar
No, that is not a common problem. I have had one leak at the seam seal. Where the plastic top attaches to the aluminum core.
His...
Hers...
Our daughter...07 OB
SuperRu is offline
post #3 of 14 (permalink) Old 12-08-2008, 03:06 PM
flstffxe's Avatar
I would say this is pretty common, a quick search on nabisco yielded several results for cracked radiators. Some are cracked in the same place, some are not, but most failed due to a crack on the plastic end tanks.
With pics and several others who have had the tanks of their radiator crack:
How's this for a broken radiator? - NASIOC
Need Help! My car is going through radiators - NASIOC
Overheating Issues... - NASIOC
Needed Asap: Wrx Radiator! - NASIOC
Radiator took a dump... - NASIOC
Cracked radiator - NASIOC
radiator cracked!! - NASIOC
08 X Prem 5mt
flstffxe is offline
post #4 of 14 (permalink) Old 12-08-2008, 03:11 PM
tre36's Avatar
Car Model: camry se
Transmission: 6AT
Great. More preventative maintenance expenses to think of.
tre36 is offline
post #5 of 14 (permalink) Old 12-08-2008, 03:39 PM
admin
SuperRu's Avatar
Oy vey, now more to worry about!
Do you think the failures might be related to over tightening of the hose clamps?
His...
Hers...
SuperRu is offline
post #6 of 14 (permalink) Old 12-08-2008, 03:50 PM
funkymonkey1002's Avatar
Car Model: 2.5 XT
I think its just the nature of using plastic on something that sees heat cycles like the rad. Plastic end tanks just don't make sense to me, especially on radiators and the newer style subaru intercoolers.
funkymonkey1002 is offline
post #7 of 14 (permalink) Old 12-08-2008, 03:52 PM
Feedback Score: 53 reviews
Yeah, the plastic endtanks on Subie radiators are pretty notorious for cracking. I remember first reading about it when the STi radiator caps were all the rage. The endtanks often can't handle the resulting increase in pressure. In the OP's case it could be as simple as fatigue of the material, I suppose, especially at that mileage.
~ Silke ~
'04 FXT 4EAT PSM - "Subed Up"
'98 S 4EAT DBP - "Slynki"
pleiad7 is offline
post #8 of 14 (permalink) Old 12-08-2008, 04:30 PM
tre36's Avatar
Car Model: camry se
Transmission: 6AT
I'm with funkymonkey1002 on this.
I'm going to run my car til the last crank. I probably would look into a aluminum radiator or full steel at the very least for replacement.
I went through two headgasket replacement already and dread anything that leaks coolant. I'm fearful at this point actually.
tre36 is offline
post #9 of 14 (permalink) Old 12-08-2008, 04:57 PM
Check what kind of warranty you have. That's clearly a falt and the rad should be replaced.
98 forester L 2.5L
British-G is offline
post #10 of 14 (permalink) Old 12-08-2008, 05:44 PM
At 95k miles on an 04? I think the OP is SOL warranty-wise, unless he has the 100k Added Security Gold Plan...
~ Silke ~
pleiad7 is offline
post #11 of 14 (permalink) Old 12-08-2008, 07:08 PM Thread Starter
I really don't see any relationship to the hose clamps. I have never tightened them since new so if they were overtightened it would be that way from the factory. Also if it were the hoseclamp I would expect the the plastic part of the radiator inside the hose to be damaged and it is not.
I think it is just the tank cannot take the road vibration, especially with the weight of the fan assembly hanging off the screw boss. A better design would have fillets and or ribs on the screw bosses /posts to more evenly spread out the stresses.
It seems to be a common problem on the NASIOC forum as flstffxe pointed out. Theirs cracked too and further away from the hose clamps.
How's this for a broken radiator? - Page 2 - NASIOC
However if you do overtighten the hose clamps that would lead to another failure no doubt.
Chris
eyefly is offline
post #12 of 14 (permalink) Old 12-08-2008, 07:12 PM Thread Starter
Does anyone sell a good aftermaket aluminum radiator that is better?
I already ordered the OEM part again but maybe next time I'll do something else.
Chris
eyefly is offline
post #13 of 14 (permalink) Old 12-09-2008, 12:13 PM
tre36's Avatar
Car Model: camry se
Transmission: 6AT
I don't know for certain but I'll be looking into it for sure. I usually swap out the radiator hoses at 100K miles on all the cars I've own and after reading reports of crack Subaru radiators considering swapping the radiator too. It's an easy swap to do and I'll have all the hoses out and such anyway.
tre36 is offline
post #14 of 14 (permalink) Old 12-09-2008, 12:20 PM
FS CA: Koyo Radiator w/ Flex-a-lite dual fan setup.
~ Silke ~
pleiad7 is offline
