('14+) 2014 6 Speed Owners: 4th Gear Stick Vibration? - Subaru Forester Owners Forum
post #1 of 26 (permalink) Old 10-22-2013, 06:57 AM Thread Starter
Car Model: Forester 2.5iPremium
Transmission: 6sp Manual
Hi There
I have a light vibration at the stick in 4th gear. It is obvious when accelerating from around 25mph and above. It seems to be more noticeable at full or near full throttle.
I know not to rest my hand on the gear box and I'm not asking anyone else to do so. Just lightly touch the shifter *during acceleration*, while in 4th and let me know if you get vibration.
I've taken the car to the dealership, they told me its normal due to engine vibration. This is my 3rd vehicle with a manual transmission and I've never experienced this before. I'd love to have this confirmed.
RiffleKing is offline
post #2 of 26 (permalink) Old 10-22-2013, 07:14 AM
brutus14's Avatar
Car Model: 2.5i Premium
Transmission: 6speed/mt
RiffleKing........ Mine does the same thing only in 4th gear. It might be the linkage and gear shift leaver are in a position that sets up a vibration only in 4th. It reminds me when I'm on the x-way that I need to shift back up to 6th.
brutus14 is offline
post #3 of 26 (permalink) Old 10-22-2013, 07:17 AM
Loscaldazar's Avatar
Car Year: 03
Transmission: 5 MT
Feedback Score: 11 reviews
If you are in 4th gear @25 MPH, that is a problem. That probably lugs the engine and creates a bunch more shaking. The 6 speed you have has even higher gear ratios than the 5 speed, and I know that my 400lb lighter (with similar power) and lower gear ratio 5 speed Forester would struggle in 4th gear @25 MPH.
Loscaldazar is offline
post #4 of 26 (permalink) Old 10-22-2013, 07:34 AM Thread Starter
Brutus,
Thanks a bunch for the feedback. I'll stop worrying about it now and just consider it a courtesy vibration! :)
Loscaldazar,
I do not normally shift that early. It was for test purposes before bringing it in to get looked at.
post #5 of 26 (permalink) Old 10-22-2013, 07:40 AM
Sabrewings's Avatar
Probably that the vibrations of fourth gear are in resonance with the shifter components. It's something that should've been caught in development, but is not a problem.
2011 Impreza 2.5i
1999 Forester S
Sabrewings is offline
post #6 of 26 (permalink) Old 12-22-2013, 04:10 AM
Car Model: Forester Premiun 6MT
Transmission: 6MT
2.5 ^mt not a flexible combination.
I drive a lot of MT's
I am spoiled by the good ones. The 2.5L and 6MT has some vibtration, weak torque output at low revs and a bit of surging.
Ration spacing is wrong 1-2 and 5-6.
Compare to a almost any Mazda and you will hate the subie MT.
mike69440 is offline
post #7 of 26 (permalink) Old 12-23-2013, 04:51 PM
Charlie07
Guest
Posts: n/a
I also have a 6 sp manual 2014 forester and I was getting pretty anxious about the vibration in 4th gear. I notice it around 2500 rpm. I've driven stick for about 40 years (never a 6 spd) and I don't recall anything similar. I also feel a slight vibration in the clutch pedal. Has anyone noticed that? I wonder if I'm overly sensitive and if a mechanic would even feel what I do
post #8 of 26 (permalink) Old 03-07-2014, 12:35 PM
kins191's Avatar
This is because 4th gear is a direct 1:1 so it simply engages the input shaft to the output shaft with no gear reduction or addition. Basically the counter shaft is in mesh with but not engaging the output shaft so there is less absorption of the engine vibration.
Doug
ASE smartified
kins191 is offline
post #9 of 26 (permalink) Old 03-07-2014, 11:12 PM
dpm
Car Model: XC diesel
^ wrong. All gears are indirect in the 6MT.
2015 SJ XCdiesel CVT
dpm is offline
post #10 of 26 (permalink) Old 03-08-2014, 04:41 AM
mjeanneau's Avatar
Transmission: 6 speed manual
true that...also what are these people doing in fourth at 25 mph???...you will not get better MPGs shifting that far below the torque band; all you are doing is beating your engine by lugging it. the barest minimum speed in fourth on that engine is about 30 mph, and any acceleration would require a shift to third
mjeanneau is offline
post #11 of 26 (permalink) Old 03-08-2014, 09:40 AM
kins191's Avatar
I stand corrected. I didn't realize they used all indirect gearboxes but sure enough 4th gear is .972
kins191 is offline
post #12 of 26 (permalink) Old 03-08-2014, 11:00 AM
ryan_calif's Avatar
Car Model: Forester 2.5i Premiu
Transmission: 6MT
No driveline vibration in my 2014. Your engine speed is way too low in 4th gear at 25 mph though.
Try and keep RPMs above 2,000 in any gear above 1st.
ryan_calif is offline
post #13 of 26 (permalink) Old 03-08-2014, 07:28 PM
Transmission: 6 spd
I brought this up the the dealership mechanics during first (free) oil change and was told it was the nature of the beast. I once had a vehicle with a bad shifter fork out of the factory that would pop out of gear during engine braking. This seems innocuclous but annoying.
If you move the shifter very slightly, the vibrations will disappear. It appears it's a case of the cable transferring vibrations to the shifter. This is my first cable shifter, so I'm not sure how the shift lever is located (detents or whatever). Possibly a wee bit sloppy in shift lever detents?
Looking at the cable, it drapes over the top of the tranny, then makes a loop where it contacts the engine block, finally going down to the passenger side of the tranny where it attaches to the tranny. It also could be that some additional brackets or padding might isolate the vibrations. Currently, it kinda looks like the only actual attachmets are at the shifter and where the cable mates with the transmission.
wr moore is offline
post #14 of 26 (permalink) Old 03-08-2014, 11:33 PM
dpm
the detents are at the bellcranks at the rear of the 'box, and the shift rails. The lever has no positioning of it's own save for the reverse collar.
dpm is offline
post #15 of 26 (permalink) Old 03-09-2014, 04:48 PM
mjeanneau's Avatar
btw, 13+k miles on mine and no vibration in any gear/speed
