#106 (permalink) |
^Linky no worky...but THIS SHOULD.
2004 FXT |
#107 (permalink) |
Car Model: Subaru Forester
hello! just a quick noob question guys.. i'm planning to change the fluid for my automatic transmission and was wanting to replace the filter as well.
question: do i need to replace the gasket as well? the reason i asked because i cant find any gasket/seals on our local subaru dealership that's why i dont know if i can just drain the AT fluid -> remove the transmission pan -> replace the AT filter -> put the transmission back on -> top up the AT fluid. these are the parts that i have now: 1 AT filter 4 liters AT fluid hoping for you replies. thank you guys! |
#108 (permalink) |
Car Model: FXT - Touring
Transmission: Hi Torque CVT
It's recommneded to replace the crush washer for the drain plug. Some people do, some people don't. I personally do replace it as its so cheap there's no reason not to.
Larry D 2014 FXt Touring Venetian Red Pearl |
#109 (permalink) | |
Got a pic of the '1 AT filter' you have? The '98 shouldn't have a 'filter', unless you're referring to the 'screen' inside. In '99 they updated the trans w/an EXTERNAL spin-on filter, which is supposed to last the life of the car. Also, in the owner's manual it'll tell you that the trans holds 10 US quarts. Your 4 qts will just be enough to replace what's in the pan. I'd suggest reading up on here if you think you need to drop the pan...It's a pain and not necessary, IMHO. I recommend just drain/refill/drive (shifting thru all gears) and repeat 3x. That'll get most of the old fluid out and you'll be good for another 30K miles. TD
2004 FXT |
#110 (permalink) |
When did they start using drain plugs?
#111 (permalink) |
Car Model: Forester XS PP 5sp
As far as I remember, even the debut of the 4EAT in the US in the 1990 Legacy had a drain plug. I have never seen a 4EAT without one.
04XSPP, 98S (8 Subaru's since 1978, 7 were 5 sp) ILuvSubaru's |
#113 (permalink) |
Thanks ferret, appreciate it.
#114 (permalink) |
I did mine the other day. Pretty simple, and I was amazed at how dark the fluid was. I just removed the drain plug and then reinstalled plug and refilled. Refilling was the longest part due to waiting for the funnel to drain. I will repeat this process a few times and then get a new filter from Subarupartsgirl !!!
#115 (permalink) | |
Part number: 38325AA032 Link: http://subarupartsforyou.com/cp_part...p?partid=10331 So the best way to do it is just drain the fluid, refill, drive then do it 3x. That would be a lot easier than replacing the filter etc. etc. I might just return the filter to the Subaru dealership and exchange it with 8 liters of AT fluid. |
#116 (permalink) | |
Hi! Is this the washer for the drain plug? Do you have the part number for this one so i can order it to the Subaru dealership. Thank you! |
