Correct way to check oil.. - Subaru Forester Owners Forum
post #1 of 31 (permalink) Old 06-16-2006, 09:04 AM Thread Starter
What is the correct way? Let the car sit overnight then check oil while the car is off? Run the car to operating temps then turn the car off and check the oil? Which one is the correct way and post some type of proof that its the correct way!
I've always down it when the car was cold. It just made more sense to me.
SUV - Sick Utility Vehicle
05 FXT 5MT
ZuMBLe is offline
post #2 of 31 (permalink) Old 06-16-2006, 09:41 AM
The Modfather
Peaty's Avatar
Transmission: 6 Speed Manual
Feedback Score: 10 reviews
http://www.scoobymods.com/forums/showthread.php?t=2691
Peaty
Peaty is offline
post #3 of 31 (permalink) Old 06-16-2006, 11:11 AM Thread Starter
From that I gather the oil should be checked while cold. Reading Unabomber's FAQ on nasioc it says to check oil when the car is warm at operating temps. Other people seem to agree to this but I've never done this before.
05 FXT 5MT
ZuMBLe is offline
post #4 of 31 (permalink) Old 06-16-2006, 11:27 AM
Galager's Avatar
Car Year: 13
Feedback Score: 12 reviews
I believe you drain it at operating temps, but you check it when cold. If you try to check it just after its shut off, it won't show the correct oil level as it is still draining and mucking up the dipstick.
'05 XT 5 spd VF - SOLD
'13 XT Touring
Galager is online now
post #5 of 31 (permalink) Old 06-16-2006, 11:29 AM
The Modfather
Peaty's Avatar
there is this too from the Forester SM
Peaty
Peaty is offline
post #6 of 31 (permalink) Old 06-16-2006, 01:41 PM Thread Starter
That's it then.. Check when cold. Thanks Peaty..
05 FXT 5MT
ZuMBLe is offline
post #7 of 31 (permalink) Old 06-18-2006, 01:24 PM
The Modfather
Peaty's Avatar
I like to check it cold first thing in the AM. I just remove the dipstick and read it. If it's been sitting all night then there is no need to wipe it then check.
Peaty
Peaty is offline
post #8 of 31 (permalink) Old 06-18-2006, 03:08 PM
Harbor Fright
FXT22's Avatar
I also check it in the A.M. when cold- it just amazes me that the reading varies so much when parked nose-in vs. tail-in...and the garage barely pitches toward the street...seems to read higher (by ~1/2 qt.) when the car is pointing uphill.
-Len
OBP '05 FXT MT, AP/VF-39, JDM EJ-257 (swap was easier than HGs...and not many more $)
FXT22 is offline
post #9 of 31 (permalink) Old 06-18-2006, 08:52 PM
Dan
Dan's Avatar
Car Year: 12
Car Model: Premium
Transmission: 5-speed
During an oil change you're filling with and measuring cool oil, so I figure the oil should be cool when just checking it.
SHIFT_to_Subaru
'12 Forester, 5spd - hers
'08 Legacy SE, 5spd - hers
'09 OB SE, 5spd - mine
Dan is offline
post #10 of 31 (permalink) Old 06-18-2006, 09:15 PM
Car Model: XS Premium
It's not the temperature of the oil that's the problem. It's that when the oil is hot it means that the engine has been running recently and some of the oil might not yet have settled back down in the oil pan, leading to an incorrect (low) reading on the dipstick.
That having been said, I don't have a flat place in my drive or on the street, and being parked flat is important. So I check my oil in the parking lot at the nearby Wal-Mart. It will still be pretty warm, even after 15 minutes of shopping, but I mentally factor that in and assume that the dipstick is reading low by a half a quart or so. As long as things stay in the range I'm OK. I'm not too fussy about exact oil level.
bbottomley is offline
post #11 of 31 (permalink) Old 06-19-2006, 07:21 PM
kickin_81's Avatar
I check my oil when it's cold also, but who the hell came up with the statement that you should check your oil at every gas fill-up? Sounds smart but it's wrong.
kickin_81 is offline
post #12 of 31 (permalink) Old 06-22-2006, 08:39 AM
Retserof's Avatar
Checking oil at every gas fill-up is something I learned back in the "old days" when cars typically used a lot more oil and gas tanks were bigger, but there is nothing wrong with it even today. It was just conservative good practice. I don't do it every time anymore, but while the gas tank is filling, it is easy to check under the hood for potential problems and check fluid levels.
Tom and Ray of Car Talk recommend the following:
"Yes, you need to check the oil level every few hundred miles. With your car parked on a level surface, remove the oil dipstick, clean it on your brother's best shirt and then reinsert it. Remove it again, and check the oil level." "http://cars.cartalk.com/content/advice/oilchanges.html
04 FXT Java Black Pearl M/T
98 C5
94 RX7
Retserof is offline
post #13 of 31 (permalink) Old 06-22-2006, 09:19 AM
Two distinguished graduates of .
Honest!
post #14 of 31 (permalink) Old 06-22-2006, 09:49 AM
TAGXT04's Avatar
Car Model: GTI
Transmission: DSG 6-speed
Most important part of checking the oil is the "checking" part. Do it regularly and consistently. When you check it make sure the level is between Low and Full and avoid over-filling (past the notch on dipstick.)
'12 VW MK6 GTI 2.0T w/ DSG
TAGXT04 is offline
post #15 of 31 (permalink) Old 06-22-2006, 09:51 AM
German tech
I Want Candy!'s Avatar
Car Year: MY16
Car Model: Audi S3 Sedan
Transmission: DSG 6 speed
If you have a pre MY06, check it often
Audi S3 MY16 S Tronic Petang Blue Performance Pack.
I Want Candy! is offline
