check engine light code P0457 - Subaru Forester Owners Forum
post #1 of 9 (permalink) Old 11-24-2007, 11:56 PM Thread Starter
Steve's Avatar
A steady check engine light came on today with the cruise control light flashing. I took car to Auto Zone and got the code above. It said loose gas cap but cap did not appear to be loose but i did crank it down. I'm thinking even though I'm past 36k miles it would still be a warranty item since convered under emissions. Has anybody had any experience with this code and getting it repaired via a dealer?
p.s. I did remove and clean the cabin air filtration filter a couple of days ago but don't think this would have any affect on the above.
2006 x Auto
Steve is offline
post #2 of 9 (permalink) Old 11-25-2007, 12:30 AM
goshring's Avatar
Location: The Big Sky Country Montana on the Rocky Mnt Front Range
Car Model: Forester L NA
Transmission: auto
Cool
Hi Steve..I just looked the code up in my Suby book and here is what it says........................
Evaporative Emission Control (EVAP) system leak detected (fuel filler neck loose or not installed)
This is the exact quote from the book so something else may have come loose.
Good luck.
Kenny
goshring is offline
post #3 of 9 (permalink) Old 11-25-2007, 08:13 AM
Graham's Avatar
Car Model: Sport XT
The cap doesn't need to be really loose, just not tight enough to seal properly. They are quite sensitive to this. Did you have the CEL reset by AutoZone? If not, it's going to take a few drive cycles before it goes off by itself.
If it really is a problem, then the CA emissions warranty may well cover it: you need to check the parts covered in your warranty booklet, it varies a bit from year to year. (Make sure you check the CA emissions warranty section, not the Federal one.)
(Oh, you are correct, the cabin air filter won't be anything to do with it.)
Graham is offline
post #4 of 9 (permalink) Old 12-17-2007, 04:33 AM
Buddur's Avatar
Did Re-Tightening The Gas Cap Work?
While driving to work this morning, my Check Engine light came on and stayed on steadily and the "Cruise" light came on and blinked. Before I could pull over I looked at my owners manual and it said an Emission Control maintenance issue. I did back into some snow while pulling out of my garage, so when I pulled off the interstate I checked the muffler and there was no snow plugged in it.
After reading this thread and posting this, I'm going to go out and re-tighten my gas cap. Hopefully this will work, but I filled the tank yesterday while coming home from a weekend trip, and drove at least 80-100 miles before the lights came on.
Can anyone of you guys who this happened to give me/us an update regarding your fix and clearing your CEL?
Tom
Of course, I should stop by Auto Zone and have them read for the "real" code.
Edit: having stopped to get the CEL read and cleared, it showed a PO420 code a catalytic maintenance somethingorother. I'm sure my cat is not going bad and that the issue was probably detected form having backed into deep snow and slightly plugging the exhaust for a very short while. The electronic reader cleared the warning lights and they have not come back on (yet).
2006 2.5X AT N/A
Last edited by Buddur; 12-18-2007 at 06:49 AM. Reason: ....I'm Editing 'Cause I'm One Bad Mutha!
Buddur is offline
post #5 of 9 (permalink) Old 04-22-2010, 10:28 AM
Car Model: forester X
One week after getting a new USED engine in my 2005 subaru forester X the CHECK ENGINE LIGHT CAME BACK ON... "Found code P0457 large evaporative leak detected (Fule cap). Checked the fuel cap (cap passed with the tester). Subaru found blockage under the manifold in a tube of the evap. purge... code P0457 detected after clearing the blockage, re-tested for leaks, no evap. leaks... Checked purge valve and close valve with SSMIII, did compulsary valve check. Energized the close valve, re-performed leak check; no leak. Performed test drive with SSMIII; Pressure sensor reads negative value to -012, -.003 at open cap values; should not be below ZERO hg. Need to replace the pressure sensor and recheck"(subaru service tech notes)!!!
Should I have the dealership replace this for and additional $850 or take the car out of their shop... im tired of maita subaru! 5G705359
melon817 is offline
post #6 of 9 (permalink) Old 04-22-2010, 10:55 AM
filler pipe and EVAP valve
have you checked the filler pipe? behind the rear passenger tire you can remove the cover 3 10mm bolts (upper one will most likely break off). then you can begin scraping off the mud cake to reveal the gas pipe and a very rusty EVAP valve. dealers keep this part in stock...
CarMech is offline
post #7 of 9 (permalink) Old 07-07-2010, 07:01 AM
Car Model: forester s
Same code here. I just replaced the rusty filler pipe and all associated parts/evap lines.
Question: I want the PCM to reset the code on its own. Does anyone know how many drive cycles it takes?
golden retreiver is offline
post #8 of 9 (permalink) Old 07-07-2010, 01:40 PM
Real Lyte's Avatar
Car Model: Impreza RS Wagon
~100 miles or more, most EVAP test by the ECM are done around half a tank.
05 2.5RS
03 Outback
They live on.
Real Lyte is offline
post #9 of 9 (permalink) Old 07-08-2010, 07:10 AM
Thanks - better half just informed me light went out at about 75mi.
