('06-'08) Check Engine Light/Cruise Indicator - Subaru Forester Owners Forum
post #1 of 10 (permalink) Old 02-02-2012, 05:40 AM Thread Starter
New User
Transmission: Don't know
Hi there...
My 2006 Forester had a lovely little surprise for me yesterday. I hopped in and started it up, headed for work. The Check Engine light was on and stayed on constantly. The Cruise Indicator light was on as well, but was blinking.
I tried to engage the Cruise but of course, it was having none of that.
Any ideas or advice? Is it safe to drive the vehicle for about a week or so until I can get to a mechanic?
Oh, it is an automatic transmission. It has been whining when I back up and recently the left hand headlights went out. I had an oil change about a week ago. Guess that is about it.
Appreciate any input! Thank you...
Lisa
ladams402 is offline
post #2 of 10 (permalink) Old 02-02-2012, 05:47 AM
Car Model: 2.5 XTe
Hi Lisa, the CEl (Check engine light) light flashing along with the cruise control also flashing and becoming defunct is indicative of a problem with the car that has been picked up by the on board diagnostic system.
To establish what the actual problem is you will need to know what codes are being recorded by the on board diagnostic system through equipment and software designed to interrogate the OBD system.
Once you know what the code/codes are then this forum will doubtless be a source of knowledge, but first you need to get the codes read. There are many articles on here about how to go about that depending upon where you are, your level of technical expertise or access to garage facilities that can do the interrogation for you.
Very general answer but I hope it helps.
Coachhome42 is offline
post #3 of 10 (permalink) Old 02-02-2012, 05:58 AM Thread Starter
New User
One thing...
Coach...
First, thank you for responding.
Not sure it makes a difference as I am assuming I will still need to find out the code...but the CEI is not flashing...it is constant. It is the Cruise Light that is flashing. Does that change your answer?
Thanks again!!
Lisa
post #4 of 10 (permalink) Old 02-02-2012, 06:14 AM
Car Model: 2.5 XTe
Your are right CEl does not flash, my error there, everything
else is the same though.
I currently have a problem with my secondary air system and got the same problem which is why I am here in the first place. Been running with same problem for two years now and forum has recently shown a good way to correct issue without paying a new mortgage, so once you know what the code is then you can establish what actions if any you are able to do to correct it.
Good luck.
post #5 of 10 (permalink) Old 02-02-2012, 06:30 AM
ConnorLug's Avatar
Car Model: FXT Limited
You can go to an auto parts store like advance auto parts or autozone, and they will read the code for you for free. Have them write down the code for you and post it up here and we'll tell you whats up!
ConnorLug is offline
post #6 of 10 (permalink) Old 02-02-2012, 07:58 AM
TC2000's Avatar
Loose gas cap ?
Have you put gas in the car recently ? My daughter put gas in my car on Sunday night and since the teather had broken off the cap she put it on the roof to fill it, and well she ended up leaving it on the roof and driving off without it . The next morning the same lights came on. When I get to where I was going I went to check and tighten gas cap and realized she had forgotten to replace it. Made a trip to the dealer bought a new cap with teather replaced it and drove it for a day to see if it would reset itself, to my dismay it did not . The next morning I pulled the negative battery terminal off stepped on the brakes a few times, reconnected everything and walla! no more cel light and flashing cruise.
2009 Forester X Premium 4EAT
Respect The Wagon!
TC2000 is offline
post #7 of 10 (permalink) Old 02-02-2012, 02:03 PM
Car Model: XS Premium
Check item 7 in the Important Forester info for new members thread.
bbottomley is online now
post #8 of 10 (permalink) Old 04-08-2012, 08:30 PM
baangeles's Avatar
I too just got the flashing cruise light and solid check engine. This started right after we turned both r front heat seats on. I had to take both battery cables off reconnected and like u said "Walla" no more flashing cruise, solid check engine light!
Curious if this is just a temporary fix? Everything is running fine n it's an 07 XT Sports MT
Any additional input of symptoms that may occur?
Thanks for the info
07 SPORTS WRB MT/04 X WHITE AT
baangeles is offline
post #9 of 10 (permalink) Old 04-11-2012, 08:42 AM
Thanks for the info
Yes this is only a temporary fix (more than likely). Your light will likely come back on in a day or two. You need to find out what the code is. Chances are, it's an O2 sensor. We have replaced 3 of them in my wife's 06 Forester in the past 4 years.
shmoeman is offline
post #10 of 10 (permalink) Old 03-01-2013, 10:39 AM
Transmission: manual
CEL and flashing cruise
I just bought a 2005 forester 2 weeks ago from Subaru dealer. First road trip and the light combination went on shortly after filling up. The manual said firstly to make sure your gas cap is on tight. Well, that didn't do it. I took it in they fixed it in about an hour. A manifold on the o2 sensor was cracked, they replaced it. Luckily covered under 1 month warranty, so I don't know the cost.
It seems to me from reading through threads that this CEL cruise combination has to do with the fuel system, be it Cat converter, o2 sensor, high humidity.
suddern is offline
