#61 (permalink) |
IDMO - Sometimes an oil will show high metal wear if your bearings are starting to go, but your copper is the only thing that is high so it might be a specific problem. The oil remained a 30 weight viscosity so that's very good. I would post this on bitog for some expert comments on the copper. They might even suggest a Dyson analysis. Although Ifdal's copper eventually came down.
Blackstone's explanation of elements. What kind of in-line oil filter are you talking about? It's definitely not the fumoto. ifdal - Your engine is wearing perfectly, but the oil sheared to a 20 weight in under 3,000 miles! Do you have an OEM air filter (silicon)? You could probably go 4-5k miles on the PP, IMHO. -Dennis Last edited by bluesubie : 05-05-2007 at 07:44 AM. |
#62 (permalink) |
Dennis -
It's an OEM air filter with about 8k on it when the oil was sampled. I'm still using the OEM oil filter's as well. You thinking I should migrate to a 40w for the summer? Driving for these last 6000 or so miles has been 90% (at least) stop and go. I'm guessing IDMO was mentioning the two in line oil filters for the AVCS system. There was a TSB about them mentioning, IIRC, that they could drop and impede oil flow to that part of system. I removed mine a while back.
Larry D 08 OBW Ltd, Missing my 04 FXT 4EAT |
#63 (permalink) |
Larry,
I guess it depends on your comfort level and how long you plan to run it. I usually go with thicker 30 weights (thicker at 100 cst) for peace of mind. A lot of Energy Conserving 30 weights will shear to a 20 weight in a turbo in 3k miles. The PP might hold up a little better. I'm actually sampling my Motul 8100 5W30 today and expect it to be a 20 weight. I wanted something thin for winter to see if it would help with fuel dilution. German Castrol 0W30 will be in before it gets too hot out. Ok, now I remember about the in-line oil filter. Thanks. -Dennis |
#64 (permalink) | |
The filter I was talking about is discussed here: http://forums.nasioc.com/forums/showthread.php?t=906921 I'm just thinking of anything copper or brass that I could have screwed around with. |
#65 (permalink) | |
Unless, of course, you just want to do a Dyson anyway. :) -Dennis Last edited by bluesubie : 05-09-2007 at 12:20 PM. |
#66 (permalink) |
Sorry, not sure what UOA is but I'm assuming it's something Oil Analysis. So I should just do a normal analysis and see if Copper dropped and then go from there on getting a Dyson done? I seem to remember seeing where they can do a Dyson with your sample even after you've received the results for the standard analysis. If so, that's probably the route I'll take.
#69 (permalink) |
Nice! Mine is below. I switched to Motul 8100 5W30 because I wanted something thinner than the German Castrol I was running. I was having high fuel dilution in the winter due to my 5 mile commute.
The Motul is a thin 30 weight and I'm impressed that it stayed in grade. Equipment make: Subaru Equipment model: 2.5L Turbo Oil use interval: 5,900 Oil type & Grade: Motul 8100 Eco-nergy 5W30 Make-up oil added: .25 qts. Miles on unit: 59,650 Air filter: OEM Oil filter: OEM Dennis: Sodium dropped again, and wear looks terrific. The TBN read 4.8, still plenty of active additive left in the oil. We’re glad to see that you haven’t changed this oil yet. It still has plenty of life left in it. No fuel or antifreeze found. Add another 2,000 or 3,000 and check back. If wear still reads low, you may not even need to change it at that point. Aluminum 4 5 4 4 4 6 Chromium 1 1 1 1 1 1 Iron 11 12 16 11 10 15 Copper 6 8 7 10 6 20 Lead 2 3 3 3 2 2 Tin 0 1 0 1 0 0 Molybdenum 3 2 9 4 12 63 Nickel 0 0 0 0 1 0 Maganese 0 1 0 0 0 0 Silver 0 0 0 0 0 0 Titanium 0 0 0 0 0 0 Potassium 0 2 0 0 0 3 Boron 1 0 0 1 14 115 Silicon 14 13 15 15 18 Sodium 11 19 18 6 2 6 Calcium 1252 1783 2165 1689 2582 3394 Magnesium 953 530 436 398 106 10 Phosphorous 932 796 816 754 680 764 Zinc 1025 974 1011 909 818 904 Barium 0 0 0 0 0 1 Properties SUS Viscosity @ 210F: 58 66.2 66.4 64.4 64.8 57.8 [56-63] Flashpoint: 370 380 380 385 365 395 [>365] Fuel %: .5 TR .2.3 .5 1.0 .5 [<2.0] Antifreeze: 0 0 ? 0 0 0 [0] Water: 0 0 0 0 0 0[<0.1] Insolubules: .3 .4 .2 .5 .4 .5 [<.6] |
#72 (permalink) |
Administrator |
Follow-up question to my above post... Is the increased wear due to the shearing of the oil? Should I be using a different weight, or is it normal for wear to increase as the motor ages?
Oh, and I'm pleasantly surprised that the SPT intake does a decent job at filtering out particles. |
#73 (permalink) |
A thin oil sometimes shows more wear but your increased wear is just a little blip.
Folks at bitog have been commenting lately that M1 30 weights have been showing more wear in general though. A more robust and thicker M1 is the M1 10W30 High Mileage. It's European ACEA A3 rated and only a handful of 30 weights in the U.S. get that. I'm not sure that engine wear and age go hand in hand (but it does make sense). Maybe post at bitog. I'll try to search later when I have time. The best dirt filtration will show Si in the single digits. -Dennis |
#74 (permalink) |
Another thing. I'm actually suprised that the viscosity stayed in grade so well in your previous reports. Usually, an Energy Conserving oil shearing to a 20 weight is normal (especially in a turbo). That's why Blackstone says to extend the interval even when it's a 20 weight.
I found a few interesting links to read on bitog: Thicker oil with high mileage? Acceptable wear metal ranges (the Audi guy really knows his stuff!) * Who doesn't like HM oils and why? What is oil analysis (also in the link above)? *My two cents: Regardless if people think HM oils are marketing hype, they are usually thicker oils. M1 10W30 is 10.0 cst's at 100C M1 10W30 HM is 11.79. -Dennis |
