2010 tire pressure sensor light - Subaru Forester Owners Forum
post #1 of 17 (permalink) Old 12-05-2009, 09:57 AM Thread Starter
justjpo's Avatar
Has anyone else had an issue with the tire pressure light coming on in cold temps and remain on after warming/driving?
Does it have to be reset via dealership?
2005 Aspen White XT
justjpo is offline
post #2 of 17 (permalink) Old 12-05-2009, 10:07 AM
FPT_RAIDER's Avatar
confused, your tag says you have 05??? the lights dont need to be reset in the sense that you think, you just need to check the tire pressure with a gauge, chances are that your tires are in fact low, you also could have a very slow leak, my moms OB wagon has had one in the past and it was the seal on the tire pressure sensor itself
FPT_RAIDER is offline
post #3 of 17 (permalink) Old 12-05-2009, 10:20 AM
flstffxe's Avatar
^^ true.
TPMS Sensor Replacement.
08 X Prem 5mt
flstffxe is offline
post #4 of 17 (permalink) Old 12-06-2009, 08:23 AM Thread Starter
justjpo's Avatar
I have a 2005, my fiancee drives the 2010 in question. Tire pressure was incresed after checking with gauge. The light went off, now it has come back on with the same tire pressure in all four tires as it had when the light went off....
Ambient temp this morning was 12 where live FYI.
2005 Aspen White XT
justjpo is offline
post #5 of 17 (permalink) Old 01-04-2010, 08:14 AM
Car Model: Forester 2.5x
Question 2009 Subaru Forester tire pressure sensor light
I started getting the tire pressure light when the temperature fell below 14 degrees. I was driving @ about 80 MPH and the light started blinking. I stopped at the nearest gas stations and checked the tire pressure which was as recommended in all the tires. Is this turely a temperature issue? or is there more to this. Does anyone know how to reset this sensor?
Thank you.
kansiawala is offline
post #6 of 17 (permalink) Old 01-04-2010, 08:56 AM
romclean's Avatar
I've had several different brand SUV's with TPMS systems... they've all had issues in really cold temps... A VW Toureg I had did it every time the temps got into the single digits even tho pressure was good in each tire - the only thing I did like about that system was the actual pressure readings it gave you for each tire on the dash. I'm not using them in the Subaru - winter package instead.
______________________________________
2009 Forester XT Limited, Nav, Reverse Cam
romclean is offline
post #7 of 17 (permalink) Old 01-04-2010, 08:58 AM
Mod Emeritus
crewzer's Avatar
Car Model: Highlander AWD XLE
Transmission: 6AT
Lightbulb
The same indicator is used for a low tire pressure indicator and a TPMS system malfunction indicator (telltale). Per page 3-14 and -15 in the '09 U.S. spec Forester owner manual:
Your vehicle has also been equipped with
a TPMS malfunction indicator to indicate
when the system is not operating properly.
The TPMS malfunction indicator is combined
with the low tire pressure telltale.
When the system detects a malfunction,
the telltale will flash for approximately one
minute and then remain continuously
illuminated. This sequence will continue
upon subsequent vehicle start-ups as long
as the malfunction exists. When the
malfunction indicator is illuminated, the
system may not be able to detect or signal
low tire pressure as intended. TPMS
malfunctions may occur for a variety of
reasons, including the installation of replacement
or alternate tires or wheels on
the vehicle that prevent the TPMS from
functioning properly. Always check the
TPMS malfunction telltale after replacing
one or more tires or wheels on your
vehicle to ensure that the replacement or
alternate tires and wheels allow the TPMS
to continue to function properly.
Should the warning light illuminate steadily
after blinking for approximately one
minute, have the system inspected by
your nearest SUBARU dealer as soon as
possible.
HTH,
Jim / crewzer
15 Highlander XLE AWD
12 Forester (sold)
09 Forester (sold)
06 BMW 530xi wagon
00 Ford F250
crewzer is offline
post #8 of 17 (permalink) Old 01-04-2010, 10:57 AM
miked290's Avatar
Car Model: 2.5 Premium
Tire Pressure Sensor Light.
I had the same prooblem with my 09 Legacy and the owners manual said that the spare tire is also being monitored. You may want to check.
miked290 is offline
post #9 of 17 (permalink) Old 01-04-2010, 11:13 AM
Mod Emeritus
crewzer's Avatar
Transmission: 6AT
Exclamation
^ Interesting! The OEM temp "donut" spare in my '09 Forester was not monitored by the TPMS. From page 9-2 of the owner's manual:
When a spare tire is mounted or a
wheel rim is replaced without the
original pressure sensor/transmitter
being transferred, the low tire pressure
warning light will illuminate
steadily after blinking for approximately
one minute. This indicates
the tire pressure monitoring system
(TPMS) is unable to monitor all four
road wheels.
Regards,
Jim / crewzer
12 Forester (sold)
09 Forester (sold)
06 BMW 530xi wagon
00 Ford F250
crewzer is offline
post #10 of 17 (permalink) Old 01-28-2011, 07:07 AM
Car Year: 09
I am having the same problem. I leave my house and the light isn't on, half way to work it comes on, then as I drive home it goes off. I have had a garage check it twice and the tires are fine. The service center just tells me to kick the tires to see if they are soft and if it doesn't go off in a couple of days to bring it in.
I can't bring it in because it will go off eventually. The service center also uses the temp excuse, which is annoying because it is only January and it will be this cold for another three month. I actually joined the forum today to see if anyone had a solution for this.
aoma-s is offline
post #11 of 17 (permalink) Old 01-28-2011, 07:24 AM
ArcadeTom's Avatar
A couple of suggestions here:
My '09 will illuminate the TPS light when the temp drops quickly and if my tire pressures are close to the lower limit. Mine seems to trip about 26 PSI. The really confusing part for me was that I had a pressure gauge I thought was good, but when compared to a very accurate gauge, it was reading about 4 PSI higher than what the pressure really was. (i.e. indicated 30 PSI on my gauge and actual pressure was 26). If you check and your pressures seem fine, compare with a different gauge.
Purchase a quality gauge (digital and calibrated if you can) that comes with a protective case. Bouncing around in a tool box or even your glove box will cause them to read incorrectly.
2009 XT, Camillia Red Pearl
ArcadeTom is offline
post #12 of 17 (permalink) Old 01-28-2011, 01:37 PM
Most Subaru dealership maintenance shops fill all four tires to 40psi when you go for an oil change. The Subaru TPS sensor is etremely sensitive to anything below the manufacturer cold-temp pressure suggestion in your book.
The reason some of you are getting the light on when it's first cold is because you're at or below the lower PSI limit. Once you start driving the tires heat up; thus, warming and expanding the air inside your tires. Higher air temp = higher air pressure, so then the TPS light turns off. I would just suggest filling the tires to 35 - 40PSI. All the dealership shops do this in Colorado. The tires wear perfectly like this too.
Soobs is offline
post #13 of 17 (permalink) Old 10-27-2015, 05:39 AM
YAMAHA RIDER's Avatar
Car Model: 2.5X Limited
2010 2.5X Limited
The past couple of days I have had a similar problem with the tire pressure light. My commute to work is about 13 miles, with the first 11 miles on the highway. When I start the car and leave the TPM light is off. After driving on the highway for about 8 or 9 miles the light will come on. Then about a mile or two later it goes off and stays off until I go home. On the way home its the same scenario, light stays off for about 8 or 9 miles. I checked all the tires and they were about 28 to 30 psi so I pumped them up to 35 psi and the light came on again today.
Does anyone know what is causing this? I read the thread and there aren't any solutions that make sense in my scenario. Do the batteries in the sensors need replaced after a while? Its only 5 years old.
YAMAHA RIDER is offline
post #14 of 17 (permalink) Old 10-27-2015, 10:02 AM
Chucker's Avatar
Personally, I think it just that the TPMS is terminally stupid. Mine acted very similar to yours for a while last year, then suddenly stopped again. It's been acting funky again for the last week or so, even after adding air.
Sage Green Mafia!
Chucker is offline
post #15 of 17 (permalink) Old 10-27-2015, 10:44 AM
FXTerrific's Avatar
Car Model: XT Touring
ive had it act funky if its straddling the line or whatever its setting is psi wise...but usually will quit being dumb once im back at about 32-33psi. with that said, last year i had bigger swing psi wise when using general tires (i wanna say like 4-6psi even sometimes with erratic weather changes...and we had a lot of them throughout the winter months). so i would be fine at say 33psi one day, then cold morning see it come on (so guessing i was down into high 20s) then suddenly 50 again that afternoon, and theyre "fine" when i check them.
havent noticed it yet with the Cooper tires i have now.
so maybe its a combo of an over active system...AND the tires you happen to have? @YAMAHA RIDER
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
FXTerrific is offline
